2000-07-14 | Changed name of static table versions to avoid conflict. | Joel Sherrill | 1 | -2/+2 | |
2000-07-11 | Removed no cpu references. | Joel Sherrill | 12 | -15/+15 | |
2000-07-11 | Reworked score/cpu/sparc so it can be safely compiled multilib. All | Joel Sherrill | 10 | -127/+32 | |
routines and structures that require CPU model specific information are now in libcpu. This primarily required moving erc32 specific information from score/cpu files to libcpu/sparc and the erc32 BSP. | |||||
2000-07-11 | Added Hitachi H8/300 to the list of CPUs that should be OK with | Joel Sherrill | 1 | -0/+1 | |
using cpuopts.h and not targopts.h. | |||||
2000-07-11 | Reworked score/cpu/i960 so it can be safely compiled multilib. All | Joel Sherrill | 5 | -533/+31 | |
routines and structures that require CPU model specific information are now in libcpu. This required significant rework of the score/cpu header files and the creation of multiple header files and subdirectories in libcpu/i960. | |||||
2000-07-11 | Patch rtems-rc-20000711-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 8 | -9/+16 | |
that decouples exec/ for the sh, m68k and i960 from targopts.h. NOTE: The change to system.h is a hack to enable cpuopts.h for some targets, but keep using targopts.h for others - I know it does *not* work for sparc, mips, i386 and ppc. This will have to be addressed as work continues on multilibing. | |||||
2000-07-10 | Patch rtems-rc-20000709-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2 | -0/+6 | |
that addresses aspects of the targopts.h multilib related issues. Changes: * Move targopts.h to libbsp/include, because the current targopts.h actually is a per-BSP-header and therefore can not stay below exec/. * Introduce an autoheader generated header file (exec/score/include/rtems/score/cpuopts.h), which shall take per-cpu configuration options only. * Move all autoconf-detectable/configure specified per-cpu option-defines from targopts.h to cpuopts.h. * Add Makefiles to the libbsp/shared directory hierarchy. Notes: * The new per-bsp targopts.h in libbsp includes the per-cpu cpuopts.h. This way, the new targopts.h is kept backward compatible to the old targopts.h and existing BSPs which (carelessly) include targopts.h (i386, ppc) should be kept working when using the multilib-disabled configuration scheme. * cpuopts.h is not yet complete, because the per-BSP make-targopts rules from custom/<BSP>.cfg files can not be applied to files below exec/ when building multilibs. * All files below exec/ should not include targopts.h anymore, but should include cpuopts.h instead. However, eliminating inclusion of targopts.h currently triggers further structural / header file inclusion related issues, because several ports apply BSP or CPU_MODEL specific defines from targopts.h below exec/ | |||||
2000-07-07 | Moved old_exception_processing and new_exception_processing directories | Joel Sherrill | 1 | -7/+1 | |
from score/cpu to libcpu because the determination of which to use is based on RTEMS_CPU_MODEL. Thus it can not be determined based solely on multilib information. | |||||
2000-07-07 | Fixed problem reported by Victor V. Vengerov <Victor.Vengerov@oktet.ru> | Joel Sherrill | 1 | -1/+7 | |
where alarm() did not correctly account for the watchdog start_time and stop_time fields being based on ticks not seconds. This resulted in alarm() returning a bogus number of seconds remaining. | |||||
2000-07-07 | Moved __RTEMS_APPLICATION__ conditional to include the use of the | Joel Sherrill | 1 | -1/+1 | |
static inline routine _CORE_mutex_Seize_interrupt_trylock since static routines are not included when in an application. | |||||
2000-07-06 | Switched to faster implementation. | Joel Sherrill | 1 | -25/+20 | |
2000-07-06 | Patch from Eric Valette <valette@crf.canon.fr> and Yacine El Kolli | Joel Sherrill | 1 | -2/+2 | |
<elkolli@crf.canon.fr> to add support for the mbx860_005b. | |||||
2000-07-06 | Added missing #endif's. | Joel Sherrill | 2 | -3/+0 | |
2000-07-06 | Corrected call to _CORE_mutex_Seize_interrupt_blocking. | Joel Sherrill | 1 | -2/+5 | |
2000-07-06 | Modfied to execute faster and have fewer instructions. | Joel Sherrill | 1 | -38/+38 | |
2000-07-06 | Switched to using isr disable version of _Objects_Get. When the | Joel Sherrill | 1 | -13/+15 | |
semaphore/mutex can be obtained immediately, this cuts execution time by 50%. | |||||
2000-07-06 | Added _Semaphore_Get_interrupt_disable. | Joel Sherrill | 1 | -0/+10 | |
2000-07-06 | Cleaned up to avoid disruptive use of inline conditionals. | Joel Sherrill | 1 | -18/+16 | |
2000-07-06 | Switched to using _POSIX_Mutex_Get_interrupt_disable to improve performance. | Joel Sherrill | 1 | -3/+4 | |
2000-07-06 | Added support for converting a mutex id to a pointer and returning | Joel Sherrill | 1 | -21/+39 | |
with interrupts disabled. | |||||
