Return early only if there was a timeout, otherwise return the PPS info.
Update #2349.
Close #2349.
Update #2349.
Update #2349.
Update #2349.
Update #2349.
Update #2349.
Rename tc_getfrequency() to _Timecounter_Get_frequency().
Update #2349.
Update #2349.
Update #2349.
Update #2349.
Update #2349.
Remove URL in copyright notice.
Update #3053.
Change license to BSD-2-Clause according to file history.
Update #3053.
Use the copyright notice of the associated header file from FreeBSD if the
kernel space header file contains a substantial amount of imported code.
Synchronize all file descriptors and not just the ones associated with a FILE
object.
Close #4656.
This file had no header, copyright, or license. Based on git history,
added appropriate copyright and license.
These files had no header, copyright, or license. Based on git history,
added appropriate copyrights and licenses.
These files had no header, copyright, or licenses. Based on git history,
These files had no file header, copyright, or license. Based on git
history, added appropriate copyright and license.
This file had no file header, copyright, or license. Based on git
Close #4644.
These files had no file header, copyright, or license. Chris identified
that these were made by him.
Updates #4521
The other ports included that architecture's version of this file from
NetBSD. This patch follows that pattern.
closes #4641
Currently the following sequence causes a endless loop when extending an
IMFS file:
- Create a file with zero length and close it.
- Make sure nearly no allocatable memory is left.
- Open the file and write enough data into it that more than the
remaining memory will be used.
In that case when extending the IMFS file, the file currently need zero
blocks. If allocating enough new blocks fails, the already allocated new
blocks will be freed again.
The comparison of block>=old_blocks that has been used prior to this
patch compared two unsigned numbers. If old_blocks was zero, the
comparison of these two numbers always evaluated to true.
This patch frees the last block in a separate step to avoid this
problem.
Fixes #4639
In contrast to rtems_shell_main_loop(), this new function does not
perform all sorts of initialization based on environment settings. For
example, due to the use of isatty() in rtems_shell_main_loop() it is
impossible to run an interactive shell through a socket connection.
Move rtems_shell_init_environment() call to rtems_shell_set_shell_env()
since this function uses the POSIX key.
Do not assign members already provided by the global environment.
Disentangle the shell main loop from setup and teardown code. Move main
loop into shell_main_loop().
Move call to isatty() to caller of rtems_shell_line_editor(). This
avoids a dependency on isatty() in rtems_shell_line_editor().
- A larger block size lets files systems work better. On JFFS
a 512 byte compressed block means lots of small flash updates
Closes #4635
