* capture/config.h: Remove.
* capture/Makefile.am: Remove config.h.
AM_CPPFLAGS += -I$(top_builddir).
* cpuuse/config.h: Remove.
* cpuuse/Makefile.am: Remove config.h.
* devnull/config.h: Remove.
* devnull/Makefile.am: Remove config.h.
* dummy/config.h: Remove.
* dummy/Makefile.am: Remove config.h.
* dumpbuf/config.h: Remove.
* dumpbuf/Makefile.am: Remove config.h.
* monitor/config.h: Remove.
* monitor/Makefile.am: Remove config.h.
* mw-fb/config.h: Remove.
* mw-fb/Makefile.am: Remove config.h.
* rtmonuse/config.h: Remove.
* rtmonuse/Makefile.am: Remove config.h.
* serdbg/config.h: Remove.
* serdbg/Makefile.am: Remove config.h.
* shell/config.h: Remove.
* shell/Makefile.am: Remove config.h.
* stackchk/config.h: Remove.
* stackchk/Makefile.am: Remove config.h.
* untar/config.h: Remove.
* untar/Makefile.am: Remove config.h.
* src/config.h: Remove.
* Makefile.am: Remove src/config.h
* src/Makefile.am: AM_CPPFLAGS += -I$(top_builddir).
* src/dosfs/config.h: Remove.
* src/dosfs/Makefile.am: Remove config.h
* src/imfs/config.h: Remove.
* src/imfs/Makefile.am: Remove config.h
* acinclude.m4: New.
* configure.ac: Don't use AUTOHEADER to generate cpuopts.h.
Add local autoheader config.h.
* aclocal/canonical-target-name.m4: Require AC_CANONICAL_HOST.
* aclocal/enable-inlines.m4: Remove USE_MACROS (Unused).
which included commits to RCS files with non-trunk default branches.
* src/regiongetsegment.c: Remove unneccessary typecast in assignment
to thread->Wait.return_argment.
PR 515/filesystem
* src/dosfs/fat_fat_operations.c: Remove commented out code.
PR 512/core
* src/tasks.c, src/taskvariabledelete.c: Run task variable destructor
when task variable is deleted. Also some style cleanup.
PR 511/filesystem
* src/malloc.c: Add deferred free and protect against C Program Heap
operations while in a dispatch disable critical section or ISR.
PR 509/filesystem
* src/dosfs/fat.c: _fat_block_read and _fat_block_write return error
codes instead of -1 in case of errors, as they are supposed to do
according to the comments documenting these functions.
PR 440/filesystem
* src/dosfs/fat_fat_operations.c: Improve write speed with FAT12 and
FAT16 filesystems. Previously merged on 4.6 branch.
* ChangeLog: Correct line length.
* aclocal/check-posix.m4: Add m4-quotes.
Require RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU.
* aclocal/canonical-host.m4: Remove.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* aclocal/sysv-ipc.m4: Remove reference to RTEMS_CANONICAL_HOST.
* aclocal/canonical-target-name.m4: Use AC_CANONICAL_HOST instead of
AC_CANONICAL_TARGET. Use $host instead of $target.
* aclocal/check-multiprocessing.m4: Add m4-quotes.
Remove RTEMS_CHECK_CPU.
* aclocal/check-itron.m4: Add m4-quotes.
* aclocal/check-networking.m4: Add m4-quotes.
* aclocal/check-cpu.m4: Remove.
* aclocal/canonical-target-name.m4: Add m4-quotes.
* configure.ac: Merge-in former aclocal/check-cpu.m4.
* configure.ac: Remove RTEMS_CHECK_CPU.
* src/coremsgseize.c, src/coremsgsubmit.c:
Remove unnecessary typecasts in assignments to
thread->Wait.return_argument.
* src/cancelrun.c, src/pthreadexit.c, src/pthreadjoin.c,
src/sigtimedwait.c: Remove unnecessary typecasts in assignments to
* src/dosfs/Makefile.am: noinst_HEADERS += fat.h
* src/dosfs/msdos_file.c (msdos_file_read, msdos_file_write):
Use '0' as initial value for ret instead of RC_OK.
* src/dosfs/msdos_conv.c: Remove isupper, islower, toupper, tolower
(Unused).
* capture/capture-cli.c: Reflect new rtems_monitor_command_arg_t.
* src/rpc/Makefile.am: Remove __P from AM_CPPFLAGS.
