* | Update email address of Fernando Ruiz Casas to <fruizcasas@gmail.com> | Joel Sherrill | 2022-04-05 | 43 | -202/+260 | |
| | | | | This was requested to be executed prior to relicensing to BSD-2. | |||||
* | cpukit/libmisc/dumpbuf/dumpbuf.c: Manually change license to BSD-2 | Joel Sherrill | 2022-04-02 | 1 | -3/+20 | |
| | | | | | | | There was a typo in the license text and this file was missed by the script. Updates #3053 | |||||
* | cpukit/include; Remove SPDX from Gaisler files NOT changed to BSD-2 | Joel Sherrill | 2022-04-02 | 12 | -24/+0 | |
* | cpukit/libcsupport/src/_*: Change license to BSD-2 | Joel Sherrill | 2022-04-01 | 8 | -24/+176 | |
| | | | | Updates #3053. | |||||
* | cpukit/libcsupport/src/[g-r]*: Change license to BSD-2 | Joel Sherrill | 2022-04-01 | 51 | -157/+1132 | |
* | cpukit/libcsupport/src/[s-z]*: Change license to BSD-2 | Joel Sherrill | 2022-04-01 | 40 | -127/+893 | |
* | cpukit/libcsupport/src/[a-f]*: Change license to BSD-2 | Joel Sherrill | 2022-04-01 | 38 | -117/+841 | |
* | cpukit/include/rtems/timespec.h: Change license to BSD-2 | Joel Sherrill | 2022-04-01 | 1 | -3/+22 | |
| | | | | | | Permission received from Krzysztof Miesowicz. Updates #3053. | |||||
* | cpukit/include/rtems/cbs.h: Change license to BSD-2 | Joel Sherrill | 2022-04-01 | 1 | -3/+22 | |
| | | | | | | Permission received from Petr Benes Updates #3053. | |||||
* | cpukit/score/cpu/moxie: Change license to BSD-2 | Joel Sherrill | 2022-04-01 | 8 | -24/+176 | |
| | | | | | | Permission received from Anthony Green. Updates #3053. | |||||
* | libcsupport: Use _fwalk_reent() | Sebastian Huber | 2022-04-01 | 1 | -19/+10 | |
| | | | | | Use _fwalk_reent() instead of _fwalk(), since _fwalk() was removed from Newlib. Include <sys/reent.h> and remove local declarations. | |||||
* | rtems: Clarify scheduler of created task | Sebastian Huber | 2022-03-29 | 1 | -3/+3 | |
* | cpukit/include/rtems/confdefs/libpci.h: Manual file header clean up | Joel Sherrill | 2022-03-25 | 1 | -8/+8 | |
* | cpukit/include/pci: Manual header file clean up | Joel Sherrill | 2022-03-25 | 7 | -9/+61 | |
* | cpukit/include/drvmgr: Manual header file clean up | Joel Sherrill | 2022-03-25 | 4 | -7/+35 | |
* | cpukit/include/pci.h: Manual header clean up | Joel Sherrill | 2022-03-25 | 1 | -2/+11 | |
* | cpukit/include/*.h: Change license to BSD-2 | Joel Sherrill | 2022-03-25 | 2 | -6/+44 | |
* | cpukit/include/sys: Change license to BSD-2. | Joel Sherrill | 2022-03-25 | 31 | -97/+686 | |
* | cpukit/include/rtems: Change license to BSD-2 | Joel Sherrill | 2022-03-25 | 73 | -219/+1606 | |
* | cpukit/include/linux: Change license to BSD-2 | Joel Sherrill | 2022-03-25 | 4 | -12/+88 | |
* | cpukit/include/dev: Change license to BSD-2 | Joel Sherrill | 2022-03-25 | 12 | -36/+264 | |
* | cpukit/libmisc/monitor/: Manually change to BSD-2 license | Joel Sherrill | 2022-03-24 | 19 | -50/+562 | |
| | | | | | | | | | | | | | | This code did not have any copyrights or licenses and a bit of archeology was needed to determine authorship. This code was in the initial import into the RTEMS CVS repository when it was established in May 1995. There was very little, if any, code not written by OAR Corporation in that initial import. After discussion with Chris Johns, it was determined that this code was from OAR Corporation and that he had added a few features later. Both Chris Johns and OAR Corporation have given permission to relicense. Updates #3053. | |||||
* | cpukit/: Update Eric Norum contact info and normalize file headers | Joel Sherrill | 2022-03-24 | 9 | -51/+66 | |
* | smp: Add fatal error | Sebastian Huber | 2022-03-24 | 2 | -1/+7 | |
