* pppd/auth.c, pppd/ccp.c, pppd/chap.c, pppd/ipcp.c, pppd/lcp.c,
pppd/options.c, pppd/upap.c: Add missing initializers.
* httpd/webrom.c: Add missing initializers.
* libblock/include/rtems/bdbuf.h, libblock/include/rtems/diskdevs.h,
libblock/include/rtems/ramdisk.h: Use "#include <..>" to include
public headers.
* libnetworking/netinet/in_cksum_arm.h:
Stop using old-style function definitions.
* Makefile.am: Merge thumb/Makefile.am.
* thumb/Makefile.am: Remove (superfluous).
* configure.ac: Remove score/cpu/arm/thumb/Makefile.
* itron/include/itronsys/types.h: Eliminate "boolean".
* libmisc/monitor/mon-prmisc.c: Add missing initializers.
* libblock/include/rtems/ramdisk.h,
libfs/src/nfsclient/proto/mount_prot.x: Convert to Unix file format.
* libcsupport/include/clockdrv.h: The Shared Memory Driver no longer
requires the special IOCTL in Clock_control. This was a hack which
has existed since before the Classic API Timer Manager was
implemented. All implementations of and references to Clock_control
were removed.
* score/src/corebarrier.c, score/src/corebarrierrelease.c,
score/src/corebarrierwait.c, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsgclose.c,
score/src/coremsgflush.c, score/src/coremsgflushsupp.c,
score/src/coremsgflushwait.c, score/src/coremsginsert.c,
score/src/coremsgseize.c, score/src/coremsgsubmit.c,
score/src/corerwlock.c, score/src/coresem.c,
score/src/coresemflush.c, score/src/coresemseize.c,
score/src/threadblockingoperationcancel.c,
score/src/threadqenqueue.c: Remove unnecessary include of mpci.h.
* rtems/src/msgmp.c, rtems/src/msgqtranslatereturncode.c,
rtems/src/semmp.c, rtems/src/semtranslatereturncode.c: Correct
confusion over SuperCore proxy blocking status and Classic API proxy
blocking status constants.
* score/src/objectgetinfo.c: Correct for multiprocessor systems when
all object instances within a particular class are remote.
* libcsupport/src/assocnamebad.c: Correct file name in message.
* sapi/include/confdefs.h: Make sure
CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER is defined to 0 in single
processor configurations.
* sapi/include/confdefs.h: Account for needed a Classic API Timer when
using the Shared Memory MPCI driver.
* score/include/rtems/score/mpci.h,
score/inline/rtems/score/threadmp.inl, score/src/mpci.c: Eliminate
dependencies between MP .h files.
* libfs/src/nfsclient/src/rpcio.c: Correct breakage introduced by Joel
removing asserts with side-effects.
* cpu.c: Stop using old-style defs.
* cpu.c, rtems/score/cpu.h: Convert to "bool".
* rtems/new-exceptions/cpu.h, rtems/score/cpu.h: Convert to "bool".
* sapi/include/rtems/config.h,
sapi/inline/rtems/chain.inl,
sapi/inline/rtems/extension.inl,
sapi/src/debug.c,
sapi/src/extension.c,
sapi/src/ioregisterdriver.c: Convert to "bool".
* rtems/src/clocktodvalidate.c,
rtems/src/intrbody.c,
rtems/src/msgmp.c,
rtems/src/msgqcreate.c,
rtems/src/msgqreceive.c,
rtems/src/partmp.c,
rtems/src/regionmp.c,
rtems/src/semmp.c,
rtems/src/signalsend.c,
rtems/src/taskcreate.c,
rtems/src/taskmode.c,
rtems/src/taskmp.c,
rtems/src/tasks.c,
rtems/src/timerserver.c,
rtems/src/workspace.c: Convert to "bool".
* rtems/inline/rtems/rtems/asr.inl,
rtems/inline/rtems/rtems/attr.inl,
rtems/inline/rtems/rtems/barrier.inl,
rtems/inline/rtems/rtems/dpmem.inl,
rtems/inline/rtems/rtems/eventset.inl,
rtems/inline/rtems/rtems/message.inl,
rtems/inline/rtems/rtems/modes.inl,
rtems/inline/rtems/rtems/options.inl,
rtems/inline/rtems/rtems/part.inl,
rtems/inline/rtems/rtems/ratemon.inl,
rtems/inline/rtems/rtems/region.inl,
rtems/inline/rtems/rtems/sem.inl,
rtems/inline/rtems/rtems/status.inl,
rtems/inline/rtems/rtems/support.inl,
rtems/inline/rtems/rtems/tasks.inl,
rtems/inline/rtems/rtems/timer.inl: Convert to "bool".
* rtems/include/rtems/rtems/asr.h,
rtems/include/rtems/rtems/clock.h,
rtems/include/rtems/rtems/config.h,
rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/sem.h,
rtems/include/rtems/rtems/support.h: Convert to "bool".
