* inline/Makefile.am: Remove.
* macros/Makefile.am: Remove.
* src/Makefile.am: Remove.
* Makefile.am: Merge-in removed Makefile.ams.
* wrapup/Makefile.am: Reflect changes to sapi/.
* configure.ac: Reflect changes to sapi/.
* configure.ac: Add AC_SUBST(INLINEdir).
* wrapup/Makefile.am: Reflect changes to rtems/.
* configure.ac: Reflect changes to rtems/.
* wrapup/Makefile.am: Reflect changes to posix/.
Reflect changes to itron/.
* src/malloc.c: Fixed code that incorrected did a disable dispatch
instead of locking and unlocking the allocator mutex.
* inline/rtems/posix/cond.inl, macros/rtems/posix/cond.inl:
Implemented PTHREAD_COND_INITIALIZER support. Vladimir implemented
the inline version and Joel adapted it to the macro version.
* automake/compile.am: Rework *FLAGS, AM_*FLAGS handling.
* automake/multilib.am: Don't include @RTEMS_BSP@.cfg.
* automake/compile.am: Remove hard-coded CFLAGS_PROFILE_V.
Add autoconf-supplied CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V,
CFLAGS_PROFILE_V.
Hard-code RTEMS_CFLAGS_PROFILE = -pg
* aclocal/prog-cc.m4: Sync with toplevel/aclocal/prog-cc.m4.
Remove GCCSED.
* aclocal/env-rtemsbsp.m4: Add AC_ARG_VAR for CPU_CFLAGS,
CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V.
* configure.ac: Add various checks to enhance portability.
* src/termios.c: Reflect changes to configure.ac.
* aclocal/rtems-flags.m4: New.
* stackchk/check.c: Better handling of task name.
* include/rtems/score/object.h, include/rtems/score/tod.h:
Added casts to eliminate warnings on 16 bit targets like the h8300.
* include/rtems/rtems/support.h: Added casts to eliminate warnings
* include/rtems/posix/timer.h, src/keygetspecific.c,
src/posixtimespecsubtract.c, src/ptimer1.c, src/semunlink.c:
Added casts to eliminate warnings on 16-bit targets like the h8300.
* src/dosfs/fat.h, src/dosfs/msdos.h: Added casts to remove warnings
* include/rtems/libio.h: Internally use a union of an unsigned64
and major/minor device so we don't get into trouble shifting.
The h8300 seemed to be impossible to remove warnings otherwise.
Eventually the structure definition of a dev_t might be better anyway.
* include/sys/ioccom.h: Added casts to remove warnings on 16 bit
targets.
* src/bdbuf.c: Added cast to remove warning.
* automake/compile.am: Remove CFLAGS_DEBUG_OPTIMIZE_V (Unused).
* configure.ac: Cosmetical fixes.
* configure.ac: Fix package name.
* aclocal/sysv-ipc.m4: Adaptation to autoconf-2.5x.
* aclocal/check-newlib.m4: Sync with ../aclocal/check-newlib.m4.
* include/rtems/libio.h: Remove.
* configure.ac: Check for sys/cdefs.h, Add NEED_SYS_CDEFS_H.
Add check for CHAR_BIT.
* Makefile.am: Conditionally install sys/cdefs.h iff using newlib or
if the host does not provide sys/cdefs.h (Fixes Linux/posix).
* aclocal/version.m4: Updated to rtems-ss-20021118.
* configure.ac: Remove -ansi -fasm.
Add checks to diagnose potential system header conflicts.
* Makefile.am: Unconditionally install sys/cdefs.h.
* Makefile.am: Merge-in HEADER-handling from
net/Makefile.am, netinet/Makefile.am, nfs/Makefile.am.
* net/Makefile.am: Remove *_HEADERS.
* netinet/Makefile.am: Remove *_HEADERS.
* nfs/Makefile.am: Remove *_HEADERS.
* aclocal/prog-cc.m4: Acknowledge configuration-time CFLAGS.
* automake/compile.am: Acknowledge configuration-time CFLAGS.
Remove CFLAGS_DEFAULT.
* Makefile.am: Merge-in arpa/Makefile.am, machine/Makefile.am,
sys/Makefile.am, vm/Makefile.am.
Add . to SUBDIRS.
* arpa/Makefile.am: Remove.
* machine/Makefile.am: Remove.
* sys/Makefile.am: Remove.
* vm/Makefile.am: Remove.
* include/rtems/userenv.h: Rely upon <limits.h> for
_POSIX_LOGIN_NAME_MAX.
* src/diskdevs.c: Include <unistd.h> to remove warning.
* monitor/mon-commands.c: Removed warnings for RTEMS_UNIX.
* macros/rtems/score/object.inl: Keep consistent with inline version.
* capture/Makefile.am: Remove AUTOMAKE_OPTIONS.
* serdbg/Makefile.am: Remove AUTOMAKE_OPTIONS.
* serdbg/serdbgio.c: Add #include <unistd.h>.
* shell/Makefile.am: Add RTEMS_LIBSHELL conditional.
* wrapup/Makefile.am: Add RTEMS_LIBSHELL conditional.
* configure.ac: Check for stdio assignments.
* src/regionreturnsegment.c: When RTEMS_REGION_SHRED_ON_FREE is
set, there should have been an & in front of size.
* configure.ac: Generate unixsize.h on the fly, filter out
autoconf-2.53 PACKAGE crap.
* rtems/score/.cvsignore: unixsize*
* aclocal/version.m4: Updated to rtems-ss-20021111.
* src/mount.c: Per PR297, correct fs_mountme failure paths.
* sys/select.h: Add C++ to C external.
paths.
* rtems/score/cpu.h: Add prototype of H8BD_Install_IRQ to eliminate
warning.
* rtems/new-exceptions/cpu.h: Remove sections on
CPU_INLINE_ENABLE_DISPATCH and CPU_UNROLL_ENQUEUE_PRIORITY.
* rtems/old-exceptions/cpu.h: Remove sections on
* rtems/score/cpu.h: Insert sections on
