* | lm32: Remove use of proc_ptr | Sebastian Huber | 2018-11-12 | 2 | -62/+18 |
| | | | | Update #3585. | ||||
* | i386: Remove use of proc_ptr | Sebastian Huber | 2018-11-12 | 2 | -23/+6 |
* | epiphany: Remove use of proc_ptr | Sebastian Huber | 2018-11-12 | 2 | -48/+0 |
* | bfin: Remove use of proc_ptr | Sebastian Huber | 2018-11-12 | 2 | -67/+20 |
* | arm: Remove use of proc_ptr | Sebastian Huber | 2018-11-12 | 3 | -14/+16 |
* | no_cpu: Remove use of proc_ptr | Sebastian Huber | 2018-11-12 | 2 | -24/+35 |
* | rtems: Simplify rtems_interrupt_catch() | Sebastian Huber | 2018-11-12 | 1 | -33/+5 |
| | | | | | | Remove casts and superfluous inline functions. Update #3585. | ||||
* | score: Deprecate proc_ptr | Sebastian Huber | 2018-11-12 | 1 | -1/+1 |
* | score: Move internal structures to userextdata.h | Sebastian Huber | 2018-11-12 | 5 | -24/+66 |
| | | | | Update #3598. | ||||
* | score: Includes in <rtems/score/smplockstats.h> | Sebastian Huber | 2018-11-12 | 1 | -0/+2 |
| | | | | | | Include implementation header files only if necessary. Update #3598. | ||||
* | rtems: Simplify includes in <rtems/rtems/cache.h> | Sebastian Huber | 2018-11-12 | 1 | -2/+1 |
* | score: Move internal structures to objectdata.h | Sebastian Huber | 2018-11-12 | 16 | -71/+112 |
* | rtems: Avoid include of <rtems/score/scheduler.h> | Sebastian Huber | 2018-11-12 | 5 | -5/+40 |
* | rtems: Avoid include of <rtems/score/thread.h> | Sebastian Huber | 2018-11-12 | 1 | -3/+4 |
* | score: Avoid complex include in heap.h | Sebastian Huber | 2018-11-12 | 1 | -2/+3 |
* | rtems: Remove superfluous include | Sebastian Huber | 2018-11-12 | 1 | -1/+0 |
* | score: Introduce <rtems/score/watchdogticks.h> | Sebastian Huber | 2018-11-12 | 11 | -43/+85 |
| | | | | | | | Separate the definitions related to watchdog ticks from the watchdog structures. Update #3598. | ||||
* | rtems: Avoid <rtems/score/timecounter.h> in API | Sebastian Huber | 2018-11-12 | 5 | -7/+35 |
| | | | | | | Use a real function for rtems_clock_get_uptime_seconds(). Update #3598. | ||||
* | score: Avoid include of <rtems/score/thread.h> | Sebastian Huber | 2018-11-12 | 2 | -15/+17 |
* | score: Remove empty <rtems/score/tod.h> | Sebastian Huber | 2018-11-12 | 4 | -35/+0 |
* | rtems: Move internal structures to extensiondata.h | Sebastian Huber | 2018-11-12 | 6 | -11/+66 |
* | rtems: Move internal structures to timerdata.h | Sebastian Huber | 2018-11-12 | 5 | -50/+75 |
* | rtems: Move internal structures to tasksdata.h | Sebastian Huber | 2018-11-12 | 13 | -67/+90 |
* | rtems: Move internal structures to semdata.h | Sebastian Huber | 2018-11-12 | 6 | -84/+121 |
* | rtems: Move internal structures to regiondata.h | Sebastian Huber | 2018-11-12 | 6 | -33/+63 |
* | rtems: Move internal structures to partdata.h | Sebastian Huber | 2018-11-12 | 6 | -41/+70 |
* | rtems: Move internal structures to messagedata.h | Sebastian Huber | 2018-11-12 | 5 | -43/+67 |
