* | score: Add _ISR_lock_Set_name() | Sebastian Huber | 2019-04-12 | 3 | -3/+38 |
| | | | | | Add _ISR_lock_Set_name() to optimize the initialization of zero-initialized locks. | ||||
* | score: Remove unused macros | Sebastian Huber | 2019-04-12 | 1 | -28/+0 |
* | score: Rename _SMP_Get_processor_count() | Sebastian Huber | 2019-04-11 | 9 | -35/+45 |
| | | | | | | | Rename _SMP_Get_processor_count() in _SMP_Get_processor_maximum() to be in line with the API level rtems_scheduler_get_processor_maximum(). Update #3732. | ||||
* | score: Rename _SMP_Processor_count | Sebastian Huber | 2019-04-11 | 2 | -4/+4 |
| | | | | | | | Rename _SMP_Processor_count in _SMP_Processor_maximum to be in line with the API level rtems_scheduler_get_processor_maximum(). Update #3732. | ||||
* | posix: Avoid fatal error in Shm object create | Sebastian Huber | 2019-04-10 | 1 | -1/+5 |
* | posix: Avoid workspace for queued signals | Sebastian Huber | 2019-04-10 | 4 | -18/+18 |
* | posix: _Configuration_POSIX_Minimum_stack_size | Sebastian Huber | 2019-04-10 | 3 | -3/+3 |
| | | | | Rename to use proper namespace. | ||||
* | posix: _Configuration_POSIX_Maximum_queued_signals | Sebastian Huber | 2019-04-10 | 4 | -4/+4 |
* | config: Obsolete Go configuration options | Sebastian Huber | 2019-04-10 | 1 | -46/+13 |
| | | | | Update #2832. | ||||
* | libdebugger: Fix for ARMv7-M with -O0 optimization | Chris Johns | 2019-04-09 | 2 | -5/+21 |
* | rtems: Add rtems_scheduler_get_processor_maximum() | Sebastian Huber | 2019-04-09 | 14 | -76/+48 |
| | | | | | | | | | | | Add rtems_scheduler_get_processor_maximum() as a replacement for rtems_get_processor_count(). The rtems_get_processor_count() is a bit orphaned. Adopt it by the Scheduler Manager. The count is also misleading, since the processor set may have gaps and the actual count of online processors may be less than the value returned by rtems_get_processor_count(). Update #3732. | ||||
* | rtems: Add rtems_scheduler_get_processor() | Sebastian Huber | 2019-04-09 | 6 | -25/+40 |
| | | | | | | | | | | | Add rtems_scheduler_get_processor() as a replacement for rtems_get_current_processor(). The rtems_get_current_processor() is a bit orphaned. Adopt it by the Scheduler Manager. This is in line with the glibc sched_getcpu() function. Deprecate rtems_get_current_processor(). Update #3731. | ||||
* | score: Add RTEMS_CONST | Sebastian Huber | 2019-04-09 | 1 | -0/+11 |
| | | | | Close #3734. | ||||
* | Remove superfluous run-time check | Sebastian Huber | 2019-04-09 | 2 | -11/+2 |
| | | | | | The _Objects_Information_table[ the_api ] is never NULL for a valid API index. | ||||
* | libdebugger: Use an offset table to format GDB `g` packets. | Chris Johns | 2019-04-09 | 8 | -215/+478 |
| | | | | | | | Adding support for a register offset table lets FPU registers be supported if added to the backend. Closes #3733. | ||||
* | doxygen: Update _Objects_Build_name() | Sebastian Huber | 2019-04-05 | 1 | -8/+6 |
| | | | | | | This is intended as an example in the RTEMS Software Engineering manual. Update #3704. | ||||
* | doxygen: Rename Score* groups in RTEMSScore* | Sebastian Huber | 2019-04-04 | 254 | -360/+360 |
| | | | | Update #3706 | ||||
* | doxygen: Split up "libmisc" subgroups and removed libmisc | Andreas Dachsberger | 2019-04-04 | 8 | -23/+13 |
| | | | | Update #3706. | ||||
* | doxygen: New API subgroup Tracing | Andreas Dachsberger | 2019-04-04 | 3 | -2/+10 |
* | doxygen: Added RTEMS Test Framework to API | Andreas Dachsberger | 2019-04-04 | 1 | -0/+2 |
* | doxygen: Added inttypes.h to Print Support | Andreas Dachsberger | 2019-04-04 | 1 | -0/+2 |
