* | ratemonreportstatistics.c: Fix printf() warnings so clean on 32 and 64 bit ↵ | Joel Sherrill | 2017-04-24 | 1 | -7/+8 |
| | | | | architectures | ||||
* | epiphany/cpu.c: Fix not a prototype warning | Joel Sherrill | 2017-04-24 | 1 | -2/+2 |
* | rtems/inttypes.h: Add PRIdioctl_command_t | Joel Sherrill | 2017-04-23 | 1 | -3/+7 |
* | rtems/inttypes.h: Add blksize_t and blkcnt_t | Joel Sherrill | 2017-04-22 | 2 | -0/+36 |
* | libdebugger: Fix the mode on task create. Clean up warnings. | Chris Johns | 2017-04-19 | 1 | -14/+21 |
| | | | | Closes #2976. | ||||
* | libmisc/monitor: Correctly print unlimited configuration table entries. | Chris Johns | 2017-04-19 | 1 | -12/+22 |
| | | | | Closes #2997. | ||||
* | Merge tmacros.h PRIxxx constants from testsuites/ into <rtems/inttypes.h> | Joel Sherrill | 2017-04-18 | 2 | -20/+76 |
| | | | | | | | This completes the initial creation of rtems/inttypes.h based on all existing PRIxxx definitions contained in RTEMS Project owned code. closes #2983. | ||||
* | rtems/inttypes.h: New file. Uses contents from cpukit | Joel Sherrill | 2017-04-18 | 9 | -59/+90 |
| | | | | | | | | Provide extentions to <inttpes.h> PRIxxx constants for more POSIX types. Start with existing definitions found in RTEMS Project owned code in cpukit/. updates #2983. | ||||
* | libdebugger: Work around assert when using _Thread_Executing. | Chris Johns | 2017-04-15 | 2 | -2/+8 |
| | | | | | | | Using _Thread_Executing with RTEMS_DEBUG results in an `assert` if the server accesses invalid memory. Updates #2993. | ||||
* | cpukit/../i386/cpu.c: Use inttypes.h to fix 1 warning. | Cillian O'Donnell | 2017-04-14 | 1 | -1/+2 |
* | Updating default termios initialization for dedicated input/output baud rates | Kevin Kirspel | 2017-04-10 | 1 | -1/+4 |
| | | | | updates #2897. | ||||
* | libdl/rtl-obj-cache.c: Using inttypes macros fixes 4 format warnings | Cillian O'Donnell | 2017-04-07 | 1 | -9/+12 |
* | xz_config.h: Define XZ_USE_CRC64 | Joel Sherrill | 2017-04-06 | 1 | -1/+1 |
| | | | | close #2909. | ||||
* | SMP: Simplify SMP multicast actions | Sebastian Huber | 2017-04-05 | 4 | -63/+85 |
* | sys/event.h: Update to FreeBSD head 2017-02-13 | Sebastian Huber | 2017-04-04 | 1 | -7/+9 |
* | bsps: Fix baud settings | Sebastian Huber | 2017-04-03 | 2 | -5/+3 |
| | | | | Update #2897. | ||||
* | configure: Remove defunct configure stuff | Sebastian Huber | 2017-04-03 | 1 | -2/+0 |
* | libdl: Support link ordered loading of ELF sections. | Chris Johns | 2017-03-31 | 5 | -36/+166 |
| | | | | | | | | | | | | | The ARM C++ exception ABI uses an address ordered index table to locate the correct frame data and this requires the EXIDX sections are loaded in the order the order the matching text is loaded. The EXIDX sections set the SHF_LINK_ORDER flag and link field. This patch adds support to load those flagged sections in the linked-to section order. Updates #2955. Closes #2959 | ||||
* | arm: Optimize context switch | Sebastian Huber | 2017-03-28 | 3 | -78/+55 |
| | | | | | | | | | Set CPU_ENABLE_ROBUST_THREAD_DISPATCH to TRUE. In this case the interrupts are always enabled during a context switch even after interrupt processing (see #2751). Remove the CPSR from the context control since it contains only volatile bits. Close #2954. | ||||
* | posix: Fix pthread_detach() internal lock acquire | Sebastian Huber | 2017-03-28 | 1 | -1/+1 |
* | rtems: Fix error return path | Sebastian Huber | 2017-03-28 | 1 | -0/+1 |
* | cpukit: Fix Makefile.am and update preinstall.am | Sebastian Huber | 2017-03-27 | 2 | -18/+20 |
* | termios: Avoid invalid memory access | Sebastian Huber | 2017-03-27 | 1 | -1/+3 |
* | termios: Synchronize with latest FreeBSD headers | Kevin Kirspel | 2017-03-22 | 26 | -293/+658 |
| | | | | | | | | | | | Adding modified FreeBSD headers to synchronize RTEMS termios with FreeBSD. Modify termios to support dedicated input and output baud for termios structure. Updated BSPs to use dedicated input and output baud in termios structure. Updated tools to use dedicated input and output baud in termios structure. Updated termios testsuites to use dedicated input and output baud in termios structure. Close #2897. | ||||
