* | 2005-08-17 Nickolay Semyonov <snob@oktetlabs.ru> | Joel Sherrill | 2005-08-17 | 3 | -3/+11 |
| | | | | | | | | PR 744/filesystem * libcsupport/src/unlink.c, libfs/src/dosfs/msdos_eval.c: DOSFS did not support permissions on directories so the check performed by unlink would always fail. The unlink code was modified to support a not supported status being returned. | ||||
* | 2005-08-15 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-15 | 1 | -0/+2 |
| | | | | | * posix/include/mqueue.h, posix/src/mqueuetimedreceive.c: ssize_t mq_timedreceive() (POSIX compliance). | ||||
* | ssize_t mq_timedreceive() (POSIX compliance) | Ralf Corsepius | 2005-08-15 | 2 | -2/+2 |
* | Regenerate. | Ralf Corsepius | 2005-08-15 | 1 | -0/+8 |
* | 2005-08-15 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-15 | 2 | -2/+7 |
| | | | | * wrapup/Makefile.am: Use librtemscpu_a_LIBRARIES. | ||||
* | 2005-08-12 Chris Johns <chrisj@rtems.org> | Joel Sherrill | 2005-08-12 | 2 | -4/+8 |
| | | | | | | PR 808/rtems_misc * libcsupport/src/printk.c: Fix bug where specifying field width crashed on pc386 BSP. | ||||
* | 2005-08-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-06 | 2 | -2/+5 |
| | | | | | * libnetworking/nfs/bootp_subr.c: Don't include nfs/nfs.h, nfs/krpc.h. | ||||
* | 2005-08-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-05 | 1 | -0/+9 |
| | | | | | | | | | * libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_eval.c, libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_free.c, libfs/src/dosfs/msdos_fsunmount.c, libfs/src/dosfs/msdos_init.c, libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c: Introduce msdos_status_t (dosfs statii are at least 32bit, not int). | ||||
* | Introduce msdos_status_t. | Ralf Corsepius | 2005-08-05 | 9 | -32/+34 |
* | Regenerate. | Ralf Corsepius | 2005-08-05 | 2 | -4/+8 |
* | 2005-08-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-05 | 3 | -490/+40 |
| | | | | | * Makefile.am: Add libnetworking/memory.h * libnetworking/Makefile.am: Remove memory.h | ||||
* | 2005-08-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-02 | 2 | -1/+8 |
| | | | | | | | PR 817/rtems * libcsupport/src/gxx_wrappers.c: Rename rtems_gxx_recursive_mutex_init_function to rtems_gxx_recursive_mutex_init. | ||||
* | 2005-08-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-01 | 1 | -0/+4 |
| | | | | * libnetworking/sys/syslog.h: Partial update from FreeBSD. | ||||
* | Partial update from FreeBSD. | Ralf Corsepius | 2005-08-01 | 1 | -16/+15 |
* | This commit was generated by cvs2svn to compensate for changes in r12147, | Ralf Corsepius | 2005-07-18 | 2 | -0/+234 |
|\ | | | | | which included commits to RCS files with non-trunk default branches. | ||||
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2005-07-18 | 2 | -0/+234 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2005-02-06 | 1 | -0/+10 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2005-02-06 | 1 | -0/+2 |
* | | Pass along errno from failed ftruncate(). | Eric Norum | 2005-07-13 | 2 | -0/+5 |
* | | Add PR. | Joel Sherrill | 2005-07-06 | 1 | -0/+1 |
* | | 2005-07-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-07-06 | 2 | -4/+7 |
| | | | | | | | | | | | | * libnetworking/lib/syslog.c: Fix spelling mistake. * libnetworking/sys/uio.h: Partial update from FreeBSD. * libnetworking/kern/kern_subr.c: Reflect changes above. | ||||
* | | Fix spelling mistake. | Ralf Corsepius | 2005-07-06 | 1 | -1/+1 |
* | | Partial update from FreeBSD. | Ralf Corsepius | 2005-07-06 | 1 | -13/+20 |
* | | 2005-07-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-07-05 | 2 | -1/+11 |
| | | | | | | | | * libblock/include/rtems/ide_part_table.h: Add C++ guards. | ||||
* | | The DHCP header. | Chris Johns | 2005-06-30 | 1 | -0/+47 |
