* | score: Delete _CPU_Context_Fp_start() | Sebastian Huber | 2017-01-26 | 18 | -288/+14 |
| | | | | | | | | | | Since the FP area pointer is passed by reference in _CPU_Context_Initialize_fp() the optional FP area adjustment via _CPU_Context_Fp_start() is superfluous. It is also wrong with respect to memory management, e.g. pointer passed to _Workspace_Free() may be not the one returned by _Workspace_Allocate(). Close #1400. | ||||
* | posix: Fix use of uninitialized variable | Sebastian Huber | 2017-01-25 | 1 | -0/+2 |
| | | | | Update #2859. | ||||
* | Adding ARM VFP V2 support | Kevin Kirspel | 2017-01-24 | 1 | -0/+6 |
* | rtems: rtems_rate_monotonic_postponed_job_count() | Sebastian Huber | 2017-01-24 | 1 | -12/+7 |
| | | | | | | Use proper locking in SMP configurations. Update #2795. | ||||
* | rtems: Fix _Rate_monotonic_Release_postponed_job() | Sebastian Huber | 2017-01-24 | 1 | -5/+3 |
* | rtems: Fix _Rate_monotonic_Renew_deadline() | Sebastian Huber | 2017-01-24 | 3 | -44/+21 |
| | | | | | | | Make _Rate_monotonic_Renew_deadline() static and use proper locking in SMP configurations. Update #2795. | ||||
* | sparc: Relax CPU_STACK_ALIGNMENT | Sebastian Huber | 2017-01-24 | 1 | -12/+3 |
| | | | | Close #2352. | ||||
* | Remove CPU_BIG_ENDIAN and CPU_LITTLE_ENDIAN | Sebastian Huber | 2017-01-24 | 17 | -310/+0 |
| | | | | | | Use de-facto standard BYTE_ORDER instead. Close #2803. | ||||
* | Use <sys/endian.h> | Sebastian Huber | 2017-01-24 | 3 | -28/+12 |
| | | | | Update #2803. | ||||
* | Provide <endian.h> for glibc compatibility | Sebastian Huber | 2017-01-24 | 3 | -0/+6 |
* | nfsclient: Fix suspicious condition | Sebastian Huber | 2017-01-23 | 1 | -1/+2 |
| | | | | Close #2700. | ||||
* | sys/endian.h: Document FreeBSD origin | Sebastian Huber | 2017-01-23 | 1 | -1/+1 |
* | JFFS2: Fix typo | Sebastian Huber | 2017-01-19 | 1 | -1/+1 |
* | classic: adjust names of RM postponed job functions | Gedare Bloom | 2017-01-13 | 2 | -9/+14 |
| | | | | closes #2795 | ||||
* | Enhancement of the RMS manager for the overrun handling. | Kuan-Hsun Chen | 2017-01-13 | 4 | -9/+176 |
| | | | | | | | | | | | | | | | Three additional functions: rtems_rate_monotonic_postponed_job_count, _Rate_monotonic_Renew_deadline, and _Rate_monotonic_Release_postponed_job. Four refined functions: _Rate_monotonic_Activate, _Rate_monotonic_Block_while_expired, rtems_rate_monotonic_period, _Rate_monotonic_Timeout. Rate_monotonic_Control contains one counter for counting the postponed jobs and one for recording the recent deadline. Update #2795. | ||||
* | posix: shared memory support | Gedare Bloom | 2017-01-13 | 14 | -8/+882 |
| | | | | | | | | | Add POSIX shared memory manager (Shm). Includes a hook-based approach for the backing memory storage that defaults to the Workspace, and a test is provided using the heap. A test is also provided for the basic use of mmap'ing a shared memory object. This test currently fails at the mmap stage due to no support for mmap. | ||||
* | posix: fix typo in mmap arguments | Gedare Bloom | 2017-01-13 | 1 | -2/+2 |
* | posix: add stub implementations for mman functions | Gedare Bloom | 2017-01-13 | 9 | -0/+222 |
* | posix: move sys/mman.h to newlib and test it in psxhdrs | Gedare Bloom | 2017-01-13 | 4 | -195/+1 |
* | configure: Remove __RTEMS_DO_NOT_INLINE_THREAD_* | Sebastian Huber | 2017-01-13 | 1 | -6/+0 |
* | configure: Remove __RTEMS_HAVE_DECL_SIGALTSTACK__ | Sebastian Huber | 2017-01-13 | 2 | -17/+0 |
* | configure: Remove HAVE_STRUCT__THREAD_QUEUE_QUEUE | Sebastian Huber | 2017-01-13 | 7 | -25/+0 |
