* libnetworking/netinet/in_cksum.c: Add missing prototypes.
* librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/svc_tcp.c:
* rtems/score/cpu.h, rtems/score/i386.h: Add missing prototypes.
* libfs/src/nfsclient/src/librtemsNfs.h: Add missing prototype.
* aclocal/prog-cc.m4: Add -Wimplicit-function-declaration
-Wstrict-prototypes to RTEMS_CFLAGS.
* ChangeLog: Add correct entry.
PR 1297/cpukit
* posix/src/prwlockinit.c: Fix NULL attribute pointer handling.
* rtems/include/rtems/rtems/ratemon.h,
rtems/include/rtems/rtems/status.h,
score/include/rtems/score/object.h: Removed extraneous commas.
* rtems/powerpc/registers.h: Removed obsolete defines MSR_, MSR_KERNEL
and MSR_USER. Added missing prototypes.
* rtems/include/rtems/rtems/msgmp.h: Fix MP code missed by Sebastian.
* libmisc/monitor/monitor.h, rtems/include/rtems/rtems/tasks.h,
score/include/rtems/score/thread.h, score/src/threadreset.c,
score/src/threadrestart.c, score/src/threadstart.c: New type
Thread_Entry_numeric_type for numeric arguments in thread entry
functions with at least one numeric argument.
* score/include/rtems/score/sysstate.h,
score/inline/rtems/score/sysstate.inl, score/src/thread.c: Make
_System_state_Is_multiprocessing unused when multiprocessing is not
enabled. Saves one more variable from single processor configuration.
* libcsupport/src/_rename_r.c: Fixed return code bug. Add a check
to see if the 'to' path was a directory and removed the directory.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Added the mv command.
* libmisc/shell/main_mv.c, libmisc/shell/pathnames-mv.h: New.
* libblock/src/bdbuf.c: PR1272. Fixed similar possible issues in
the new bdbuf code.
* libblock/src/diskdevs.c: PR1192. Update the disktap pointer
after the realloc.
* libblock/src/diskdevs.c: PR1269. Delete the semaphore rather
than release it.
PR 537/bsps
* libcsupport/include/rtems/libcsupport.h, libcsupport/src/newlibc.c,
libcsupport/src/no_libc.c, libcsupport/src/unixlibc.c: Eliminate
vestiges of ticks_per_timeslice controlling newlib reentrancy. The
parameter was ignored in libc_init().
PR 741/networking
* libmisc/dummy/dummy.c: Add dummy network configuration.
* rtems/include/rtems/rtems/sem.h, rtems/src/semobtain.c:
Changed option set type to rtems_option.
* score/src/objectgetinfo.c: Check return value of
_Objects_API_maximum_class().
* libmisc/monitor/mon-mpci.c, libmisc/monitor/monitor.h,
rtems/include/rtems/rtems/message.h, rtems/src/msgmp.c,
rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c,
rtems/src/msgqcreate.c, rtems/src/msgqreceive.c, rtems/src/msgqsend.c,
rtems/src/msgqurgent.c, score/include/rtems/score/coremsg.h,
score/include/rtems/score/mpci.h, score/include/rtems/score/thread.h,
score/inline/rtems/score/coremsg.inl, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsgseize.c,
score/src/coremsgsubmit.c:
Removed parameters of _Message_queue_Allocate(). Changed option set
type to rtems_option. Changed type of maximum message and packet size
to size_t. Changed the input buffer type for message send functions to
"const void *". Changed the pointer to the second return argument in
the thread wait information to a union. This union can contain a
pointer to an immutable or a mutable object. This is somewhat fragile.
An alternative would be to add a third pointer for immutable objects,
but this would increase the structure size.
* rtems/new-exceptions/cpu.h: Changed define
CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER to UINT32_MAX to avoid comparison
between signed and unsigned.
PR 1212/cpukit
* rtems/src/taskmode.c, score/src/threadtickletimeslice.c: Time slicing
will not happen if the task mode is changed from a non-timeslicing
mode to timeslicing mode if it is done by the executing thread (e.g.
in its task body). This change includes sp44 to demonstrate the
problem and verify the correction.
* posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c: Fix
warnings.
PR 1294/bsps
* rtems/score/cpu.h, rtems/score/sparc.h: Correct prototype and usage
of sparc_disable_interrupts.
* rtems/score/cpu.h: Spacing.
PR 1265/cpukit
* score/include/rtems/score/object.h,
score/src/objectallocatebyindex.c: Rename index argument to avoid
warning when rtems.h and string.h are included at the same time by
user code.
* libnetworking/lib/tftpDriver.c: Add prototypes.
* pppd/rtemsmain.c: Add prototypes.
* zlib/crc32.c: Add prototypes.
* telnetd/telnetd.c: Add missing prototypes.
Remove unused local declations.
* libblock/include/rtems/blkdev.h: Remove count and start from
rtems_blkdev_request. Add RTEMS_BLKDEV_START_BLOCK macro.
* libblock/src/bdbuf.c: Add read ahead blocks always consecutive
comment. Change count to bufnum and remove start references. Sort
the transfer list so blocks are consecutive where possible.
* libblock/src/blkdev.c, libblock/src/nvdisk.c,
libblock/src/ramdisk.c: Change count to bufnum and remove start
references.
* libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c,
libnetworking/libc/gethostbynis.c,
libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetbydns.c,
libnetworking/libc/getnetbynis.c,
libnetworking/libc/getnetnamadr.c,
libnetworking/libc/nsap_addr.c,
libnetworking/libc/res_debug.c,
libnetworking/libc/res_send.c: Add missing prototypes.
* libi2c/libi2c.c, libi2c/libi2c.h: Add missing prototypes.
* libmd/md4.c, libmd/md5.c: Add missing prototypes.
* libmisc/monitor/mon-command.c, libmisc/shell/filemode.c,
libmisc/shell/shell_script.c: Add missing prototypes.
* libfs/src/nfsclient/src/xdr_mbuf.c: Add prototypes.
* librpc/include/rpc/clnt.h: Cleanup.
* librpc/include/rpc/svc.h: Cleanup.
* librpc/src/xdr/xdr_stdio.c: Misc. ansifications.
Add prototypes.
* librpc/src/xdr/xdr_mem.c librpc/src/xdr/xdr_rec.c
librpc/src/xdr/xdr_sizeof.c: Misc. ansifications.
Add prototypes.
