closes #2384
Fixes link failure when linking Ada programs on the raspberry pi
This mutex implementation uses a thread priority queue with a simple
priority inheritance mechanism (similar to the object based mutexes).
The storage space must be supplied by the user (16 bytes on 32-bit
targets).
This enables external libraries to use thread locks since they are
independent of the actual RTEMS build configuration, e.g. profiling
enabled or disabled.
These SMP lock statistics are used for all lock objects that lack a
storage space for the statistics. Examples are lock objects used in
external libraries which are independent of the actual RTEMS build
configuration.
Use a leading underscore in the structure name to allow forward
declarations in standard header files provided by Newlib and GCC.
Add a leading underscore to the structure name to allow forward
closes #2376.
Rename _POSIX_Absolute_timeout_to_ticks() to
_TOD_Absolute_timeout_to_ticks() and move it to the score directory.
Delete empty <rtems/posix/time.h>.
This avoids the "0x0xabc" output and is more compact.
This makes it possible to use _Thread_queue_Extract_locked() for barrier
operations which extract all threads on the queue in one critical
section.
Move the storage for the thread queue heads to the threads. Each thread
provides a set of thread queue heads allocated from a dedicated memory
pool. In case a thread blocks on a queue, then it lends its heads to
the queue. In case the thread unblocks, then it takes a free set of
threads from the queue. Since a thread can block on at most one queue
this works. This mechanism is used in FreeBSD. The motivation for this
change is to reduce the memory demands of the synchronization objects.
On a 32-bit uni-processor configuration the Thread_queue_Control size is
now 8 bytes, compared to 64 bytes in RTEMS 4.10 (other changes reduced
the size as well).
Separate the thread queue heads and lock from the operations. This
enables the support for light weight objects which only support one
queuing discipline.
The e500v1 has no support for the ATB.
Update #2369.
The mftb is not available on Book E processors. Use SPR 268 instead.
Close #2369.
Disable an optimization which would lead to a recursive calloc() call in
calloc().
This allows a suitably configured DHCP server with DDNS to enter
the name into the DNS table making it addressiable via it's host name.
Exploit the fact that the current thread lock must be the default thread
lock and interrupts are disabled if we call _Thread_Lock_set().
Add a SMP lock statistics pointer to SMP_lock_Stats_context and drop the
SMP lock statistics parameter from _SMP_ticket_lock_Release().
With this a _Freechain_Put( _Freechain_Get() ) works always.
Replace the extend function with an allocator since this fits better
to the current use case.
The problem is that empty structures have a different size in C and C++.
Drop the <rtems/score/percpu.h> include since this file exposes a lot of
implementation details.
Avoid Thread_Control typedef in <rtems/score/percpu.h>. This helps to
get rid of the <rtems/score/percpu.h> include in <rtems/score/thread.h>
which exposes a lot of implementation details.
Add rtems_interrupt_local_disable|enable() as suggested by Pavel Pisa to
emphasize that interrupts are only disabled on the current processor.
Do not define the rtems_interrupt_disable|enable|flash() macros and
functions on SMP configurations since they don't ensure system wide
mutual exclusion.
