PR 1471/cpukit
* libmisc/cpuuse/cpuusagereport.c: Rework statement to ensure 64-bit
multiplication is used to avoid overflow with intermediate value.
PR 1468/cpukit
* score/src/timespecdividebyinteger.c: Rework statement to ensure
64-bit multiplication is used.
PR 1462/cpukit
* rtems/include/rtems/rtems/ratemon.h, rtems/src/ratemonperiod.c: Fine
tune previous patch after analysis in application.
PR 1469/cpukit
* cpu.c: Add dummy entry for (non-existing) exception #15.
Otherwise all slots for vectors >= 16 are one element off.
PR pr1462/cpukit
* rtems/include/rtems/rtems/ratemon.h, rtems/src/ratemonperiod.c,
rtems/src/ratemontimeout.c: Fix bugs in rate monotonic statistics.
* sapi/include/confdefs.h: Correct type of rtems_malloc_dirty_helper so
usable.
* libcsupport/include/rtems/malloc.h: Correct type of
rtems_malloc_dirty_helper so usable.
PR 1441/cpukit
* libcsupport/src/tcgetprgrp.c: Remove.
* libcsupport/src/tcgetpgrp.c: New (Renamed from
libcsupport/src/tcgetprgrp.c).
* libcsupport/Makefile.am: Add libcsupport/src/tcgetpgrp.c.
Remove libcsupport/src/tcgetprgrp.c.
Cherrypick from master 2009-09-15 05:32:49 UTC Ralf Corsepius <ralf.corsepius@rtems.org> '2009-09-15 Ralf Corsépius <ralf.corsepius@rtems.org>':
c/src/lib/libbsp/arm/gba/console/defaultfont.h
c/src/lib/libbsp/arm/smdk2410/include/.cvsignore
c/src/lib/libbsp/m68k/genmcf548x/include/.cvsignore
c/src/lib/libbsp/m68k/mcf52235/include/.cvsignore
c/src/lib/libbsp/m68k/mcf5329/include/.cvsignore
c/src/lib/libbsp/mips/csb350/start/regs.h
c/src/lib/libbsp/mips/genmongoosev/start/regs.h
c/src/lib/libbsp/mips/hurricane/liblnk/regs.h
c/src/lib/libbsp/mips/jmr3904/start/regs.h
c/src/lib/libbsp/mips/rbtx4925/liblnk/regs.h
c/src/lib/libbsp/mips/rbtx4938/liblnk/regs.h
c/src/lib/libbsp/powerpc/mvme3100/include/.cvsignore
c/src/lib/libbsp/powerpc/virtex/include/.cvsignore
contrib/crossrpms/autotools/autoconf-sources.add
contrib/crossrpms/autotools/automake-sources.add
contrib/crossrpms/patches/gdb-6.5-bfinrtems-20090122.diff
cpukit/libcsupport/src/tcgetpgrp.c
Cherrypick from master 2008-09-28 16:36:13 UTC Ralf Corsepius <ralf.corsepius@rtems.org> 'New.':
c/src/lib/libbsp/bare/preinstall.am
* libcsupport/include/rtems/assoc.h,
libcsupport/include/rtems/malloc.h: Add extern "C" {} guards.
* libcsupport/include/rtems/libio_.h: Move extern "C" {} guards.
PR 1415/cpukit
* rtems/src/semcreate.c, rtems/src/semtranslatereturncode.c,
score/inline/rtems/score/coremutex.inl, score/src/coremutex.c:
Address two paths where a task with a priority above the ceiling
could obtain a priority ceiling mutex.
PR 1413/cpukit
* rtems/src/timerserver.c: Fix bug where server based timers which
reinitiated themselves did not get reinserted onto timer chain.
PR 1412/cpukit
* score/src/coremutex.c: Add missing braces. Broken with strict mutex
code added.
PR 1411/cpukit
* rtems/src/workspace.c, score/include/rtems/score/protectedheap.h,
score/src/pheapgetfreeinfo.c, score/src/pheapgetinfo.c: Improve
workspace wrapper methods.
* aclocal/check-rtems-debug.m4: Add missing ','.
PR 1378/filesystem
* libfs/src/imfs/deviceio.c: IMFS device lseek should return the
current offset.