| | | | | | | | Add SMP-specifc SMP_FATAL_MULTITASKING_START_ON_NOT_ONLINE_PROCESSOR fatal error. This fatal error helps to diagnose a broken SMP startup sequence. Without this error a context switch using the NULL pointer for the thread control block happens which may be difficult to debug. | |||||
* | libtest: Increase line length | Sebastian Huber | 2022-03-24 | 1 | -1/+1 | |
| | | | | Update #3716. | |||||
* | libtest: Add scheduler test support | Sebastian Huber | 2022-03-24 | 2 | -0/+948 | |
| | | | | | | | | | Add support to record scheduler operations. This support is especially important for tests in SMP configurations since the thread switch extension is quite difficult to use due to the asynchronous nature of thread dispatching. In contrast, the scheduler operations occur normally in a deterministic order. Update #3716. | |||||
* | score: Add _IO_Relax() | Sebastian Huber | 2022-03-24 | 2 | -0/+61 | |
| | | | | | | | This function may be used to burn a couple of processor cycles with minimum impact on the system bus. It may be used in busy wait loops. Since it is a global function, it is possible to wrap it in device driver test code. | |||||
* | cpukit/libmisc/untar: Change license to BSD-2 | Joel Sherrill | 2022-03-22 | 3 | -9/+66 | |
* | cpukit/libmisc/check: Change license to BSD-2 | Joel Sherrill | 2022-03-22 | 1 | -3/+22 | |
* | cpukit/libmisc/serdbg: Change license to BSD-2 | Joel Sherrill | 2022-03-22 | 3 | -9/+66 | |
* | cpukit/libmisc/rtems-fdt: Change license to BSD-2 | Joel Sherrill | 2022-03-22 | 2 | -6/+44 | |
* | cpukit/libmisc/redirector: Manually change license to BSD-2 | Joel Sherrill | 2022-03-22 | 1 | -7/+27 | |
* | cpukit/libmisc/mouse: Change license to BSD-2 | Joel Sherrill | 2022-03-22 | 1 | -3/+22 | |
* | cpukit/libmisc/fsmount/fsmount.c: Manual header clean up | Joel Sherrill | 2022-03-22 | 1 | -3/+1 | |
* | cpukit/libmisc/fsmount: Change license to BSD-2. | Joel Sherrill | 2022-03-22 | 1 | -3/+22 | |
* | cpukit/libmisc/dumpbuf: Change license to BSD-2 | Joel Sherrill | 2022-03-22 | 1 | -0/+2 | |
* | cpukit/libmisc/dummy: Change license to BSD-2. | Joel Sherrill | 2022-03-22 | 1 | -3/+22 | |
* | cpukit/libmisc/devnull/devzero.c: Change license to BSD-2 | Joel Sherrill | 2022-03-22 | 1 | -3/+22 | |
* | cpukit/libmisc/cpuuse: Change license to BSD-2 | Joel Sherrill | 2022-03-22 | 6 | -18/+132 | |
* | cpukit/libmisc/capture: Manually change license to BSD-2 | Joel Sherrill | 2022-03-22 | 7 | -112/+212 | |
| | | | | | | | These files did not follow the standard format and needed to be changed manually. Updates #3053. | |||||
* | cpukit/capture: Change license to BSD-2 | Joel Sherrill | 2022-03-22 | 2 | -6/+44 | |
* | cpukit/libmisc/bspcmdline: Change license to BSD-2 | Joel Sherrill | 2022-03-22 | 4 | -12/+88 | |
* | cpukit/libtest: Change license to BSD-2 | Joel Sherrill | 2022-03-22 | 5 | -15/+110 | |
* | cpukit/libpci: Change license to BSD-2 | Joel Sherrill | 2022-03-22 | 22 | -66/+484 | |
* | cpukit/libgnat: Change license to BSD-2. | Joel Sherrill | 2022-03-22 | 1 | -3/+22 | |
* | cpukit/libfs/src/rfs: Change license to BSD-2 | Joel Sherrill | 2022-03-22 | 21 | -63/+462 | |
* | cpukit/libds/src/ftpfs/tftpDriver.c: Manually update license to BSD-2 | Joel Sherrill | 2022-03-22 | 1 | -8/+30 | |
| | | | | | | | Eric Norum granted permission plus git log archeology to get year for his copyright. Updates #3053. | |||||
* | cpukit/libfs/src/imfs: Change license to BSD-2 | Joel Sherrill | 2022-03-22 | 28 | -84/+616 | |
* | cpukit/libdl: Manual file header reordering (SPDX, Doxygen, Copyright) | Joel Sherrill | 2022-03-22 | 35 | -300/+335 | |
* | cpukit/libfs/src/defaults: Change license to BSD-2 | Joel Sherrill | 2022-03-22 | 37 | -111/+814 | |
| | | | | Updates #3053. |
