Updates #3877
- Fix the passing of std[in/out] to child threads
- Fix deleting of managed memory in the key destructor
- Only set the key in the main loop thread
- Only allocate a shell env outside of the main loop
- Fix memory leak if the task start fails
- Remove error level from shell env, it cannot be returned this way. Add
exit_code but the API is broken so it cannot be returned.
Closes #3877
- Newlib overtites any FILE pointers set in stdin, stdout or stderr.
Closes #3870
Close #3722.
(cherry picked from commit 2e8a66d13f04015c0024a084578f720ceb15ea00)
This bug had probably no effect since the interrupt enable is idempotent
on all CPU ports.
Close #3497.
The function rtems_rfs_buffer_sync() erroneously calls
rtems_disk_release(). This screws up the reference counting of the disk.
Close #3494.
Closes #3324
Handles possible NULL return value
Updates #2747
POSIX specifies char *, not const char *
Updates #2747
Updates #2747
Updates #2747
If there is already a file with a long file name it isn't possible to
create a second file which has a name that ends on the first files name
(for example ets.beam and sets.beam). This patch fixes that.
Close #3258.
Take care that a file in the root directory with the same name as the
volume name can be found.
Close #3257.
Close #3164.
The RTEMS_MILLISECONDS_TO_TICKS() macro doesn't round up. Do not use it
to calculate the program timeout in ticks. Check program done condition
after the timeout check to account for pre-emptions.
Close #3162.
Close #3161.
Do not update the non-existant meta-data of the root directory.
Close #2944.
Close #2964.
Set a proper name buffer length for each converter invocation.
Close #2987.
- Add 'rtems_shell_init_environment()' so a user can create the
shell environment without needing to run a shell.
- Move 'rtems_shell_lookup_topic', 'rtems_shell_can_see_cmd',
and 'rtems_shell_execute_cmd' from the internal interface to
the public interface.
Closes #3104.
Remove the OBJECTS_UNLIMITED_OBJECTS flag for the memory size
configuration.
Close #3105.
Close #3093.
Do not touch the FPSCR[QC] bit since this is DNM/RAZ on Cortex-R4.
Close #3092.
Right after a "msr basepri_max, %[basepri]" instruction an interrupt
service may still take place (observed at least on Cortex-M7). However,
pendable service calls that are activated during this interrupt service
may be delayed until interrupts are enable again. The
_ARMV7M_Pendable_service_call() did not check that a thread dispatch is
allowed. Move this test from _ARMV7M_Interrupt_service_leave() to
_ARMV7M_Pendable_service_call().
Close #3060.
Closes #2956.
Do not use our long file name entry count to optimize the file name
search. The Unicode comparison must be taken into account.
Close #2939.
Obtain file system instance lock before member access.
Close #2937.
The name "fat_entries" for long file name directory entries is quite
misleading.
Close #2934.
Simplify.
Make sure that long file names work accross cluster boundaries.
Close #2929.
Update #2929.
Update #2929.
Update #2929.
Update #2929.
Remove forced overwrite which leads to file data corruption. The logic
to determine a forced overwrite was fundamentally broken. For simplity,
disable this feature.
Close #2622.
It is all right in case the result uses the full destination buffer.
Without this fix the handling of a maximum 8.3 short file name is
broken.
Close #2928.
Perform a context-dependent deferred location release to avoid a
deadlock on the file system instance locks, for example during a
chdir().
Close #2936.
In canonical mode, the raw input buffer or the canonical buffer may
overflow without an end of line. Avoid an infinite loop in this case.
Update #2915.
Use the device lock to protect the raw input buffer management, e.g.
tail, head and buffer content updates.
Update #2914.
Remove dead code.
Update #2914.
The second FAT entry contains a bit to indicate if the FAT32 filesystem
is not dirty and a bit to indicate if there was no IO error. Set both
bits for a fresh filesystem. This prevents a warning if mounted on
Windows.
Update #2913.
Update #2755.
Close #2388.
Close #2401.
For a filename match the entry must match without anything remaining.
Update #2908.
Update #2886.
CPU_STRUCTURE_ALIGNMENT.
The CPU_CACHE_LINE_BYTES has been introduced after 4.11 branch
fork and is not available for all architectures on RTEMS 4.11.
Use of rtems_cache_get_maximal_line_size() is more descriptive
choice. The min/max data/instruction cache line size is not critical
there, value is used for optimization only to use single operation
for decently following sections.
Memory content changes caused by relocation has to be
propagated to memory/cache level which is used/snooped
during instruction cache fill.
Closes #2438
Updates #2782
