path: root/cpukit (follow)
* Added code to initialize the /etc/group and /etc/passwd files.Joel Sherrill1999-07-022-0/+91
* Fixed format strings and warnings.Joel Sherrill1999-07-022-9/+9
* Reentrant versions added by Joel. Signficant formatting cleanup.Joel Sherrill1999-07-022-115/+176
* Password and group routines added by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill1999-07-022-0/+248
* Honor 0 as PID of caller.Joel Sherrill1999-07-011-1/+1
* New file to implement signal(2).Joel Sherrill1999-07-011-0/+50
* Removed hack to set __USER_LABEL_PREFIX__ since late model gcc's andJoel Sherrill1999-07-012-2/+0
| | | | | egcs source tree handle this correctly. No one should be using gcc 2.7.2 anymore.
* After comments D. V. Henkel-Wallace <gumby@zembu.com>, the interface toJoel Sherrill1999-06-154-38/+6
| | | | mount() was changed to avoid the use of a string as the options.
* RTEMS_FILESYSTEM_READ_WRITE_ONLY changed to RTEMS_FILESYSTEM_READ_WRITEJoel Sherrill1999-06-142-2/+2
| | | | for simplicity.
* Wrong prototype corrected.Joel Sherrill1999-06-141-1/+1
* Warning removal from D. V. Henkel-Wallace <gumby@zembu.com>.Joel Sherrill1999-06-142-6/+6
* This is a large patch from Eric Valette <valette@crf.canon.fr> that wasJoel Sherrill1999-06-148-1149/+1249
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | described in the message following this paragraph. This patch also includes a mcp750 BSP. From valette@crf.canon.fr Mon Jun 14 10:03:08 1999 Date: Tue, 18 May 1999 01:30:14 +0200 (CEST) From: VALETTE Eric <valette@crf.canon.fr> To: joel@oarcorp.com Cc: raguet@crf.canon.fr, rtems-snapshots@oarcorp.com, valette@crf.canon.fr Subject: Questions/Suggestion regarding RTEMS PowerPC code (long) Dear knowledgeable RTEMS powerpc users, As some of you may know, I'm currently finalizing a port of RTEMS on a MCP750 Motorola board. I have done most of it but have some questions to ask before submitting the port. In order to understand some of the changes I have made or would like to make, maybe it is worth describing the MCP750 Motorola board. the MCP750 is a COMPACT PCI powerpc board with : 1) a MPC750 233 MHz processor, 2) a raven bus bridge/PCI controller that implement an OPENPIC compliant interrupt controller, 3) a VIA 82C586 PCI/ISA bridge that offers a PC compliant IO for keyboard, serial line, IDE, and the well known PC 8259 cascaded PIC interrupt architecture model, 4) a DEC 21140 Ethernet controller, 5) the PPCBUG Motorola firmware in flash, 6) A DEC PCI bridge, This architecture is common to most Motorola 60x/7xx board except that : 1) on VME board, the DEC PCI bridge is replaced by a VME chipset, 2) the VIA 82C586 PCI/ISA bridge is replaced by another bridge that is almost fully compatible with the via bridge... So the port should be a rather close basis for many 60x/7xx motorola board... On this board, I already have ported Linux 2.2.3 and use it both as a development and target board. Now the questions/suggestions I have : 1) EXCEPTION CODE ------------------- As far as I know exceptions on PPC are handled like interrupts. I dislike this very much as : a) Except for the decrementer exception (and maybe some other on mpc8xx), exceptions are not recoverable and the handler just need to print the full context and go to the firmware or debugger... b) The interrupt switch is only necessary for the decrementer and external interrupt (at least on 6xx,7xx). c) The full context for exception is never saved and thus cannot be used by debugger... I do understand the most important for interrupts low level code is to save the minimal context enabling to call C code for performance reasons. On non recoverable exception on the other hand, the most important is to save the maximum information concerning proc status in order to analyze the reason of the fault. At least we will need this in order to implement the port of RGDB on PPC ==> I wrote an API for connecting raw exceptions (and thus raw interrupts) for mpc750. It should be valid for most powerpc processors... I hope to find a way to make this coexist with actual code layout. The code is actually located in lib/libcpu/powerpc/mpc750 and is thus optional (provided I write my own version of exec/score/cpu/powerpc/cpu.c ...) See remark about files/directory layout organization in 4) 2) Current Implementation of ISR low level code ----------------------------------------------- I do not understand why the MSR EE flags is cleared again in