PR 500/misc
* libcsupport/src/termios.c: Avoid potential buffer overflow.
* cpu.c: Fix prototypes.
* rtems/score/cpu.h: Use memcpy() initialize FP structure and avoid
many casts and potential warnings.
* libnetworking/kern/kern_sysctl.c, libnetworking/libc/res_debug.c: Fix
warnings.
* rtems/score/cpu.h: Fix type when initializing FP context.
* libfs/src/nfsclient/src/nfs.c, libfs/src/nfsclient/src/rpcio.c:
Remove some warnings. Using ASSERT/assert macros confuses gcc who is
unsure actions take place. More importantly if you ever compiled with
NDEBUG set wrong, intended actions would not occur. Likely I did not
catch all of these.
* httpd/uemf.h: Add empty braces to macro.
PR 1296/cpukit.
* posix/src/timersettime.c: POSIX timers use incorrect repeat interval.
This patch fixes the following problems in timer_settime: 1) Uses
value.it_interval for repeat period. 2) Corrects test for incorrect
value of it_value.tv_nsec (should reject 1000000000).
* cpu.c, rtems/score/cpu.h: Add extern for bfffo table and rename it to
indicate that it is specific to this architecture.
* score/inline/rtems/score/threadmp.inl: Add include of
rtems/score/mpci.h and remove extern.
* libcsupport/include/clockdrv.h: Add Clock_Exit prototype.
* rtems/inline/rtems/rtems/asr.inl,
rtems/inline/rtems/rtems/attr.inl,
rtems/inline/rtems/rtems/barrier.inl,
rtems/inline/rtems/rtems/dpmem.inl,
rtems/inline/rtems/rtems/event.inl,
rtems/inline/rtems/rtems/eventset.inl,
rtems/inline/rtems/rtems/message.inl,
rtems/inline/rtems/rtems/modes.inl,
rtems/inline/rtems/rtems/options.inl,
rtems/inline/rtems/rtems/part.inl,
rtems/inline/rtems/rtems/ratemon.inl,
rtems/inline/rtems/rtems/region.inl,
rtems/inline/rtems/rtems/sem.inl,
rtems/inline/rtems/rtems/status.inl,
rtems/inline/rtems/rtems/support.inl,
rtems/inline/rtems/rtems/tasks.inl,
rtems/inline/rtems/rtems/timer.inl,
Add header guard to force indirect inclusion.
* rtems/score/cpu.h: Add missing prototype.
* score/inline/rtems/score/address.inl,
score/inline/rtems/score/chain.inl,
score/inline/rtems/score/corebarrier.inl,
score/inline/rtems/score/coremsg.inl,
score/inline/rtems/score/coremutex.inl,
score/inline/rtems/score/corerwlock.inl,
score/inline/rtems/score/coresem.inl,
score/inline/rtems/score/corespinlock.inl,
score/inline/rtems/score/heap.inl,
score/inline/rtems/score/isr.inl,
score/inline/rtems/score/mppkt.inl,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/objectmp.inl,
score/inline/rtems/score/priority.inl,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/states.inl,
score/inline/rtems/score/sysstate.inl,
score/inline/rtems/score/thread.inl,
score/inline/rtems/score/threadmp.inl,
score/inline/rtems/score/threadq.inl,
score/inline/rtems/score/tod.inl,
score/inline/rtems/score/tqdata.inl,
score/inline/rtems/score/watchdog.inl,
score/inline/rtems/score/wkspace.inl:
* posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/key.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/inline/rtems/posix/timer.inl:
* itron/inline/rtems/itron/eventflags.inl,
itron/inline/rtems/itron/fmempool.inl,
itron/inline/rtems/itron/intr.inl,
itron/inline/rtems/itron/mbox.inl,
itron/inline/rtems/itron/msgbuffer.inl,
itron/inline/rtems/itron/network.inl,
itron/inline/rtems/itron/port.inl,
itron/inline/rtems/itron/semaphore.inl,
itron/inline/rtems/itron/sysmgmt.inl,
itron/inline/rtems/itron/task.inl,
itron/inline/rtems/itron/time.inl,
itron/inline/rtems/itron/vmempool.inl:
* sapi/inline/rtems/chain.inl:
* rtems/include/rtems/rtems/object.h: Use _RTEMS_RTEMS_OBJECT_H as
header guard.