* | configure: Remove envlock support | Sebastian Huber | 2017-01-13 | 3 | -124/+1 |
| | | | | This is provided by Newlib itself. | ||||
* | configure: Remove SIZEOF_PTHREAD_SPINLOCK_T | Sebastian Huber | 2017-01-13 | 6 | -65/+2 |
* | configure: Remove HAVE_THREADS_H support | Sebastian Huber | 2017-01-13 | 2 | -6/+1 |
* | configure: Remove HAVE_SEMAPHORE_H support | Sebastian Huber | 2017-01-13 | 4 | -170/+1 |
* | posix: Add pthread_getname_np(), ... | Sebastian Huber | 2017-01-13 | 3 | -0/+84 |
| | | | | | | Add pthread_getname_np() and pthread_setname_np(). Update #2858. | ||||
* | score: Add _Thread_Set_name() | Sebastian Huber | 2017-01-13 | 5 | -0/+53 |
| | | | | | | Add configuration option CONFIGURE_MAXIMUM_THREAD_NAME_SIZE. Update #2858. | ||||
* | score: Add and use _Thread_Get_name() | Sebastian Huber | 2017-01-13 | 7 | -37/+82 |
* | score: Add Thread_queue_Queue::name | Sebastian Huber | 2017-01-13 | 7 | -21/+46 |
* | score: Add and use _Objects_Name_to_string() | Sebastian Huber | 2017-01-13 | 2 | -27/+79 |
* | configure: Add RTEMS_TOOL_CHAIN_ERROR | Sebastian Huber | 2017-01-13 | 1 | -14/+13 |
| | | | | | Stop the build with a common error message in case the tool chain is seriously out of date. | ||||
* | cpuuse: Call printer only once | Sebastian Huber | 2017-01-12 | 1 | -14/+7 |
* | Fix documentation comment | Sebastian Huber | 2017-01-12 | 1 | -4/+4 |
* | rtems: Use header file for rtems_object_get_name() | Sebastian Huber | 2017-01-12 | 1 | -10/+1 |
* | Add and use rtems_assoc_thread_states_to_string() | Sebastian Huber | 2017-01-12 | 5 | -90/+81 |
* | libdebugger: Fix const qualifier | Sebastian Huber | 2017-01-12 | 1 | -1/+1 |
* | Add rtems_assoc_32_to_string() | Sebastian Huber | 2017-01-12 | 3 | -1/+94 |
* | score: Remove unused _States_Is_*() | Sebastian Huber | 2017-01-12 | 1 | -153/+0 |
* | score: Replace STATES_DELAYING | Sebastian Huber | 2017-01-12 | 5 | -41/+8 |
| | | | | | | | | Replace STATES_DELAYING with STATES_WAITING_FOR_TIME. There is no need for separate timeout thread states. The Thread_Control::Timer::header and Watchdog_Control::cpu members can be used to figure out the kind of timeout. | ||||
* | Remove obsolete __RTEMS_HAVE_SYS_CPUSET_H__ | Joel Sherrill | 2017-01-11 | 17 | -123/+70 |
* | Add support for posix_devctl() | Joel Sherrill | 2017-01-11 | 3 | -1/+76 |
* | posix: Fix alarm() in SMP configurations | Sebastian Huber | 2017-01-11 | 1 | -2/+0 |
| | | | | | Avoid to change the CPU of the watchdog right in the middle of the critical section. This would corrupt the watchdog lock states. | ||||
* | score: Improve SMP lock debug support | Sebastian Huber | 2017-01-11 | 4 | -7/+18 |
| | | | | | The CPU index starts with zero. Increment it by one, to allow global SMP locks to reside in the BSS section. | ||||
* | score: Optimize thread state values | Sebastian Huber | 2017-01-11 | 1 | -48/+73 |
* | score: Add STATES_THREAD_QUEUE_WITH_IDENTIFIER | Sebastian Huber | 2017-01-11 | 16 | -49/+43 |
| | | | | | Add thread state bit to identify thread queues that are embedded in an object with identifier. | ||||
* | score: Delete STATES_WAITING_FOR_BUFFER | Sebastian Huber | 2017-01-11 | 3 | -22/+1 |
* | score: Format thread state defines | Sebastian Huber | 2017-01-11 | 1 | -27/+27 |
| | | | | Specify all 32-bits in a thread state define. | ||||
* | sys/event.h: Update to FreeBSD head 2017-01-02 | Sebastian Huber | 2017-01-09 | 1 | -29/+31 |
* | score: Relax <sys/lock.h> static assertions | Sebastian Huber | 2016-12-23 | 5 | -9/+9 |
| | | | | Only require that the Newlib defined structure is big enough. |