exec/score/cpu/powerpc/irq_stubs.S #if (PPC_USE_SPRG) mfmsr r5 mfspr r6, sprg2 #else lwz r6,msr_initial(r11) lis r5,~PPC_MSR_DISABLE_MASK@ha ori r5,r5,~PPC_MSR_DISABLE_MASK@l and r6,r6,r5 mfmsr r5 #endif Reading the doc, when a decrementer interrupt or an external interrupt is active, the MSR EE flag is already cleared. BTW if exception/interrupt could occur, it would trash SRR0 and SRR1. In fact the code may be useful to set MSR[RI] that re-enables exception processing. BTW I will need to set other value in MSR to handle interrupts : a) I want the MSR[IR] and MSR[DR] to be set for performance reasons and also because I need DBAT support to have access to PCI memory space as the interrupt controller is in the PCI space. Reading the code, I see others have the same kind of request : /* SCE 980217 * * We need address translation ON when we call our ISR routine mtmsr r5 */ This is just another prof that even the lowest level IRQ code is fundamentally board dependent and not simply processor dependent especially when the processor use external interrupt controller because it has a single interrupt request line... Note that if you look at the PPC code high level interrupt handling code, as the "set_vector" routine that really connects the interrupt is in the BSP/startup/genpvec.c, the fact that IRQ handling is BSP specific is DE-FACTO acknowledged. I know I have already expressed this and understand that this would require some heavy change in the code but believe me you will reach a point where you will not be able to find a compatible while optimum implementation for low level interrupt handling code...) In my case this is already true... So please consider removing low level IRQ handling from exec/score/cpu/* and only let there exception handling code... Exceptions are usually only processor dependent and do not depend on external hardware mechanism to be masked or acknowledged or re-enabled (there are probably exception but ...) I have already done this for pc386 bsp but need to make it again. This time I will even propose an API. 3) R2/R13 manipulation for EABI implementation ---------------------------------------------- I do not understand the handling of r2 and r13 in the EABI case. The specification for r2 says pointer to sdata2, sbss2 section => constant. However I do not see -ffixed-r2 passed to any compilation system in make/custom/* (for info linux does this on PPC). So either this is a default compiler option when choosing powerpc-rtems and thus we do not need to do anything with this register as all the code is compiled with this compiler and linked together OR this register may be used by rtems code and then we do not need any special initialization or handling. The specification for r13 says pointer to the small data area. r13 argumentation is the same except that as far as I know the usage of the small data area requires specific compiler support so that access to variables is compiled via loading the LSB in a register and then using r13 to get full address... It is like a small memory model and it was present in IBM C compilers. => I propose to suppress any specific code for r2 and r13 in the EABI case. 4) Code layout organization (yes again :-)) ------------------------------------------- I think there are a number of design flaws in the way the code is for ppc organized and I will try to point them out. I have been beaten by this again on this new port, and was beaten last year while modifying code for pc386. a) exec/score/cpu/* vs lib/libcpu/cpu/*. I think that too many things are put in exec/score/cpu that have nothing to do with RTEMS internals but are rather related to CPU feature. This include at least : a) registers access routine (e.g GET_MSR_Value), b) interrupt masking/unmasking routines, c) cache_mngt_routine, d) mmu_mngt_routine, e) Routines to connect the raw_exception, raw_interrupt handler, b) lib/libcpu/cpu/powerpc/* With a processor family as exuberant as the powerpc family, and their well known subtle differences (604 vs 750) or unfortunately majors (8xx vs 60x) the directory structure is fine (except maybe the names that are not homogeneous) powerpc ppc421 mpc821 ... I only needed to add mpc750. But the fact that libcpu.a was not produced was a pain and the fact that this organization may duplicates code is also problematic. So, except if the support of automake provides a better solution I would like to propose something like this : powerpc mpc421 mpc821 ... mpc750 shared wrapup with the following rules : a) "shared" would act as a source container for sources that may be shared among processors. Needed files would be compiled inside the processor specific directory using the vpath Makefile mechanism. "shared" may also contain compilation code for routine that are really shared and not worth to inline... (did not found many things so far as registers access routine ARE WORTH INLINING)... In the case something is compiled there, it should create libcpushared.a b) layout under processor specific directory is free provided that 1)the result of the compilation process exports : libcpu/powerpc/"PROC"/*.h in $(PROJECT_INCLUDE)/libcpu 2) each processor specific directory creates a library called libcpuspecific.a Note that this organization enables to have a file that is nearly the same than in shared but that must differ because of processor differences... c) "wrapup" should create libcpu.a using libcpushared.a libcpuspecific.a and export it $(PROJECT_INCLUDE)/libcpu The only thing I have no ideal solution is the way to put shared definitions in "shared" and only processor specific definition in "proc". To give a concrete example, most MSR bit definition are shared among PPC processors and only some differs. if we create a single msr.h in shared it will have ifdef. If in msr.h we include libcpu/msr_c.h we will need to have it in each prowerpc specific directory (even empty). Opinions are welcomed ... Note that a similar mechanism exist in libbsp/i386 that also contains a shared directory that is used by several bsp like pc386 and i386ex and a similar wrapup mechanism... NB: I have done this for mpc750 and other processors could just use similar Makefiles... c) The exec/score/cpu/powerpc directory layout. I think the directory layout should be the same than the libcpu/powerpc. As it is not, there are a lot of ifdefs inside the code... And of course low level interrupt handling code should be removed... Besides that I do not understand why 1) things are compiled in the wrap directory, 2) some includes are moved to rtems/score, I think the "preinstall" mechanism enables to put everything in the current directory (or better in a per processor directory), 5) Interrupt handling API ------------------------- Again :-). But I think that using all the features the PIC offers is a MUST for RT system. I already explained in the prologue of this (long and probably boring) mail that the MCP750 boards offers an OPENPIC compliant architecture and that the VIA 82586 PCI/ISA bridge offers a PC compatible IO and PIC mapping. Here is a logical view of the RAVEN/VIA 82586 interrupt mapping : --------- 0 ------ | OPEN | <-----|8259| | PIC | | | 2 ------ |(RAVEN)| | | <-----|8259| | | | | | | 11 | | | | | | <---- | | | | | | | | | | | | --------- ------ | | ^ ------ | VIA PCI/ISA bridge | x -------- PCI interrupts OPENPIC offers interrupt priorities among PCI interrupts and interrupt selective masking. The 8259 offers the same kind of feature. With actual powerpc interrupt code : 1) there is no way to specify priorities among interrupts handler. This is REALLY a bad thing. For me it is as importnat as having priorities for threads... 2) for my implementation, each ISR should contain the code that acknowledge the RAVEN and 8259 cascade, modify interrupt mask on both chips, and reenable interrupt at processor level, ..., restore then on interrupt return,.... This code is actually similar to code located in some genpvec.c powerpc files, 3) I must update _ISR_Nesting_level because irq.inl use it... 4) the libchip code connects the ISR via set_vector but the libchip handler code does not contain any code to manipulate external interrupt controller hardware in order to acknoledge the interrupt or re-enable them (except for the target hardware of course) So this code is broken unless set_vector adds an additionnal prologue/epilogue before calling/returning from in order to acknoledge/mask the raven and the 8259 PICS... => Anyway already EACH BSP MUST REWRITE PART OF INTERRUPT HANDLING CODE TO CORRECTLY IMPLEMENT SET_VECTOR. I would rather offer an API similar to the one provided in libbsp/i386/shared/irq/irq.h so that : 1) Once the driver supplied methods is called the only things the ISR has to do is to worry about the external hardware that triggered the interrupt. Everything on openpic/VIA/processor would have been done by the low levels (same things as set-vector) 2) The