* libnetworking/netinet/in_cksum_arm.h, score/cpu/arm/cpu.c
score/cpu/h8300/rtems/score/cpu.h: Add missing prototypes.
* cpu.c, rtems/score/cpu.h: Add void.
* libnetworking/lib/ftpfs.c, libnetworking/libc/inet_ntoa.c,
libnetworking/libc/rcmd.c, libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_glue.c,
libnetworking/rtems/rtems_malloc_mbuf.c,
libnetworking/rtems/rtems_showicmpstat.c, libnetworking/sys/malloc.h:
Fix some warnings.
* libcsupport/include/rtems/libcsupport.h, libcsupport/src/scandir.c,
libmisc/cpuuse/cpuusagereset.c, libmisc/monitor/mon-monitor.c,
libmisc/serdbg/serdbg.c, libmisc/serdbg/serdbg.h,
libnetworking/netinet/in_cksum_powerpc.h, shttpd/compat_rtems.h: Fix
warnings.
* itron/include/rtems/itron/task.h, itron/src/def_cyc.c,
itron/src/task.c, libcsupport/src/newlibc_exit.c,
libcsupport/src/sync.c, libfs/src/imfs/imfs_fchmod.c,
posix/include/rtems/posix/pthread.h, posix/src/pthread.c,
posix/src/sysconf.c, rtems/include/rtems/rtems/tasks.h,
rtems/src/tasks.c, score/include/rtems/score/stack.h,
score/inline/rtems/score/thread.inl, score/src/threadhandler.c: Fix
various nested-externs warnings.
* libcsupport/Makefile.am, libcsupport/src/newlibc.c: Split libc_init()
into a separate file to avoid linkage dependencies on newlibc.c which
in turn pulls in fclose() and other C library methods.
* libcsupport/src/newlibc_init.c: New file.
* aclocal/prog-cc.m4: Add -Wnested-externs.
* libnetworking/net/ppp_tty.c: Remove bogus local decl of
termios_baud_to_number(int).
* libnetworking/netinet/in_cksum_i386.h: Add missing prototype.
* libnetworking/netinet/in_cksum.c: Add missing prototypes.
* librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/svc_tcp.c:
* rtems/score/cpu.h, rtems/score/i386.h: Add missing prototypes.
* libfs/src/nfsclient/src/librtemsNfs.h: Add missing prototype.
* aclocal/prog-cc.m4: Add -Wimplicit-function-declaration
-Wstrict-prototypes to RTEMS_CFLAGS.
* ChangeLog: Add correct entry.
PR 1297/cpukit
* posix/src/prwlockinit.c: Fix NULL attribute pointer handling.
* rtems/include/rtems/rtems/ratemon.h,
rtems/include/rtems/rtems/status.h,
score/include/rtems/score/object.h: Removed extraneous commas.
* rtems/powerpc/registers.h: Removed obsolete defines MSR_, MSR_KERNEL
and MSR_USER. Added missing prototypes.
* rtems/include/rtems/rtems/msgmp.h: Fix MP code missed by Sebastian.
* libmisc/monitor/monitor.h, rtems/include/rtems/rtems/tasks.h,
score/include/rtems/score/thread.h, score/src/threadreset.c,
score/src/threadrestart.c, score/src/threadstart.c: New type
Thread_Entry_numeric_type for numeric arguments in thread entry
functions with at least one numeric argument.
* score/include/rtems/score/sysstate.h,
score/inline/rtems/score/sysstate.inl, score/src/thread.c: Make
_System_state_Is_multiprocessing unused when multiprocessing is not
enabled. Saves one more variable from single processor configuration.