* | dosfs: Fix file name search | Sebastian Huber | 2017-03-16 | 1 | -17/+7 |
| | | | | | | | Do not use our long file name entry count to optimize the file name search. The Unicode comparison must be taken into account. Update #2939. | ||||
* | dosfs: Fix race condition msdos_dir_read() | Sebastian Huber | 2017-03-16 | 1 | -5/+5 |
| | | | | | | Obtain file system instance lock before member access. Update #2937. | ||||
* | dosfs: Rename fat_entries to lfn_entries | Sebastian Huber | 2017-03-16 | 1 | -20/+20 |
| | | | | | The name "fat_entries" for long file name directory entries is quite misleading. | ||||
* | dosfs: Fix long file name padding | Sebastian Huber | 2017-03-16 | 1 | -3/+3 |
| | | | | Update #2934. | ||||
* | dosfs: msdos_filename_utf8_to_short_name_for_save | Sebastian Huber | 2017-03-16 | 1 | -15/+10 |
| | | | | Simplify. | ||||
* | dosfs: Fix msdos_add_file() | Sebastian Huber | 2017-03-16 | 1 | -245/+155 |
| | | | | | | Make sure that long file names work accross cluster boundaries. Update #2929. | ||||
* | dosfs: Simplify msdos_add_file() | Sebastian Huber | 2017-03-16 | 1 | -4/+2 |
* | dosfs: Add and use msdos_lfn_checksum() | Sebastian Huber | 2017-03-16 | 3 | -22/+25 |
* | dosfs: Simplify fat_file_open() | Sebastian Huber | 2017-03-16 | 1 | -3/+1 |
* | dosfs: Simplify msdos_creat_node() | Sebastian Huber | 2017-03-16 | 1 | -21/+14 |
* | dosfs: Fix fat_file_write() | Sebastian Huber | 2017-03-16 | 3 | -30/+11 |
| | | | | | | | | Remove forced overwrite which leads to file data corruption. The logic to determine a forced overwrite was fundamentally broken. For simplity, disable this feature. Update #2622. | ||||
* | dosfs: Fix msdos_utf8_normalize_and_fold() | Sebastian Huber | 2017-03-16 | 1 | -2/+2 |
| | | | | | | | | It is all right in case the result uses the full destination buffer. Without this fix the handling of a maximum 8.3 short file name is broken. Update #2928. | ||||
* | libio: Fix deadlock in location management | Sebastian Huber | 2017-03-16 | 7 | -13/+17 |
| | | | | | | | | Perform a context-dependent deferred location release to avoid a deadlock on the file system instance locks, for example during a chdir(). Update #2936. | ||||
* | arm: Fix CPU context validation for Cortex-R4 | Sebastian Huber | 2017-03-09 | 2 | -7/+3 |
| | | | | Do not touch the FPSCR[QC] bit since this is DNM/RAZ on Cortex-R4. | ||||
* | arm: Remove legacy execption support | Sebastian Huber | 2017-03-08 | 4 | -301/+0 |
* | monitor: Do not zero sema id and name | Sebastian Huber | 2017-03-07 | 1 | -1/+5 |
* | score: Fix scheduler yield in SMP configurations | Sebastian Huber | 2017-03-07 | 4 | -20/+46 |
| | | | | | | | | | Check that no ask help request is registered during unblock and yield scheduler operations. There is no need to ask for help if a scheduled thread yields, since this is already covered by the pre-emption detection. Update #2556. | ||||
* | powerpc: Fix PPC_CONTEXT_VOLATILE_SIZE | Sebastian Huber | 2017-03-06 | 1 | -1/+1 |
* | libdrvmgr: remove braces | Daniel Cederman | 2017-03-06 | 1 | -1/+1 |
* | libdrvmgr: added default BSP init level hook | Daniel Hellstrom | 2017-03-06 | 1 | -0/+9 |
* | libpci: code cleanup | Daniel Hellstrom | 2017-03-06 | 1 | -3/+1 |
* | posix_devctl: Fix for pre C99 | Sebastian Huber | 2017-03-02 | 1 | -5/+5 |
| | | | | | Use __restrict just like in <devctl.h> to avoid compiler errors with older GCC, e.g. 4.8 or 4.9. | ||||
* | dosfs: Fix FAT32 formatter | Sebastian Huber | 2017-02-28 | 1 | -2/+2 |
| | | | | | | | | | The second FAT entry contains a bit to indicate if the FAT32 filesystem is not dirty and a bit to indicate if there was no IO error. Set both bits for a fresh filesystem. This prevents a warning if mounted on Windows. Close #2913. | ||||
* | dosfs: Directories should have a file size of 0 | Sebastian Huber | 2017-02-28 | 1 | -1/+6 |
| | | | | Close #2755. | ||||
* | termios: Simplify some calculations | Sebastian Huber | 2017-02-28 | 1 | -4/+3 |
| | | | | Use the modular arithmetic addition rule. | ||||
* | termios: Implement non-blocking write | Sebastian Huber | 2017-02-28 | 1 | -4/+6 |