caller will need to supply the on/off/isOn routine that are fundamental to correctly implements debuggers/performance monitoring is a portable way 3) A globally configurable interrupt priorities mechanism... I have nothing against providing a compatible set_vector just to make libchip happy but as I have already explained in other mails (months ago), I really think that the ISR connection should be handled by the BSP and that no code containing irq connection should exist the rtems generic layers... Thus I really dislike libchip on this aspect because in a long term it will force to adopt the less reach API for interrupt handling that exists (set_vector). Additional note : I think the _ISR_Is_in_progress() inline routine should be : 1) Put in a processor specific section, 2) Should not rely on a global variable, As : a) on symmetric MP, there is one interrupt level per CPU, b) On processor that have an ISP (e,g 68040), this variable is useless (MSR bit testing could be used) c) On PPC, instead of using the address of the variable via __CPU_IRQ_info.Nest_level a dedicated SPR could be used. NOTE: most of this is also true for _Thread_Dispatch_disable_level END NOTE -------- Please do not take what I said in the mail as a criticism for anyone who submitted ppc code. Any code present helped me a lot understanding PPC behavior. I just wanted by this mail to : 1) try to better understand the actual code, 2) propose concrete ways of enhancing current code by providing an alternative implementation for MCP750. I will make my best effort to try to brake nothing but this is actually hard due to the file layout organisation. 3) make understandable some changes I will probably make if joel let me do them :-) Any comments/objections are welcomed as usual. -- __ / ` Eric Valette /-- __ o _. Canon CRF (___, / (_(_(__ Rue de la touche lambert 35517 Cesson-Sevigne Cedex FRANCE Tel: +33 (0)2 99 87 68 91 Fax: +33 (0)2 99 84 11 30 E-mail: valette@crf.canon.fr
* Added local prototype of ioctl() to avoid requiring sys/ioctl.h.Joel Sherrill1999-06-113-3/+9
* Added comments.Joel Sherrill1999-06-111-1/+1
* Patch from Ian Lance Taylor <ian@airs.com>:Joel Sherrill1999-06-114-2/+64
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | The select function is not particularly efficient when dealing with a large number of sockets. The application has to build a big set of bits and pass it in. RTEMS has to look through all those bits and see what is ready. Then the application has to look through all the bits again. On the other hand, when using RTEMS, the select function is needed exactly when you have a large number of sockets, because that is when it becomes prohibitive to use a separate thread for each socket. I think it would make more sense for RTEMS to support callback functions which could be invoked when there is data available to read from a socket, or when there is space available to write to a socket. Accordingly, I implemented them. This patch adds two new SOL_SOCKET options to setsockopt and getsockopt: SO_SNDWAKEUP and SO_RCVWAKEUP. They take arguments of type struct sockwakeup: struct sockwakeup { void (*sw_pfn) __P((struct socket *, caddr_t)); caddr_t sw_arg; }; They are used to add or remove a function which will be called when something happens for the socket. Getting a callback doesn't imply that a read or write will succeed, but it does imply that it is worth trying. This adds functionality to RTEMS which is somewhat like interrupt driven socket I/O on Unix. After the patch to RTEMS, I have appended a patch to netdemos-19990407/select/test.c to test the new functionality and demonstrate one way it might be used. To run the new test instead of the select test, change doSocket to call echoServer2 instead of echoServer.
* Patch from Eric Norum <eric@cls.usask.ca> to fix bug reported byJoel Sherrill1999-06-111-0/+2
| | | | | | | | | | | | | | | | | | Ian Lance Taylor <ian@airs.com>: Ian Lance Taylor wrote: > > In rtems-19990528, sbwait sets SB_WAIT in sb_flags. sowakeup checks > it. Why doesn't socket_select set it? > > I don't know that this is a bug--I haven't tried to create a test > case. However, it certainly looks odd. > > Ian Yes, there's a bug there. Sorry about that. It was introduced when I did some cleanup on the sleep/wakeup handling in rtems_glue.c.
* Modified to return an error when a bogus return address for theJoel Sherrill1999-06-091-0/+3
| | | | old_priority parameter is provided.