* ftpd/ftpd.h: Add extern C.
PR 1393/cpukit
* posix/src/mutextranslatereturncode.c: Add entry to table for
CORE_MUTEX_RELEASE_NOT_ORDER.
PR 1385/cpukit
* cpu_asm.S: When the type rtems_boolean was switched to the C99 bool,
the size changed from 4 bytes to 1 byte. The interrupt dispatching
code accesses two boolean variables for scheduling purposes and the
assembly implementations of this code did not get updated.
PR 1376/filesystem
* libcsupport/include/rtems/libio.h, libfs/src/dosfs/fat_file.c,
libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_dir.c,
libfs/src/dosfs/msdos_file.c, libfs/src/imfs/deviceio.c,
libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_directory.c,
libfs/src/imfs/memfile.c, libfs/src/nfsclient/src/nfs.c: lseek
handlers should return off_t.
PR 1388/cpukit
* rtems/src/semcreate.c: Classic Semaphores allow both priority inherit
and ceiling attributes to be set on semaphore create. These
attributes are mutually exclusive and this should be an error.
PR 1377/shell
* libmisc/shell/main_netstats.c: Remove #if 0 which should not have
been there anyway.
PR 1374/misc
* libmisc/stackchk/check.c: Fix printk formatting string.
* ftpd/ftpd.c: Change SIX_MONTHS to time_t.
with read-write access.
* libnetworking/net/if_ppp.h: Eliminate pppattach, pppintr
(Unused).
* libnetworking/net/if_ppp.c: Eliminate pppintr (Unused).
PR 1359/cpukit
* libcsupport/src/libio.c: rtems_libio_allocate:
rtems_libio_iop_freelist incorrectly zeroed on semaphore error. Now
checks error and does not modify anything until sure it has created
semaphore.
PR 1363/filesystem
* libfs/src/dosfs/fat.h: Fix issue where 32 bit values are not written
correctly in FAT f/s data.
PR 1364/cpukit
* libcsupport/src/gxx_wrappers.c: Fix compilation problems when
diagnostics enabled.
Joel Sherrill <joel.sherrill@oarcorp.com>
PR 1357/cpukit
* rtems/src/tasks.c: Ensure creating a task with no ASR is honored.
PR 1351/cpukit
* sapi/include/confdefs.h: Mask off unlimited object bit before using
configured number in calculations.
* posix/include/aio.h, posix/src/aio_suspend.c: Make aio_suspend()
POSIX-compliant.
* libblock/src/bdbuf.c: Fix typo having crept in during
boolean->bool transition.
* libfs/src/nfsclient/Makefile.am: Remove RTEMS_RELLDFLAGS.
* aclocal/prog-cc.m4: Add RTEMS_RELLDFLAGS hack.
* libfs/src/nfsclient/src/dirutils.c: #include <limits.h>.
* rtems/include/rtems/rtems/clock.h: #include <sys/time.h>
* librpc/include/rpc/rpcent.h: #include <rpc/types.h>.
* librpc/include/rpc/xdr.h: #include <rtems/bsd/sys/cdefs.h>.
PR 1348/cpukit
* rtems/src/ratemonperiod.c: Properly handle period statistics after
cpu usage information is reset while a period is running.
PR 1347/cpukit
* rtems/include/rtems/rtems/timer.h, rtems/src/rtemstimer.c,
rtems/src/timerreset.c, rtems/src/timerserver.c,
score/Makefile.am, score/include/rtems/score/watchdog.h: Rework Timer
Server to ensure that the context allows for blocking, allocating
memory, and acquiring semaphores and mutexes.
* score/src/watchdogadjusttochain.c: New file.
PR 1346/cpukit
* rtems/include/rtems/rtems/ratemon.h: Sense of rate monotonic
statistics nanoseconds or ticks granularity conditional is backwards.
* libcsupport/src/ttyname.c: Correct prototype of ttyname_r() to use
size_t for third parameter.
* libmisc/shell/main_cp.c, libmisc/shell/main_ls.c,
libmisc/shell/main_mv.c, libmisc/shell/main_netstats.c,
libmisc/shell/main_rm.c, libmisc/shell/shell_script.c: Add #define
__need_getopt_newlib to enable getopt_r() support in newlib as
required by 4.10 toolset.