* | doxygen: Added subclasses to API | Andreas Dachsberger | 2019-04-04 | 4 | -0/+8 |
| | | | | | | | Update #3706. RTEMS Application Loader, RTEMS Runtime Link Editor, Status Checks and Test Support | ||||
* | doxygen: Zero and Null Device Drivers now in Device Drivers | Andreas Dachsberger | 2019-04-04 | 2 | -2/+2 |
* | doxygen: Print Support now in API->IO | Andreas Dachsberger | 2019-04-04 | 3 | -2/+18 |
* | doxygen: Mouse now in Device Drivers | Andreas Dachsberger | 2019-04-04 | 1 | -1/+1 |
* | doxygen: Time Test 27 now in Device Drivers | Andreas Dachsberger | 2019-04-04 | 2 | -2/+10 |
* | doxygen: Benchmark Timer Driver Interface now in Device Drivers | Andreas Dachsberger | 2019-04-04 | 2 | -0/+10 |
* | doxygen: Put Real-Timer Clock Driver Interface into group Device Drivers | Andreas Dachsberger | 2019-04-04 | 1 | -0/+2 |
* | doxygen: Put Print Support in IO | Andreas Dachsberger | 2019-04-04 | 1 | -0/+2 |
* | doxygen: Real Time Clock Time of Day API Definition in BSP->Shared | Andreas Dachsberger | 2019-04-04 | 1 | -1/+1 |
* | doxygen: Put SPI Driver into group Device Drivers | Andreas Dachsberger | 2019-04-04 | 1 | -0/+2 |
* | doxygen: Put C Library Support and POSIX in Internal | Andreas Dachsberger | 2019-04-04 | 2 | -0/+4 |
* | doxygen: Added some subgroups to API and IO | Andreas Dachsberger | 2019-04-04 | 3 | -6/+12 |
| | | | | | | I2C library, Media Manager and Profiling Support Update #3706. | ||||
* | doxygen: Added I2C Driver to Device Drivers | Andreas Dachsberger | 2019-04-04 | 1 | -0/+2 |
* | doxygen: Added Version to API->Classic | Andreas Dachsberger | 2019-04-04 | 4 | -3/+7 |
* | doxygen: Added Frame Buffer Device Driver Interface to Device Drivers | Andreas Dachsberger | 2019-04-04 | 1 | -1/+1 |
* | doxygen: Added some subgroups to IO Library | Andreas Dachsberger | 2019-04-04 | 3 | -0/+6 |
| | | | | | | Update #3706. Types and Mount, IO Internal, Kernel Print Support | ||||
* | doxygen: Removed XXX group | Andreas Dachsberger | 2019-04-04 | 1 | -1/+1 |
| | | | | | | Update #3706. Content was added to Classic Barrier Implementation | ||||
* | doxygen: Added Management to Example CPU Architecture | Andreas Dachsberger | 2019-04-04 | 1 | -0/+8 |
* | doxygen: Added libmisc group and libmisc mouse group | Andreas Dachsberger | 2019-04-04 | 2 | -3/+19 |
| | | | | | | | | Update #3706. @ingroup for these groups already existed, but no @defgroup Further restructuring necessary | ||||
* | doxygen: Added toplevel group for device drivers | Andreas Dachsberger | 2019-04-04 | 2 | -1/+10 |
* | doxygen: Added further groups to RTEMSAPI | Andreas Dachsberger | 2019-04-04 | 2 | -11/+20 |
| | | | | | | | Update #3706. Associativity Routines, BSD Compatibility Support now part of RTEMSAPI | ||||
* | doxygen: Added Mainpage to RTEMSAPIClassic | Andreas Dachsberger | 2019-04-04 | 1 | -1/+1 |
* | doxygen: User Extensions Implementation group now in Internal->Classic | Andreas Dachsberger | 2019-04-04 | 1 | -1/+1 |
* | doxygen: Rework some Doxygen comments | Sebastian Huber | 2019-04-04 | 3 | -44/+51 |
| | | | | | | They are intended as examples in the RTEMS Software Engineering manual. Update #3704. | ||||
* | doxygen: score: Added ScoreRWLock to Score group | Andreas Dachsberger | 2019-04-02 | 1 | -5/+9 |
* | doxygen: Added groups to IO library | Andreas Dachsberger | 2019-04-02 | 4 | -3/+19 |
* | doxygen: score: Put ARM Co-Processor 15 group in ARM | Andreas Dachsberger | 2019-04-02 | 1 | -3/+3 |
* | doxygen: Restructured cpukit/include/rtems/rtems | Andreas Dachsberger | 2019-04-02 | 55 | -75/+90 |
* | doxygen: Reviewed cpukit/include/rtems/posix | Andreas Dachsberger | 2019-04-02 | 1 | -2/+2 |
| | | | | Update #3706. |
