* posix/src/pthread.c: Make default pthread_attr_t match the
conditionals in the version in newlib. This way it will always be
right.
* libcsupport/src/readv.c: Check for < 0 on iov_len, not <= 0. A
readv() with all iov_len equal to 0 should have no effect.
* rtems/score/cpu.h: Remove warning in _CPU_Context_Initialize.
* cpu_asm.S: L0-L3 were part of the interrupt context, but as
Mike Frysinger noted they were not being zeroed before calling
the C handlers. A patch that corrects this, as well as improving
some of the push/pop order to avoid stalls.
which included commits to RCS files with non-trunk default branches.
* cpu.c, cpu_asm.S, rtems/score/cpu.h: Fine tune registers saved in the
context. The sp and imask registers need to be saved. Also allocated
12 bytes on the stack at thread entry as the abi requires that.
* cpu.c: Blackfin ABI requires L registers to be 0 upon function entry.
* rtems/score/cpu.h: Make _gp global.
* libnetworking/sys/mbuf.h: Use uintptr_t instead of u_long
for 16bit target compliance.
* libnetworking/libc/gethostbydns.c: Use uintptr_t instead of u_long
* libnetworking/sys/sysctl.h: Change sysctl_oid->arg2 into int32_t
* libmisc/shell/fts.c (fts_pow2): Rebase fts_pow2 on
SIZEOF_SIZE_T * CHAR_BIT.
* aclocal/gcc-sanity.m4: Add RTEMS_CHECK_GCC_PRINTF_LD_OFF_T,
RTEMS_CHECK_GCC_PRINTF_LLD_OFF_T.
* shttpd/io_dir.c: Cast consts to size_t (Avoid overflows on implicit
const casts on 16bit targets).
* score/include/rtems/system.h: Let RTEMS_offsetof return uintptr_t
instead of uint32_t (16bit target compatibility).
* libmisc/monitor/mon-part.c, libmisc/monitor/mon-region.c:
Use rtems_monitor_dump_addr instead of rtems_monitor_dump_hex
to print addresses.
to print addresses.
* libmisc/monitor/mon-prmisc.c, libmisc/monitor/monitor.h:
Add rtems_monitor_dump_addr().
* libmisc/monitor/mon-symbols.c: 16bit target fixes.
* libnetworking/lib/ftpfs.c: 16bit target fixes:
Use ioctl_command_t as arg to rtems_ftpfs_do_ioctl.
Explicitly cast to uint32_t in char[] to uint32_t
conversion.
* configure.ac: Check for sched.h.
* configure.ac: Check for WORD_BIT, LONG_BIT.
* configure.ac: Check for flockfile, funlockfile, ftrylockfile.
libfs/src/rfs/rtems-rfs-buffer-bdbuf.c,
libfs/src/rfs/rtems-rfs-buffer.c, libfs/src/rfs/rtems-rfs-data.h,
libfs/src/rfs/rtems-rfs-dir.c,
libfs/src/rfs/rtems-rfs-file-system.c,
libfs/src/rfs/rtems-rfs-format.c, libfs/src/rfs/rtems-rfs-inode.h,
libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs-rtems.h,
libfs/src/rfs/rtems-rfs-shell.c: Fix for PR1502. Clean up problems
on 16bit targets.
* libmisc/stackchk/check.c: Remove bogus casts.
Use PRIxPTR to printk pointers.
Obtain/release disk during open/close
* cpu_asm.S, rtems/score/cpu.h: On uC5282, the thread restart needed to
reload the frame pointer. As part of doing this, the code was moved
from inline asm to the .S file.
* score/src/wkspace.c: Remove duplicate include.
* libmisc/monitor/mon-monitor.c, libmisc/monitor/monitor.h: Add const
to fix warning. Spacing.
* score/include/rtems/system.h: Fix warnings about TRUE/FALSE not
defined on ARM target. This file need to be clean from .S files.
* arm_exc_abort.S: Fix warnings about TRUE/FALSE not defined.
* libmisc/monitor/mon-monitor.c, libmisc/monitor/monitor.h: Add reset
command.
* libnetworking/lib/rtems_bspnet_ntp.c: #include <unistd.h>.
* posix/include/sched.h: Remove.
* posix/Makefile.am: Remove include/sched.h.
* posix/src/psxtransschedparam.c, posix/src/pthread.c,
posix/src/pthreadcreate.c: Reflect POSIX sched_parm changes.