* | rtems: Move internal structures to eventdata.h | Sebastian Huber | 2018-11-12 | 5 | -23/+52 |
* | rtems: Move internal structures to dpmemdata.h | Sebastian Huber | 2018-11-12 | 5 | -35/+62 |
* | rtems: Move internal structures to barrierdata.h | Sebastian Huber | 2018-11-12 | 5 | -39/+65 |
* | rtems: Remove Modes_Control | Sebastian Huber | 2018-11-12 | 6 | -23/+18 |
| | | | | | | | Use rtems_mode directly. This is in line with rtems_attribute and rtems_option. Update #3598. | ||||
* | rtems: Move internal structures to asrdata.h | Sebastian Huber | 2018-11-12 | 5 | -21/+61 |
* | rtems: Move internal structures to ratemondata.h | Sebastian Huber | 2018-11-12 | 6 | -111/+144 |
* | Include missing <sys/types.h> | Sebastian Huber | 2018-11-12 | 1 | -2/+3 |
* | x86_64: Remove duplicate _CPU_Thread_Idle_body() | Sebastian Huber | 2018-11-12 | 1 | -5/+0 |
* | m32c: Remove this target | Sebastian Huber | 2018-11-12 | 17 | -1646/+7 |
| | | | | Update #3599. | ||||
* | Include missing <rtems/score/thread.h> | Sebastian Huber | 2018-11-09 | 1 | -0/+2 |
* | rtems: Deprecate rtems_rate_monotonic_period_time_t | Sebastian Huber | 2018-11-09 | 1 | -5/+5 |
| | | | | | | | The rtems_rate_monotonic_period_time_t typedef as no corresponding API. It violates the POSIX namespace. A user can do nothing with it. Close #3595. | ||||
* | rtems: Deprecate rtems_thread_cpu_usage_t | Sebastian Huber | 2018-11-09 | 2 | -5/+5 |
| | | | | | | | The rtems_thread_cpu_usage_t typedef as no corresponding API. It violates the POSIX namespace. A user can do nothing with it. Close #3593. | ||||
* | rtems: Deprecate region_information_block | Sebastian Huber | 2018-11-09 | 3 | -3/+3 |
| | | | | | | | The region_information_block typedef as no corresponding API. It has no proper namespace prefix. A user can do nothing with it. Close #3591. | ||||
* | rtems: Deprecate rtems_context_fp | Sebastian Huber | 2018-11-09 | 1 | -1/+1 |
| | | | | | | | The rtems_context_fp typedef as no corresponding API. A user can do nothing with it. Close #3589. | ||||
* | rtems: Deprecate rtems_context | Sebastian Huber | 2018-11-09 | 1 | -1/+1 |
| | | | | | | | The rtems_context typedef as no corresponding API. A user can do nothing with it. Close #3587. | ||||
* | h8300: Remove left over files | Sebastian Huber | 2018-11-08 | 2 | -61/+0 |
| | | | | Update #2452. | ||||
* | rtems: Add missing include | Sebastian Huber | 2018-11-08 | 1 | -0/+1 |
* | libcsupport: Add missing include | Sebastian Huber | 2018-11-08 | 1 | -0/+1 |
* | rtems: Move includes out of extern "C" scope | Sebastian Huber | 2018-11-08 | 3 | -12/+12 |
* | small typo | Malte Münch | 2018-11-08 | 1 | -1/+1 |
* | config: Move includes out of extern "C" scope | Sebastian Huber | 2018-11-08 | 1 | -4/+4 |
* | monitor: Remove dead code | Sebastian Huber | 2018-11-08 | 2 | -19/+0 |
| | | | | | Update #3587. Update #3589. | ||||
* | score: Use RTEMS_DEPRECATED for deprecated types | Sebastian Huber | 2018-11-08 | 2 | -6/+6 |
| | | | | Update #3584. |