Rely on sys/cdefs.h providing it.
* src/xdr/Makefile.am: Remove __P from AM_CPPFLAGS.
* configure.ac: Check for sys/cdefs.h.
* aclocal/env-rtems-cpu.m4: Add project_includedir.
Deprecate PROJECT_INCLUDE. Change project_includedir to
$(PROJECT_ROOT)/include for multilibs.
* src/cleanuppop.c, src/cleanuppush.c: Protect use of
_Workspace_Allocate and _Workspec_Free.
PR 504/rtems
* include/rtems/score/coremutex.h: Add fatal error check for a task
blocking on a mutex when thread dispatching is disabled.
PR 504/rtems
* src/newlibc.c: Fix memory allocation of libc extension so it is
dispatch disabled safe See PR for detailed explanation.
* rtems/new-exceptions/cpu.h, rtems/old-exceptions/cpu.h: Obsoleting HP
PA-RISC port and removing all references.
* rtems/score/cpu.h: Obsoleting HP PA-RISC port and removing all
references.
* cpu/hppa1.1/.cvsignore, cpu/hppa1.1/ChangeLog,
cpu/hppa1.1/Makefile.am, cpu/hppa1.1/configure.ac, cpu/hppa1.1/cpu.c,
cpu/hppa1.1/cpu_asm.S, cpu/hppa1.1/rtems/.cvsignore,
cpu/hppa1.1/rtems/score/.cvsignore, cpu/hppa1.1/rtems/score/cpu.h,
cpu/hppa1.1/rtems/score/cpu_asm.h, cpu/hppa1.1/rtems/score/hppa.h,
cpu/hppa1.1/rtems/score/types.h: Removed.
PR 495/rtems_misc
* capture/capture-cli.c, monitor/mon-command.c, monitor/mon-config.c,
monitor/mon-monitor.c, monitor/mon-object.c, monitor/mon-symbols.c,
monitor/monitor.h, shell/cmds.c: Move to making libmisc 16/32 bit
clean.
PR 498/rtems
* src/printk.c: RTEMS printk() does not support the %i format which is
used by a lot of driver/BSP etc. code. The trivial patch allows %i/%I
as an alias for %d/%D.
PR 492/filesystem
* src/dosfs/fat_file.c: Fix inconsistent types in va_args call.
* configure.ac: Reflect having removed include/Makefile.am and
librpc/include/Makefile.am.
* monitor/monitor.h:
Add rtems_monitor_commands[] (Illegally applied by shell/).
Remove ifdef(__mips64) (Make broken code visible again).
* monitor/mon-command.c: Add several ifndef RTEMS_UNIX to avoid
warnings.
* monitor/mon-monitor.c: Remove RTEMS_CPU_HAS_16_BIT_ADDRESSES (Make
* shell/cmds.c: Remove local decls of rtems_monitor_commands[].
* monitor/monitor.h: Remove STREQ, STNEQ (pollute namespace),
RTEMS_MONITOR_PROMPT (pollutes namespace, useless).
* monitor/mon-command.c: Add RTEMS_MONITOR_PROMPT.
* monitor/mon-monitor.c: Apply private version of STREQ.
* monitor/symbols.h: Convert to private header.
* monitor/monitor.h: Don't include symbols.h.
Add forward decls. for symbols from symbols.h.
* monitor/Makefile.am: Don't install symbols.h.
* monitor/mon-symbols.c: Include "symbols.h".
PR 482/networking
* rtems/rtems_glue.c: Network interfaces cant be taken down
PR 481/networking
* net/ethernet.h, net/if_arp.h, netinet/if_ether.h: Network structs
should be packed
PR 482/networking
PR 489/rtems
* include/rtems/score/thread.h: Change struct
Thread_Control_struct.libc_reent to using struct _reent*.
* inline/rtems/score/thread.inl: Reflect change above.
PR 489/rtems
* src/newlibc.c: Reflect struct Thread_Control_struct.libc_reent
having changed from void * to struct _reent*.
* src/sync.c: Don't undef __STRICT_ANSI__.
Use struct _reent (struct reent doesn't exist)
PR 486/rtems
* src/newlib.c: Unconditionally include <stdio.h>
PR 488/rtems
* src/taskcreate.c, src/tasks.c: Ensure notepads are zeroed.
PR 487/filesystem
* src/dosfs/fat_file.c: Correct typing per gcc 3.3 warnings.
