which included commits to RCS files with non-trunk default branches.
* ChangeLog: fixed wrong date of last ChangeLog entry.
PR 849/networking
* librpc/src/rpc/rtems_portmapper.c: Increased stack size
by ARGSIZE to prevent overrun.
* configure.ac: New header guard for cpuopts.h.
* rtems/score/cpu.h: Eliminate use of unsigned32.
* libnetworking/rtems/rtems_mii_ioctl.h: Reflect mii.h and
if_media.h having moved.
* libnetworking/net/if_media.h, libnetworking/dev/mii/mii.h:
New (Moved from c/src/libchip).
* libnetworking/Makefile.am: Re-add rtems/rtems_mii_ioctl.h,
rtems/rtems_mii_ioctl.c, rtems/rtems_mii_ioctl_kern.c.
Add dev/mii/mii.h, net/if_media.h (Moved from c/src/libchip).
* automake/local.am: Remove depend.
* include/rtems/stdint.h: Disable RTEMS proprietary fixed-size types.
* configure.ac: Add RTEMS_NETWORKING to cpuopts.h.
Add RTEMS_DEPRECATED_TYPES to config.h.
Add AC_CONFIG_COMMANDS(preinstall-stamp) magic.
Misc. cleanups.
* rtems/score/types.h: Eliminate unsigned16, unsigned32.
* libnetworking/net/if.h: Add forward reference declaration to
struct mbuf so ifru_tap callback is properly typed.
* libnetworking/rtems/rtems_bsdnet.h: Add definition of _BSD_VISIBLE
which needs to be defined so various pieces of the .h files are
visible to device drives.
* libnetworking/Makefile.am: Comment out using
rtems/rtems_mii_ioctl.h, rtems/rtems_mii_ioctl.c,
* pppd/rtemspppd.c, pppd/rtemspppd.h: Per confirmation from Michael add
missing copyright notice.
* libi2c/libi2c.c: Include config.h.
* libi2c/libi2c.c, libi2c/libi2c.h,
libnetworking/rtems/rtems_mii_ioctl.h,
libnetworking/rtems/rtems_mii_ioctl_kern.c,
score/src/heap.c: Eliminate obsolete types.
* httpd/Makefile.am: Remove bogus noinst_LIBRARIES.
* libnetworking/Makefile.am,
libnetworking/preinstall.am: Added simple implementation of ethernet
media ioctl SIOCSIFMEDIA/SIOCGIFMEDIA for mii compliant phys.
* libnetworking/rtems/rtems_mii_ioctl.c,
libnetworking/rtems/rtems_mii_ioctl_kern.c: New files.
* libi2c/Makefile.am, libi2c/Makefile.in, libi2c/libi2c.c,
libi2c/libi2c.h: New files.
* Makefile.am, configure.ac, preinstall.am, wrapup/Makefile.am: added a
simple API/library for i2c devices and drivers for i2c 2-byte eeproms
and a ds1621 temperature sensor; API is documented in libi2c.h
* rtems/powerpc/registers.h: recognize mpc7457 CPU; added definitions
for high bats (#4..7) on 7450 CPUs
PR 842/networking
* libnetworking/libc/gethostbydns.c: Avoid use of dprintf(). Rename
dprintf to debugprintf().
* libnetworking/net/zlib.c: Remove.
* libnetworking/net/zlib.h: Remove.
* libnetworking/Makefile.am: Reflect changes above.
* pppd/Makefile.am: Fix typo.
PR 840/rtems:
* include/rtems/irq.h: Fix several typos.
* configure.ac: Add zlib.
* Makefile.am: Add zlib.
* zconf.h: Hard-code using unistd.h.
Hard-code Z_PREFIX.
* zconf.in.h: Remove (Unused).
* zconf.h: Use uint_least*_t types.
* crc32.c, zutil.c, zutil.h: Misc. type fixes.
* Makefile.am: New.
* preinstall.am: New.
trees.c, uncompr.c, zconf.h, zconf.in.h, zutil.c, zutil.h: Reformat
CVS Ids.
* ChangeLog.zlib: Renamed version of zlib's ChangeLog.
* FAQ, INDEX, README, adler32.c, algorithm.txt, compress.c, crc32.c,
crc32.h, deflate.c, deflate.h, gzio.c, infback.c, inffast.c,
inffast.h, inffixed.h, inflate.c, inflate.h, trees.c, trees.h,
uncompr.c, zconf.h, zconf.in.h, zlib.3, zlib.h, zutil.c, zutil.h,
inftrees.h, inftrees.c, ChangeLog: Import from zlib-1.2.2.2.tar.gz.