* Switched to using strcasecmp() since it is more portable.Joel Sherrill1999-06-091-2/+2
| | | | D. V. Henkel-Wallace <gumby@zembu.com> spotted this one.
* Changes from Eric Norum to add a loop and limit on the length of timeJoel Sherrill1999-05-281-22/+32
| | | | the stack will wait for mbufs.
* Alignment corrected per Eric Norum's suggestion.Joel Sherrill1999-05-281-1/+2
* At the request of Gumby, the cpu is now halted rather than spinningJoel Sherrill1999-05-281-1/+1
| | | | on a fatal exception.
* Patch from Eric Norum <eric@pollux.usask.ca> to eliminate a panic when theJoel Sherrill1999-05-273-147/+88
| | | | network stack runs out of mbufs.
* Split out the routine rtems_assoc_name_bad().Joel Sherrill1999-05-272-14/+41
* Removed usage of printf.Joel Sherrill1999-05-272-2/+2
* Split initialization and reserve resources from termios to reduceJoel Sherrill1999-05-273-59/+93
| | | | size of mininum application.
* Corrected macro names.Joel Sherrill1999-05-271-2/+6
* Removed all post 4.0 changes.Joel Sherrill1999-05-201-81/+78
* Patch from Daniel Kelley <dank@icube.com>:Joel Sherrill1999-05-182-8/+8
| | | | | | I found a small buglet in the mips64orion _CPU_ISR_Set_level; the original was wiping out the level argument, and then comparing the current interrupt level with some random value of v0. See patch below.
* Fixed some typos.Joel Sherrill1999-05-171-4/+4
* Split Interrupt Manager into one routine per file.Joel Sherrill1999-05-172-36/+55
* Split Signal Manager into one routine per file.Joel Sherrill1999-05-173-108/+154
* Dual-Ported Memory Manager split into one routine per file.Joel Sherrill1999-05-176-236/+346
* Split Partition Manager into one routine per file.Joel Sherrill1999-05-176-299/+414
* Split Timer Manager into one routine per file.Joel Sherrill1999-05-178-308/+469
* Split Event Manager into one routine per file.Joel Sherrill1999-05-176-342/+456
* Split Rate Monotonic Manager into one routine per file.Joel Sherrill1999-05-178-416/+568
* Split the Semaphore Manager into one routine per file.Joel Sherrill1999-05-177-484/+766
* Moved some MP routines to semmp.c.Joel Sherrill1999-05-172-55/+54
* Forgot to actually remove the routines. :)Joel Sherrill1999-05-171-748/+0
* Split Message Manager into one routine per file.Joel Sherrill1999-05-1712-0/+1105
* Moved an MP routine from msg.c to here.Joel Sherrill1999-05-171-0/+26
* Cleaned up some multiprocessing issues.Joel Sherrill1999-05-171-17/+15
* Split Clock Manager into one routine per file.Joel Sherrill1999-05-174-129/+194
* Split Region Manager into one routine per file.Joel Sherrill1999-05-178-455/+618
* Splitting the Thread Handler forced the inclusion of more prototypes.Joel Sherrill1999-05-171-0/+33
* Split Task Manager into multiple files. Eventually this effort willJoel Sherrill1999-05-1715-961/+1381
| | | | reduce the size of executables.
* Thread Handler split into multiple files. Eventually, as RTEMS isJoel Sherrill1999-05-1725-1304/+1978
| | | | split into one function per file, this will decrease the size of executables.
* Patch from D. V. Henkel-Wallace <gumby@zembu.com> to remove compilerJoel Sherrill1999-05-173-4/+4
| | | | warnings.
* Patch from D. V. Henkel-Wallace <gumby@zembu.com>:Joel Sherrill1999-05-171-0/+16
| | | | | | Here's a tiny patch that shreds memory returned to the pool (such as by free() and delete). This may help people find some nasty bugs, so here it is.
* Removed check for initialized ID at request of Rosimildo DaSilvaJoel Sherrill1999-05-141-0/+23
| | | | | <rdasilva@connecttel.com> who encountered random failures in his port of omniORB2.
