* ChangeLog: Correct format.
* wrapup/Makefile.am: Remove bogus $(MULTISUBDIR).
opertations will wait for ever.
will wait for ever.
* configure.ac: Remove (Merged-in into ../configure.ac)
* Makefile.am, include/Makefile.am, src/Makefile.am,
src/rpc/Makefile.am, src/xdr/Makefile.am:
* cpu/Makefile.am: Add DIST_SUBDIRS = $(RTEMS_CPU).
* configure.ac: Merge-in librpc/configure.ac.
* Makefile.am: Add librpc to SUBDIRS.
Remove @subdirs@.
PR 418/ada
* rtems.adb: Add missing all keyword to derefence pointer.
PR 419/rtems
* src/termios.c: Removed warning.
* configure.ac: Merge-in libcsupport/configure.ac.
* Makefile.am: Add libcsupport to SUBDIRS.
* Makefile.am: DOC_FILES = src/TODO src/CASES,
* src/config.h: New.
* configure.ac: Merge-in posix/configure.ac.
Merge-in itron/configure.ac.
Misc. cosmetical changes.
* Makefile.am: Add posix, itron to SUBDIRS.
* Makefile.am:
* configure.ac: Merge-in libnetworking/configure.ac.
Remove "rtems-" from RTEMS_VERSION.
Add AC_CHECK_FUNCS([strsep strcasecmp snprintf]).
* Makefile.am: Add libmisc to SUBDIRS.
* configure.ac: Remove (Merged into ../configure.ac).
* Makefile.am, libc/Makefile.am, lib/Makefile.am, wrapup/Makefile.am:
* kern/kern_mib.c: Use RTEMS_VERSION to setup osrelease.
* configure.ac: Merge-in libmisc/configure.ac.
* Makefile.am:
* capture/config.h: New.
* capture/Makefile.am: Add config.h.
* cpuuse/config.h: New.
* cpuuse/Makefile.am: Add config.h.
* devnull/config.h: New.
* devnull/Makefile.am: Add config.h.
* dummy/config.h: New.
* dummy/Makefile.am: Add config.h.
* dumpbuf/config.h: New.
* dumpbuf/Makefile.am: Add config.h.
* monitor/config.h: New.
* monitor/Makefile.am: Add config.h.
* mw-fb/config.h: New.
* mw-fb/Makefile.am: Add config.h.
* rtmonuse/config.h: New.
* rtmonuse/Makefile.am: Add config.h.
* serdbg/config.h: New.
* serdbg/Makefile.am: Add config.h.
* shell/config.h: New.
* shell/Makefile.am: Add config.h.
* stackchk/config.h: New.
* stackchk/Makefile.am: Add config.h.
* untar/config.h: New.
* untar/Makefile.am: Add config.h.
* configure.ac: Merge-in libfs/configure.ac.
* Makefile.am: Add libfs to SUBDIRS.
* Makefile.am, src/Makefile.am, src/dosfs/Makefile.am,
src/imfs/Makefile.am: Reflect having merged configure.ac into
../configure.ac.
* src/dosfs/config.h: New.
* src/dosfs/Makefile.am: Add config.h.
* src/imfsfs/config.h: New.
* src/imfs/Makefile.am: Add config.h.
Remove COMMON_C_FILES, DOC_FILES (Unused).
* src/dosfs/fat.c: include config-header "config.h".
* src/dosfs/fat_fat_operations.c: Ditto.
* src/dosfs/fat_file.c: Ditto.
* src/dosfs/msdos_conv.c: Ditto.
* capture/capture-cli.c: Add config-header support.
* capture/capture.c: Add config-header support.
* cpuuse/cpuuse.c: Add config-header support.
* devnull/devnull.c: Add config-header support.
* dummy/dummy.c: Add config-header support.
* dumpbuf/dumpbuf.c: Add config-header support.
* monitor/mon-command.c: Add config-header support.
* monitor/mon-config.c: Add config-header support.
* monitor/mon-dname.c: Add config-header support.
* monitor/mon-driver.c: Add config-header support.
* monitor/mon-extension.c: Add config-header support.
* monitor/mon-itask.c: Add config-header support.
* monitor/mon-manager.c: Add config-header support.
* monitor/mon-monitor.c: Add config-header support.
* monitor/mon-mpci.c: Add config-header support.
* monitor/mon-object.c: Add config-header support.
* monitor/mon-prmisc.c: Add config-header support.
* monitor/mon-queue.c: Add config-header support.
* monitor/mon-server.c: Add config-header support.
* monitor/mon-symbols.c: Add config-header support.
* monitor/mon-task.c: Add config-header support.
* mw-fb/mw_fb.c: Add config-header support.
* mw-fb/mw_uid.c: Add config-header support.
* rtmonuse/rtmonuse.c: Add config-header support.
* serdbg/serdbg.c: Add config-header support.
* serdbg/serdbgio.c: Add config-header support.
* serdbg/termios_printk.c: Add config-header support.
* shell/cmds.c: Add config-header support.
* stackchk/check.c: Add config-header support.
* untar/untar.c: Add config-header support.
* Makefile.am: Reflect having merged configure.ac into
../configure.ac.
* configure.ac: Merge-in libblock/configure.ac.
* Makefile.am: Add libblock to SUBDIRS.
* configure.ac: Merge-in ada/configure.ac.
* Makefile.am: Add ada to SUBDIRS.
../configure.ac.
PR 417/rtems
* src/coresemsurrender.c: Correct incorrect check for maximum_count
reported by Sergei Organov <osv@topconrd.ru>.
* configure.ac: Remove RTEMS_BSP from RTEMS_CHECK_MULTIPROCESSING.
* aclocal/version.m4: Updated to rtems-ss-20030703.
rtems_termios_bufsize call.
* src/threadloadenv.c: Removed warnings.
* pppd/chat.c: Removed warnings.
* src/objectmp.c: Removed warnings.
* include/rtems/rtems/msgmp.h, include/rtems/rtems/partmp.h,
include/rtems/rtems/regionmp.h, include/rtems/rtems/semmp.h,
src/msgmp.c, src/partmp.c, src/regionmp.c, src/semmp.c: Removed
warnings.
PR 411/filesystem
* src/imfs/imfs_unlink.c: Fix bug where renaming a memfile and
then unlinking it causes a memory leak.
* stackchk/check.c: Removed warnings.
* src/ide_part_table.c: Removed warnings.
* rtems/rtems_syscall.c: Removed warnings.
* pppd/fsm.c: Make peer_mru global again.
PR 409:
* include/stdint.h: Include rtems/stdint.h
PR 409:
* include/rtems/rtems/types.h: Include rtems/stdint.h.
Apply c99-types to typedef rtems_[un]signed[8|16|32|64].
PR 409:
* include/Makefile.am: Add rtems/stdint.h
* include/rtems/stdint.h: New.
PR 321:
* aclocal/env-rtemscpu.m4: Remove support for profile-variant.
* automake/compile.am: Ditto.
* automake/local.am: Ditto.
PR 399/rtems_misc
* src/termios.c: In canonical mode, when input is present in the
input buffer that contains an EOL character and some following
characters, a read call read data behind the EOL character, although
it should stop reading with the EOL character.
