PR 1277/networking
* libnetworking/netinet/in_cksum_i386.h: Use q instead of r in
constraint for assembly language. This restricts the register choice
to the a-d registers.
PR 1268/cpukit
* libcsupport/include/rtems/assoc.h: There is no
rtems_assoc_ptr_by_value method.
PR 1266/cpukit
* posix/src/keycreate.c, posix/src/keyrundestructors.c: Use API instead
of class for key indexing.
* libmisc/cpuuse/cpuuse.c: Fix date formatting.
PR 1261/cpukit
* posix/src/semaphorecreatesupp.c: Initialize all fields during
semaphore creation.
PR 1260/cpukit
* posix/src/pthread.c: Get initial signals blocked from creating thread
not from ourselves.
PR 1259/rtems
* rtems/src/taskcreate.c: Initialize is_global in all cases since
memory is not guaranteed to be zero.
* Makefile.am, include/bsp.h: Do not include networking
drivers if networking is disabled.
* ChangeLog, sapi/src/io.c: Revert change accidentally committed to
io.c.
PR 1256/networking
* ftpd/ftpd.c, sapi/src/io.c: Fix unaligned access.
PR 1248/networking
* libnetworking/rtems/rtems_glue.c: Luke Stras <luke@spacequest.com>
reported that when no interfaces are successfully attached, the
default route is broken and may result in a jump to an illegal
address.
* include/rtems/bspIo.h, include/rtems/pci.h:
Add extern "C" guards. Reported by
Robert S. Grimes <rsg@alum.mit.edu>.
* score/include/rtems/score/copyrt.h: Update copyright notice.
PR 1237/rtems
* cpu.c, cpu_asm.S, rtems/score/cpu.h: Add logic to prevent stack creep
when interrupts occur at a sufficient rate that the interrupted
thread never gets to clean its stack. This patch ensures that an
interrupted thread will not nest ISR dispatches on its stack.
PR 1243
* pppd/auth.c (set_allowed_addrs): Remove bogus dereference.
PR 1240/filesystem
* libfs/src/imfs/imfs_rmnod.c: Fix link when removing a symlink. Memory
for filename was not being freed.
* itron/src/rsm_tsk.c: Correct error returned.
* libcsupport/src/newlibc.c: Add __ATTRIBUTE_IMPURE_PTR__
(Fixes "relocation truncated to fit: R_MIPS_GPREL16" against
_impure_ptr bug).
Fix abuse of _REENT_INIT().
* libcsupport/src/printk.c: Add %p support.
* libmisc/stackchk/check.c: Add code to check validity of frame pointer
in addition to the pattern area being overwritten. Also do some
cleanup.
PR 1234/cpukit
* libcsupport/Makefile.am: Provide printk() based implementation of
__assert() to reduce dependencies in executables.
* libcsupport/src/__assert.c: New file.
PR 1234/cpukit
PR 1231/cpukit
* posix/src/adasupp.c, posix/src/clockgetcpuclockid.c,
posix/src/clockgetenableattr.c, posix/src/clockgetres.c,
posix/src/clockgettime.c, posix/src/clocksetenableattr.c,
posix/src/mutexdefaultattributes.c, posix/src/mutexdestroy.c,
posix/src/mutexgetprioceiling.c, posix/src/mutexlock.c,
posix/src/mutexlocksupp.c, posix/src/mutexmp.c,
posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c,
posix/src/mutextrylock.c, posix/src/mutexunlock.c,
posix/src/nanosleep.c, posix/src/posixintervaltotimespec.c,
posix/src/posixtimespecsubtract.c,
posix/src/posixtimespectointerval.c,
posix/src/psignalunblockthread.c, posix/src/ptimer.c,
posix/src/ptimer1.c, posix/src/sched.c, posix/src/time.c: Remove
unneeded includes of assert.h
* libnetworking/sys/conf.h: Don't include machine/conf.h.
* libnetworking/Makefile.am: Remove machine/conf.h.
* libnetworking/machine/conf.h: Remove.
* libnetworking/sys/conf.h: Remove linesw, struct linesw, nlinesw.
(Clash with termiostypes.h - PR 1229).
* libcsupport/src/assocnamebad.c: Remove dead code. Use PRI* macros
to fix warnings.
* score/src/heapallocatealigned.c: Correct license URL and/or fix
mistake in copyright notice. Both of these mistakes appear to be from
code submitted after these changes were made previously.
PR 1226/cpukit
* sapi/include/confdefs.h: CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE not
CONFIGURE_HAS_OWN_MULTIPROCESING_TABLE.
PR 1221/cpukit
* posix/src/pthreadequal.c: Fix critical section nesting.
* libcsupport/Makefile.am: Move getpagesize.c to newlib-only
compiled files.
* wrapup/Makefile.am: Use MKDIR_P instead of mkdir_p.
Cherrypick from master 2007-02-21 18:10:50 UTC Ralf Corsepius <ralf.corsepius@rtems.org> 'Misc. hacks':
Makefile.maint
cpukit/libcsupport/src/getpagesize.c
* score/src/coremsgsubmit.c: Use Wait.option to avoid cast.
* score/include/rtems/score/heap.h, score/src/heap.c,
score/src/heapallocatealigned.c, score/src/heapresizeblock.c:
More size_t for heap-sizes.
score/src/heapallocate.c, score/src/heapextend.c: Use size_t for
heap-sizes.
* libnetworking/resolv.h: Typo fixes. Remove __P().
* rtems/include/rtems/rtems/tasks.h, rtems/src/taskcreate.c:
Use size_t for stack-sizes.
* libnetworking/vm/vm_extern.h: Remove non-implemented/unused
functions.
* libcsupport/src/gxx_wrappers.c: fix PR#690. Supply
taskvar dtor to plug memory leak. Applied patch attached
to PR#690.
* libcsupport/src/getpagesize.c: New (moved from posix/src).
* posix/src/getpagesize.c: Removed.
* posix/Makefile.am: Remove references to getpagesize.c.
* libcsupport/Makefile.am: Add getpagesize.c.