* | | DHCP server for RTEMS. | Chris Johns | 2005-06-30 | 1 | -0/+1133 |
* | | 2005-06-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-06-17 | 2 | -1/+7 |
| | | | | | | | | | | * libnetworking/net/if.h: Avoid use of struct mbuf to avoid unintended dependencies added by the RTEMS specific tap interface. | ||||
* | | 2005-06-09 Jacques Seronie Vivien <jacques.seronievivien@astrium.eads.net> | Joel Sherrill | 2005-06-09 | 3 | -2/+13 |
| | | | | | | | | | | | | | | PR 790/rtems * sapi/src/extensioncreate.c, sapi/src/extensionident.c: Correct use of name. This was missed when the other ident services in rtems/src where changed. | ||||
* | | 2005-06-07 Brett Swimley <brett.swimley@aedbozeman.com> | Joel Sherrill | 2005-06-07 | 3 | -6/+11 |
| | | | | | | | | | | PR 803/patch * rtems/score/cpu.h, rtems/score/m68k.h: Correct definition of _VBR. | ||||
* | | Regenerate. | Ralf Corsepius | 2005-06-01 | 2 | -0/+13 |
* | | 2005-05-27 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-27 | 1 | -0/+3 |
| | | | | | | | | | | | | * libnetworking/net/if.h: Partial update from FreeBSD. * libnetworking/netinet/if_ether.h: Remove BYTE_PACK. * libnetworking/netinet/ip_var.h: Remove BYTE_PACK. | ||||
* | | Partial update from FreeBSD. | Ralf Corsepius | 2005-05-27 | 1 | -2/+3 |
* | | Remove BYTE_PACK. | Ralf Corsepius | 2005-05-27 | 2 | -14/+8 |
* | | 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-27 | 2 | -1/+5 |
| | | | | | | | | * librpc/include/rpc/clnt.h: Partial update from FreeBSD. | ||||
* | | 2005-05-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-05-27 | 6 | -4/+13 |
| | | | | | | | | | | | | * libnetworking/lib/ftpfs.c, librpc/include/rpc/svc.h, librpc/src/rpc/get_myaddress.c, librpc/src/rpc/pmap_getmaps.c, librpc/src/rpc/pmap_getport.c: Remove warnings. | ||||
* | | 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-25 | 1 | -0/+6 |
| | | | | | | | | | | | | * librpc/include/rpc/clnt.h, librpc/include/rpc/svc.h, src/rpc/pmap_rmt.c: Use void* instead of caddr_t. Cosmetics from FreeBSD. | ||||
* | | Use void* instead of caddr_t. Cosmetics from FreeBSD. | Ralf Corsepius | 2005-05-25 | 3 | -31/+49 |
* | | Regenerate. | Ralf Corsepius | 2005-05-25 | 1 | -4/+0 |
* | | 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-25 | 1 | -2/+7 |
| | | | | | | | | | | | | * librpc/include/rpc/auth_des.h: Remove (Unused, unsupported). * librpc/include/rpc/rpc.h, librpc/Makefile.am: Reflect removing auth_des.h. | ||||
* | | Reflect removing auth_des.h. | Ralf Corsepius | 2005-05-25 | 2 | -7/+1 |
* | | Remove (Unused, unsupported). | Ralf Corsepius | 2005-05-25 | 1 | -109/+0 |
* | | 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-25 | 1 | -0/+2 |
| | | | | | | | | | | * include/rpc/rpc_com.h, include/rpc/rpc_msg.h, src/rpc/svc_simple.c: Minor fixes. | ||||
* | | Misc. fixes. | Ralf Corsepius | 2005-05-25 | 3 | -37/+31 |
* | | More updates from FreeBSD. | Ralf Corsepius | 2005-05-25 | 4 | -57/+17 |
* | | 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-25 | 1 | -0/+5 |
| | | | | | | | | | | * librpc/include/rpc/clnt.h, librpc/include/rpc/clnt_soc.h, src/rpc/clnt_perror.c: More updates from FreeBSD. | ||||
* | | More updates from FreeBSD. | Ralf Corsepius | 2005-05-25 | 3 | -126/+45 |
* | | 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-25 | 2 | -54/+19 |
| | | | | | | | | * librpc/include/rpc/svc.h: Partial update from FreeBSD. | ||||
* | | 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-25 | 2 | -14/+21 |
* | | Regenerate. | Ralf Corsepius | 2005-05-25 | 1 | -16/+24 |
* | | 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-25 | 2 | -6/+17 |
| | | | | | | | | | | | | * librpc/include/rpc/clnt_soc.h, librpc/include/rpc/svc_soc.h: New (Partial update from FreeBSD). * librpc/Makefile.am: Reflect changes above. |
