* include/rtems/libio.h: Remove.
* configure.ac: Check for sys/cdefs.h, Add NEED_SYS_CDEFS_H.
Add check for CHAR_BIT.
* Makefile.am: Conditionally install sys/cdefs.h iff using newlib or
if the host does not provide sys/cdefs.h (Fixes Linux/posix).
* aclocal/version.m4: Updated to rtems-ss-20021118.
* configure.ac: Remove -ansi -fasm.
Add checks to diagnose potential system header conflicts.
* Makefile.am: Unconditionally install sys/cdefs.h.
* Makefile.am: Merge-in HEADER-handling from
net/Makefile.am, netinet/Makefile.am, nfs/Makefile.am.
* net/Makefile.am: Remove *_HEADERS.
* netinet/Makefile.am: Remove *_HEADERS.
* nfs/Makefile.am: Remove *_HEADERS.
* aclocal/prog-cc.m4: Acknowledge configuration-time CFLAGS.
* automake/compile.am: Acknowledge configuration-time CFLAGS.
Remove CFLAGS_DEFAULT.
* Makefile.am: Merge-in arpa/Makefile.am, machine/Makefile.am,
sys/Makefile.am, vm/Makefile.am.
Add . to SUBDIRS.
* arpa/Makefile.am: Remove.
* machine/Makefile.am: Remove.
* sys/Makefile.am: Remove.
* vm/Makefile.am: Remove.
* include/rtems/userenv.h: Rely upon <limits.h> for
_POSIX_LOGIN_NAME_MAX.
* src/diskdevs.c: Include <unistd.h> to remove warning.
* monitor/mon-commands.c: Removed warnings for RTEMS_UNIX.
* macros/rtems/score/object.inl: Keep consistent with inline version.
* capture/Makefile.am: Remove AUTOMAKE_OPTIONS.
* serdbg/Makefile.am: Remove AUTOMAKE_OPTIONS.
* serdbg/serdbgio.c: Add #include <unistd.h>.
* shell/Makefile.am: Add RTEMS_LIBSHELL conditional.
* wrapup/Makefile.am: Add RTEMS_LIBSHELL conditional.
* configure.ac: Check for stdio assignments.
* src/regionreturnsegment.c: When RTEMS_REGION_SHRED_ON_FREE is
set, there should have been an & in front of size.
* configure.ac: Generate unixsize.h on the fly, filter out
autoconf-2.53 PACKAGE crap.
* rtems/score/.cvsignore: unixsize*
* aclocal/version.m4: Updated to rtems-ss-20021111.
* src/mount.c: Per PR297, correct fs_mountme failure paths.
* sys/select.h: Add C++ to C external.
paths.
* rtems/score/cpu.h: Add prototype of H8BD_Install_IRQ to eliminate
warning.
* rtems/new-exceptions/cpu.h: Remove sections on
CPU_INLINE_ENABLE_DISPATCH and CPU_UNROLL_ENQUEUE_PRIORITY.
* rtems/old-exceptions/cpu.h: Remove sections on
* rtems/score/cpu.h: Insert sections on
* src/psignal.c: Fix counting problem which resulted in too many
entries being in the POSIX signals default behavior table.
* idtcpu.h: Removed warning.
* cpu.c: Removed warning.
* src/rpc/pmap_rmt.c: Removed warnings.
* pppd/auth.c, rtems_webserver/uemf.h: Removed warnings.
* kern/uipc_mbuf.c: Comment out m0 in m_copydata to suppress
warning.
* ChangeLog: Corrected.
* idtcpu.h: Removed warnings.
* cpu.c: Removed warnings.
use bootp option 129 to get command line string
change inet_ntoa->inet_ntop
* stackchk/check.c: Removed warnings.
* rtems/score/cpu.h: Removed warning.
* src/rpc/svc_run.c: Remove warning.
* src/mallocfreespace.c: Corrected sense of status check to
match change inside RTEMS.
* src/newlibc.c: Removed warning.
* rtems_webserver/socket.c, rtems_webserver/uemf.h: Removed
warnings.
* stackchk/check.c: Removed warning.
* src/regiongetinfo.c: Corrected return value check.
* libc/rcmd.c, netinet/in_cksum_arm.c: Removed warnings.
* src/heapgetinfo.c: Fixed comment.
* src/mpci.c: Removed warning.
* rtems/new-exceptions/cpu.h: Removed warnings.
which have already obtained the va_list pointer.
* aclocal/check-bsp-cache.m4: Remove.
* aclocal/multilib.m4: Remove RTEMS_ENABLE_MULTILIB_MASTER.
* configure.ac: Remove AC_ENABLE_MULTILIB.
* Makefile.am: Add CVS-Id.
