PR 692/rtems
* rtems/src/regiongetsegment.c, rtems/src/regionreturnsegment.c: The
Region Manager did not follow the proper protocol when blocking and
unblocking tasks waiting on buffers. This was a bug introduced with
the transition to an Allocation Mutex.
* aclocal/rtems-cpu-subdirs.m4, libchip/shmdr/shm_driver.h,
libnetworking/pppd/utils.c: i960 obsoleted and all references
removed.
* configure.ac, libmisc/cpuuse/README, libmisc/stackchk/README,
librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am,
score/include/rtems/score/mppkt.h: i960 obsoleted and all references
removed.
* rtems/score/cpu.h: i960 obsoleted and all references removed.
* rtems/new-exceptions/cpu.h, rtems/old-exceptions/cpu.h: i960
* score/cpu/i960/.cvsignore, score/cpu/i960/ChangeLog,
score/cpu/i960/Makefile.am, score/cpu/i960/asm.h,
score/cpu/i960/cpu.c, score/cpu/i960/cpu_asm.S,
score/cpu/i960/rtems/score/cpu.h, score/cpu/i960/rtems/score/i960.h,
score/cpu/i960/rtems/score/types.h: Removed.
PR 294/rtems
* posix/src/pthread.c: POSIX thread exit handler now confirms that it
created the executing thread before implicitly exitting it.
* libmisc/stackchk/check.c: Spacing.
* libnetworking/Makefile.am: Don't include subdirs.am.
* configure.ac: Add score/cpu/avr/Makefile.am.
* score/cpu/Makefile.am: Add avr.
* librpc/src/xdr/xdr_float.c: Add __AVR__.
* aclocal/gcc-weak.m4: New (Extracted from cpukit/configure.ac).
* configure.ac: Add RTEMS_CHECK_GCC_WEAK.
PR 677/misc
* libmisc/dumpbuf/dumpbuf.h, libmisc/fsmount/fsmount.h,
libmisc/rtmonuse/rtmonuse.h, libmisc/serdbg/serdbg.h,
libmisc/serdbg/serdbgcnf.h, libmisc/serdbg/termios_printk.h,
libmisc/serdbg/termios_printk_cnf.h, libmisc/untar/untar.h: Add
extern C wrappers.
PR 676/networking
* libnetworking/nfs/bootp_subr.c: /etc/resolv.conf contains NTP instead
of DNS servers.
PR 671/bsps
* rtems/score/cpu.h: Fixed bug in _CPU_ISR_Set_level, where input param
was always ignored.
PR 673/make_build
* aclocal/rtems-top.m4 (RTEMS_TOP): Add further quotes.
* aclocal/version.m4: Updated to rtems-4.6.99.1.
PR 620/networking
* libnetworking/lib/rtems_bsdnet_ntp.c,
libnetworking/rtems/rtems_bsdnet.h: Enhance NTP API.
PR 609/rtems
* score/src/threaddispatch.c: Close race condition between
_Thread_Dispatch and _Thread_Tickle_timeslice.
PR 654/rtems
* score/src/threadinitialize.c: Initialize the per thread watchdog
timer. When the thread control block is reused, we cannot depend on
it being zeroed.
* cpu_asm.S: Remove use of C++ style comments and make this compile
again.
* rtems/score/m68k.h: Add include of <stdint.h> for uint32_t used by
endian swapping routines.
PR 641/rtems
* rtems/src/eventsurrender.c: The problem here is that events may be
lost when sent to a task which enters rtems_event_receive() with options
set to wait with a timeout and to return on receipt of any event. The
events are sent from an interrupt source such as a timer service
routine. If more than one set of events is sent to the task before it
returns, the first event set may be overwritten.
PR 661/rtems
* score/src/objectmp.c: Fix invalid dereference.
PR 660/rtems
* score/cpu/m68k/rtems/score/m68k.h, score/cpu/mips/cpu_asm.S,
score/src/threadinitialize.c, score/src/threadstackallocate.c: Check
for overflow when allocating stack.
PR 659/rtems
* score/src/heapsizeofuserarea.c: Check that address specified is in
the heap.
PR rtems/652
* rtems/src/signalsend.c: Return RTEMS_INVALID_NUMBER when sending an
empty signal set.
PR 650/rtems
* score/src/coremsg.c: Check for mathemathical overflow when calculating
amount of memory to allocate for message buffers.
PR 651/core
* rtems/src/taskident.c: Add NULL check for id.
PR 631/rtems
* rtems/src/msgqcreate.c: Return unsatisfied from message_queue_create
when unable to allocate message buffer memory.
which included commits to RCS files with non-trunk default branches.
PR 628/rtems
* posix/src/killinfo.c, posix/src/pthreadkill.c, posix/src/ptimer1.c,
posix/src/sigaction.c, posix/src/sigaddset.c, posix/src/sigsuspend.c:
Signal set of 0 is supposed to return EINVAL. In addition
timer_create needed to return an error if the clock was not
CLOCK_REALTIME.
PR 629/rtems
* cpukit/src/mqueuecreatesupp.c: Return EINVAL is mq_maxmsg is
<= 0, not <.
PR 626/networking
* libnetworking/rtems/rtems_showifstat.c: Use unsigned char to avoid
printing leading FFFFFF for byte values > 127.
PR 618/rtems
* rtems/include/rtems/rtems/status.h, rtems/src/clockget.c,
rtems/src/clockset.c, rtems/src/dpmemcreate.c,
rtems/src/dpmemexternal2internal.c,
rtems/src/dpmeminternal2external.c, rtems/src/eventmp.c,
rtems/src/eventreceive.c, rtems/src/eventsend.c,
rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c,
rtems/src/msgqreceive.c, rtems/src/msgqsubmit.c,
rtems/src/partcreate.c, rtems/src/partdelete.c,
rtems/src/partgetbuffer.c, rtems/src/ratemoncancel.c,
rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c,
rtems/src/ratemonperiod.c, rtems/src/regioncreate.c,
rtems/src/regiondelete.c, rtems/src/regionextend.c,
rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c,
rtems/src/regionreturnsegment.c, rtems/src/semcreate.c,
rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c,
rtems/src/taskcreate.c, rtems/src/taskgetnote.c,
rtems/src/taskmode.c, rtems/src/taskrestart.c,
rtems/src/taskresume.c, rtems/src/tasksetnote.c,
rtems/src/tasksuspend.c, rtems/src/taskvariableadd.c,
rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c,
rtems/src/taskwakewhen.c, rtems/src/timercreate.c,
rtems/src/timerfirewhen.c, rtems/src/timerserverfireafter.c,
rtems/src/timerserverfirewhen.c, score/include/rtems/score/object.h,
score/src/coretodvalidate.c, score/src/objectnametoid.c: Add NULL
checks.
* libnetworking/kern/kern_sysctl.c: sysctl_register_all cannot be
static with RTEMS.
* libnetworking/netinet/in.c: Partial update from FreeBSD.
* libnetworking/kern/kern_sysctl.c: Partial updates from FreeBSD.
* libnetworking/netinet/igmp_var.h: Cosmetic updates from FreeBSD.
* libnetworking/sys/sysctl.h: Update from FreeBSD.
* libnetworking/sys/socketvar.h: Update from FreeBSD.
* libnetworking/sys/protosw.h: More partial updates from FreeBSD.
* libnetworking/net/route.c: Reflect changes to radix.h.
* libnetworking/net/radix.h, libnetworking/net/radix.c: Partial