2000-07-06 | Reimplemented _Core_MUTEX_Seize to return with interrupts disabled | Joel Sherrill | 2 | -7/+119 | |
if the mutex is successfully obtained. | |||||
2000-07-06 | Added _CORE_semaphore_Seize_isr_disable. | Joel Sherrill | 1 | -0/+56 | |
2000-07-06 | Added _Objects_Get_isr_disable prototype and added numerous comments. | Joel Sherrill | 1 | -7/+18 | |
2000-07-06 | Removed unnecessary parentheses. | Joel Sherrill | 1 | -4/+4 | |
2000-07-06 | Added objjectgetbyisr.c | Joel Sherrill | 1 | -2/+3 | |
2000-07-06 | The code that attempts to obtain a mutex has now been inlined. The | Joel Sherrill | 1 | -83/+7 | |
code remaining here now only blocks. | |||||
2000-07-06 | Directly index local table to avoid error check. | Joel Sherrill | 3 | -12/+10 | |
2000-07-06 | New file. Convert ID to pointer and return with interrupts -- not | Joel Sherrill | 1 | -0/+83 | |
dispatching -- disabled. | |||||
2000-07-06 | Format of return line changed. | Joel Sherrill | 1 | -3/+3 | |
2000-07-03 | Interrupt stack is allocated in _ISR_Handler_initialization not | Joel Sherrill | 8 | -8/+8 | |
_Interrupt_Manager_initialization. | |||||
2000-07-03 | Added blocked_count field to allow for optimizations. | Joel Sherrill | 2 | -2/+4 | |
2000-07-03 | Changed extra_system_initialization_stack to extra_mpci_receive_server_stack | Joel Sherrill | 1 | -1/+1 | |
to be consistent with other ports. | |||||
2000-07-02 | Fixed stat_ino should be st_ino. | Joel Sherrill | 1 | -1/+1 | |
2000-06-30 | Patch from Chris Johns <cjohns@cybertec.com.au> so the web server | Joel Sherrill | 2 | -3/+12 | |
shuts down on error -- not exitting the system. | |||||
2000-06-30 | Patch from Chris Johns <cjohns@cybertec.com.au> so the directory | Joel Sherrill | 1 | -1/+1 | |
read function in the IMFS properly returns the inode number. | |||||
2000-06-30 | Patch from Chris Johns <cjohns@cybertec.com.au> to add support for | Joel Sherrill | 2 | -13/+17 | |
stat()'ing a symbolic link. This is needed to support the port of the BSD commands like ls to RTEMS. | |||||
2000-06-30 | Patch from Chris Johns <cjohns@cybertec.com.au> to add fchdir() | Joel Sherrill | 2 | -0/+72 | |
functionality to libc and update TODO. | |||||
2000-06-29 | This is the initial addition of the port of RTEMS to the | Joel Sherrill | 12 | -0/+1979 | |
Hitachi H8 family. This port was done by Philip Quaife <philip@qs.co.nz> of Q Solutions and sponsored by Comnet Technologies Ltd. The port was done based on RTEMS 3.5.1 to a Hitach H8300H. The port was updated to RTEMS 4.5 style Makefiles/configure by Joel Sherrill <joel@OARcorp.com>. While doing this Joel added support for the h8300-rtems to binutils, gcc, newlib, and gdb. NOTE: Philip submitted a BSP for a Hitachi evaluation board which is being merged as a separate entity. | |||||
2000-06-29 | Added H8 as IEEE whether this is true or not. | Joel Sherrill | 1 | -0/+1 | |
2000-06-29 | Disabled #ident since the h8300-rtems binutils do not like the | Joel Sherrill | 1 | -1/+1 | |
generated assembly from it. | |||||
2000-06-29 | Corrected prototype for xdrrec_endofrecord to match C body. | Joel Sherrill | 1 | -1/+1 | |
2000-06-29 | Added RTEMS_CPU_HAS_16_BIT_ADDRESSES constant to disable code | Joel Sherrill | 2 | -0/+12 | |
that breaks when the target has 16 bit address space. One of the H8 multilibs is a 16-bit address space CPU. When a real attempt is made to support this CPU model, the code that assumes an address is 32 bits will have to change. This constant is probably not flagging all impacted code. | |||||
2000-06-29 | Patch from Chris Johns <cjohns@cybertec.com.au> to make sure the | Joel Sherrill | 1 | -1/+2 | |
ttyHead back link is set. | |||||
2000-06-26 | Patch from Chris Johns <cjohns@cybertec.com.au> and | Joel Sherrill | 1 | -0/+3 | |
Jennifer Averett <jennifer.averett@oarcorp.com> to fix appends (O_APPEND at open time) on in-memory files. A call such as: fd = open (file, O_APPEND | O_WRONLY); did not append to the end of the file. | |||||
2000-06-26 | Patch from Chris Johns <cjohns@cybertec.com.au> and | Joel Sherrill | 1 | -1/+1 | |
Jennifer Averett <jennifer.averett@oarcorp.com> to make sure "/" is created with S_IFDIR set. | |||||
2000-06-16 | Patch from John Cotton <john.cotton@nrc.ca> to correct style of | Joel Sherrill | 1 | -16/+16 | |
names to be rtems_PACKAGE_method. | |||||
2000-06-15 | Remove pragma align 4 | Joel Sherrill | 1 | -2/+0 | |
2000-06-15 | Fixing warning obtained by some users. | Joel Sherrill | 1 | -0/+4 | |
2000-06-15 | Moved <sys/cdefs.h> to lib/include so non-networking applications could | Joel Sherrill | 1 | -1/+1 | |
include <sys/ioctl.h>. | |||||
2000-06-14 | Moved <sys/cdefs.h> from libnetworking to lib/include so non-networking | Joel Sherrill | 1 | -0/+177 | |
configurations could see it while including <sys/ioctl.h> and <sys/ioccom.h>. |