* score/src/corebarrierwait.c,
score/src/coremutexseize.c,
score/src/corerwlockobtainread.c,
score/src/corerwlockobtainwrite.c,
score/src/corespinlockwait.c,
score/src/heapfree.c,
score/src/heapresizeblock.c,
score/src/heapsizeofuserarea.c,
score/src/heapwalk.c,
score/src/interr.c,
score/src/objectinitializeinformation.c,
score/src/objectmp.c,
score/src/objectnametoid.c,
score/src/objectsetname.c,
score/src/pheapextend.c,
score/src/pheapfree.c,
score/src/pheapgetblocksize.c,
score/src/pheapresizeblock.c,
score/src/pheapwalk.c,
score/src/threadchangepriority.c,
score/src/threaddispatch.c,
score/src/threadevaluatemode.c,
score/src/threadinitialize.c,
score/src/threadloadenv.c,
score/src/threadqextractwithproxy.c,
score/src/threadrestart.c,
score/src/threadresume.c,
score/src/threadstart.c,
score/src/timespecgreaterthan.c,
score/src/timespecisvalid.c,
score/src/timespeclessthan.c,
score/src/userextthreadbegin.c,
score/src/userextthreadcreate.c,
score/src/wkspace.c: Convert to "bool".
* score/inline/rtems/score/address.inl,
score/inline/rtems/score/chain.inl,
score/inline/rtems/score/corebarrier.inl,
score/inline/rtems/score/coremsg.inl,
score/inline/rtems/score/coremutex.inl,
score/inline/rtems/score/coresem.inl,
score/inline/rtems/score/corespinlock.inl,
score/inline/rtems/score/heap.inl,
score/inline/rtems/score/isr.inl,
score/inline/rtems/score/mppkt.inl,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/objectmp.inl,
score/inline/rtems/score/priority.inl,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/states.inl,
score/inline/rtems/score/sysstate.inl,
score/inline/rtems/score/thread.inl,
score/inline/rtems/score/tqdata.inl,
score/inline/rtems/score/watchdog.inl:
Convert to "bool".
score/include/rtems/score/context.h,
score/include/rtems/score/corerwlock.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/corespinlock.h,
score/include/rtems/score/heap.h,
score/include/rtems/score/interr.h,
score/include/rtems/score/isr.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/protectedheap.h,
score/include/rtems/score/sysstate.h,
score/include/rtems/score/threadq.h,
score/include/rtems/score/timespec.h,
score/include/rtems/score/tod.h,
score/include/rtems/score/userext.h,
score/include/rtems/score/wkspace.h:
Convert to "bool".
* score/src/object.c: Stop using old-style function definitions.
* itron/include/rtems/itron/mbox.h,
itron/include/rtems/itron/msgbuffer.h,
itron/include/rtems/itron/semaphore.h,
itron/inline/rtems/itron/eventflags.inl,
itron/inline/rtems/itron/fmempool.inl,
itron/inline/rtems/itron/mbox.inl,
itron/inline/rtems/itron/msgbuffer.inl,
itron/inline/rtems/itron/port.inl,
itron/inline/rtems/itron/semaphore.inl,
itron/inline/rtems/itron/task.inl,
itron/inline/rtems/itron/vmempool.inl,
itron/src/cre_tsk.c, itron/src/sta_tsk.c,
itron/src/task.c, itron/src/trcv_mbf.c,
itron/src/trcv_mbx.c, itron/src/tsnd_mbf.c,
itron/src/twai_sem.c: Convert to "bool".
* posix/include/rtems/posix/cond.h,
posix/include/rtems/posix/key.h,
posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/timer.h: Convert to "bool".
* posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/key.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/inline/rtems/posix/timer.inl: Convert to "bool".
* posix/src/cancel.c,
posix/src/condsignalsupp.c,
posix/src/condtimedwait.c,
posix/src/condwaitsupp.c,
posix/src/keyrundestructors.c,
posix/src/killinfo.c,
posix/src/mqueuerecvsupp.c,
posix/src/mqueuesendsupp.c,
posix/src/mqueuetimedreceive.c,
posix/src/mqueuetimedsend.c,
posix/src/mutexlocksupp.c,
posix/src/mutextimedlock.c,
posix/src/prwlocktimedrdlock.c,
posix/src/prwlocktimedwrlock.c,
posix/src/psignal.c,
posix/src/psignalunblockthread.c,
posix/src/pthread.c,
posix/src/pthreadcreate.c,
posix/src/pthreadkill.c,
posix/src/pthreadsigmask.c,
posix/src/semaphorewaitsupp.c,
posix/src/semtimedwait.c,
posix/src/setcancelstate.c,
posix/src/setcanceltype.c,
posix/src/sigtimedwait.c,
posix/src/testcancel.c,
posix/src/timerinserthelper.c,
posix/src/timersettime.c,
posix/src/timertsr.c: Convert to "bool".
* libnetworking/lib/ftpfs.c: Use bool instead of boolean.
