The PIP modifications from #3359 introduced new data structures
to track priority inheritance. Prioritized mutexes without PIP
share some of the code paths, and may result in NULL pointer
accesses. This patch checks for NULL, and also adds ISR critical
sections to an uncovered corner case during thread restarts.
Closes #3829.
Close #3723.
(cherry picked from commit 2e8a66d13f04015c0024a084578f720ceb15ea00)
The function rtems_rfs_buffer_sync() erroneously calls
rtems_disk_release(). This screws up the reference counting of the disk.
Close #3495.
Adds enqueue, dequeue, requeue, evaluate, and release functions
for the thread priority node priority queue of inherited priorities.
Add calls to these functions as needed to maintain the priority
queue due to blocking, unblocking, and priority changes.
Closes #3359.
Encapsulate the current_priority and real_priority fields of
the thread control block with a Thread_Priority_node struct.
Propagate modifications throughout the tree where the two
fields are directly accessed.
Updates #3359.
For FAT32 msdos_format() used to initialize first FAT entries to
non-zero values only if a volume label was given. Absence of these
entries made mounting such a FAT32 volume fail.
The missing disconnect left the socket in an unusable state. Each send
request resulted in an EISCONN error.
Use _Workspace_Allocate_or_fatal_error() consistently in case auto
extend is turned off. This helps to avoid undefined behaviour in
_API_Mutex_Allocate() in case _API_Mutex_Information() fails.
The XDR library has a problem on architectures with short enums like the
default ARM EABI. Short enums means that the size of the enum type is
variable and the smallest integer type to hold all enum values will be
selected. For many enums this is char. The XDR library uses int32_t
for enum_t. There are several evil casts from an enum type to enum_t
which leads to invalid memory accesses on short enum architectures. A
workaround is to add appropriate dummy enum values.
The file size was wrong in the no space left on device condition. This
resulted in turn in a read of an invalid block which lead to an EIO
error status.
Updates #1964.
Update #2375.
ensure that node_access is comparable in unmount()
Update #2375.
from 4.10.2-15-g5b21eb6
to eb7753437ff858ebe34a08baef7dfdb45eb0f018
Update #2375.
A cluster size > 32KiB resulted in an infinite loop in
fat_init_volume_info() due to an integer overflow.
Update #2717.
POSIX mandates that an error code is returned and not -1 plus errno.
Update #2715.
POSIX recommends ESRCH in case no thread exists for the specified
identifier.
Update #2713.
Update #2433.
closes #2376.
see #2248
updates #2249 see #1401
Access memory using a byte stream when copying to avoid unaligned
access. update #1401
Bug report by Oleg Kravtsov:
In rtems_bdbuf_swapout_processing() function there is the following
lines:
if (bdbuf_cache.sync_active && !transfered_buffers)
rtems_id sync_requester;
rtems_bdbuf_lock_cache ();
Here access to bdbuf_cache.sync_active is not protected with anything.
Imagine the following test case:
1. Task1 releases buffer(s) with bdbuf_release_modified() calls;
2. After a while swapout task starts and flushes all buffers;
3. In the end of that swapout flush we are before that part of code, and
assume there is task switching (just before "if (bdbuf_cache.sync_active
&& !transfered_buffers)");
4. Some other task (with higher priority) does bdbuf_release_modified
and rtems_bdbuf_syncdev().
This task successfully gets both locks sync and pool (in
rtems_bdbuf_syncdev() function), sets sync_active to true and starts
waiting for RTEMS_BDBUF_TRANSFER_SYNC event with only sync lock got.
5. Task switching happens again and we are again before "if
(bdbuf_cache.sync_active && !transfered_buffers)".
As the result we check sync_active and we come inside that "if"
statement.
6. The result is that we send RTEMS_BDBUF_TRANSFER_SYNC event! Though
ALL modified messages of that task are not flushed yet!
close #1485
Waiting for mbufs at this level is a bad solution. It would be better
to try to allocate a new mbuf chain before we hand over the current mbuf
chain to the upper layer. In case the allocation fails we should drop
the current packet and use its mbuf chain for a new packet.
Elevate the priority of the creating task to the ceiling priority in
case a semaphore is created as initially locked.
Fix PR 2068:
Reproducable crashes occur when using pthreads and the capture engine
at the same time. 'pthread_create()' is the culprit. It creates a SCORE thread
and then calls Thread_Start( ) without disabling thread-dispatching.
The _Thread_queue_Process_timeout() operation had several race
conditions in the event of nested interrupts. Protect the critical
sections via disabled interrupts.
Return if the executing context performed the extract operation since
interrupts may interfere.
This partly reverts commit 08b9d534604fbf437743a9925ef28eb1b848510d.
Avoid a NULL pointer access and perform the source segment erase if
necessary.
The chain iteration was wrong. The chain tail is not an object.
Commit 4b45c1393ce4ee3e1c2762ef3145d2bd6b5b38da marked a test in
_Event_Timeout() as debug only. This test is required also in non-debug
configurations since otherwise state corruption can happen. A revised
test sptests/spintrcritical10 checks the relevant sequences.
Under certain conditions it is possible that a call to
_Watchdog_Adjust_to_chain() happens with a unit parameter value of zero
(for example sptests/spintrcritical17). Remove superfluous checks that
prevent an adjust to a chain of a watchdog chain which first element has
a delta zero value.
Check the availablity of a recycle destination segment only when it is
necessary to avoid missing resycle source segment erasures.
Do not use the unavailable block count as the erased blocks starvation
threshold. Use instead the block count of the largest segment. This
improves the starvation resolution gain of available blocks.
The compaction process needs erased blocks. It is only possible to
erase an entire segment. Thus in order to make a progress we always
need enough erased blocks to empty a used or available segment which can
be erased in turn. A (possibly the worst case) lower bound of erased
blocks is the block count of the largest segment. The number of
unavailable blocks specified by the configuration will be used to
determine the erase blocks starvation situation. The number of
unavailable blocks must be greater than or equal to the number of blocks
in the largest segment.
In case rtems_bdbuf_read() returns an error status, the block device
buffer pointer will be set to NULL. In RFS the chain node of the block
device buffer will be used for RFS purposes. We must not do this after
an erroneous read.
