* ChangeLog: Merge-in libnetworking/ChangeLog.
* libnetworking/ChangeLog: Remove.
* ChangeLog: Merge-in libcsupport/ChangeLog.
* libcsupport/ChangeLog: Remove.
* ChangeLog: Merge-in libblock/ChangeLog, libfs/ChangeLog.
* libblock/ChangeLog, libfs/ChangeLog: Remove.
* ChangeLog: Merge-in libmisc/ChangeLog, librpc/ChangeLog.
* libmisc/ChangeLog, librpc/ChangeLog: Remove.
* ChangeLog: Merge-in itron/ChangeLog, posix/ChangeLog, score/ChangeLog,
sapi/ChangeLog, rtems/ChangeLog.
* itron/ChangeLog, posix/ChangeLog, score/ChangeLog, sapi/ChangeLog,
rtems/ChangeLog: Remove.
* aclocal/rtems-top.m4: Remove PROJECT_ROOT.
Prepend ../ to $1.
* aclocal/env-rtemscpu.m4: Reworked.
* configure.ac: RTEMS_TOP([.]).
* configure.ac: Move RTEMS_TOP one subdir down.
* Makefile.am: Remove wrapup.
* pppd/Makefile.am: Build libpppd.
Use automake-compilation rules.
* rtems_servers/Makefile.am: Build libftpd.
* rtems_telnetd/Makefile.am: Build libtelnetd.
* rtems_webserver/Makefile.am: Build libhttpd.
* wrapup/Makefile.am: Remove (Unused).
* pppd/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* rtems_servers/Makefile.am: Ditto.
* rtems_telnetd/Makefile.am: Ditto.
* rtems_webserver/Makefile.am: Ditto.
* wrapup/Makefile.am: Remove $(ARCH)/$(dirstamp).
Add TMPINSTALL_FILES to CLEANFILES.
* Makefile.am: Re-add dirstamps to PREINSTALL_FILES.
Add PREINSTALL_FILES to CLEANFILES.
Add cpuopts.h to DISTCLEANFILES.
* netinet/in_cksum.c: #include netinet/in_cksum_<cpu>.h.
* Makefile.am: Move include_adadir into RTEMS_ADA condional block.
Add CLEANFILES. Add PREINSTALL_FILES to CLEANFILES.
* automake/local.am: Remove depend-am.
* automake/subdirs.am: Remove depend-recursive.
PR/549 networking
* netinet/in_cksum_powerpc.h: New (copy of in_cksum_powerpc.c).
* netinet/in_cksum_powerpc.c: Remove.
* netinet/in_cksum_i386.h: New (copy of in_cksum_i386.c).
* netinet/in_cksum_i386.c: Remove.
* netinet/in_cksum_arm.h: New (copy of in_cksum_arm.c).
* netinet/in_cksum_arm.c: Remove.
* netinet/in_cksum_m68k.c: New (copy of in_cksum_m68k.c).
* netinet/in_cksum_m68k.c: Remove.
* netinet/Makefile.am: Reflect changes above.
PR 548/rtems
* Makefile.am: Add src/envlock.c.
* configure.ac: Requires automake >= 1.8.1.
* cpu/Makefile.am: Use @RTEMS_CPU@ instead of $(RTEMS_CPU).
* aclocal/rtems-top.m4: Don't AC_SUBST PROJECT_ROOT.
Remove PROJECT_TOPdir (Unused).
* aclocal/env-rtemscpu.m4: Remove PROJECT_RELEASE.
Expand ${PROJECT_ROOT}.
Remove RTEMS_ENABLE_BARE (Unused).
Don't AC_SUBST RTEMS_BSP.
* aclocal/enable-bare.m4: Remove (Unused).
* aclocal/rtems-top.m4: Remove check for cpukit/aclocal/version.m4.
Remove gnu-make endif HACK (Unused).
* Makefile.am: Reformat, add UNUSED_FILES.
* Makefile.am: Include compile.am, again.
Cleanup.
Reformat/Cleanup.
Put man-pages into EXTRA_DIST to work around automake not
distributing conditionally installed *_MANS.
Distribute include/rpcsvc.
Eliminate DOC_FILES.
Eliminate C_FILES. Reformat.
* wrapup/Makefile.am: Include compile.am.
Use TMP_LIBS instead of LIBS to avoid potential conflicts with
auto*tools' LIBS.
Reflect new locations of libscorecpu*.a
* Makefile.am: Include compile.am again. Misc fixes.
* Makefile.am: Remove AUTOMAKE_FILES.
* automake/compile.am: Replace contents with contents of
automake/amcompile.am.
* automake/amcompile.am, automake/lib.am: Remove.
* macros/rtems/score/README: Remove (Redundant with macros/README).
* Makefile.am: Convert to using automake compilation rules.
* configure.ac, aclocal/enable-bare.m4,
aclocal/enable-inlines.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4, aclocal/enable-rtems-debug.m4, aclocal/multi.m4,
aclocal/multilib.m4: Use AS_HELP_STRING instead of AC_HELP_STRING
(deprecated in autoconf-2.59)
* automake/local.am: Remove clean-local, depend-gcc.
