2018-10-10 | build: Merge libpci/Makefile.am | Sebastian Huber | 4 | -41/+26 | |
2018-10-10 | build: Merge libmd/Makefile.am | Sebastian Huber | 4 | -20/+9 | |
2018-10-10 | build: Merge libi2c/Makefile.am | Sebastian Huber | 4 | -10/+1 | |
2018-10-10 | build: Merge libgnat/Makefile.am | Sebastian Huber | 4 | -16/+7 | |
2018-10-10 | build: Merge libfs/Makefile.am | Sebastian Huber | 5 | -186/+177 | |
2018-10-09 | build: Merge libdrvmgr/Makefile.am | Sebastian Huber | 4 | -38/+23 | |
2018-10-09 | build: Merge libdl/Makefile.am | Sebastian Huber | 4 | -41/+29 | |
2018-10-09 | build: Merge libdebugger/Makefile.am | Sebastian Huber | 3 | -24/+20 | |
2018-10-09 | build: Merge libcsupport/Makefile.am | Sebastian Huber | 4 | -138/+195 | |
2018-10-09 | build: Merge libcrypt/Makefile.am | Sebastian Huber | 4 | -15/+5 | |
2018-10-09 | build: Merge libblock/Makefile.am | Sebastian Huber | 4 | -43/+31 | |
2018-10-09 | build: Merge libfdt/Makefile.am | Sebastian Huber | 4 | -18/+8 | |
2018-10-09 | build: Merge ftpd/Makefile.am | Sebastian Huber | 3 | -13/+13 | |
2018-10-09 | build: Merge dev/Makefile.am | Sebastian Huber | 4 | -26/+14 | |
2018-10-09 | build: Move sapi/Makefile.am | Sebastian Huber | 6 | -66/+76 | |
2018-10-09 | build: Remove specialized CPPFLAGS | Sebastian Huber | 30 | -37/+0 | |
2018-10-09 | shell: Use #include "..." for local header files | Sebastian Huber | 30 | -37/+36 | |
Update #3375. | |||||
2018-10-09 | telnetd: Ignore setsockopt() return status | Sebastian Huber | 2 | -2/+2 | |
Update #3529. | |||||
2018-10-09 | ftpd: Restructure chroot() handling. | Sebastian Huber | 1 | -7/+3 | |
Remove superfluous setting of errno = 0. Update #3530. | |||||
2018-10-09 | leon, spwtdp: Initial driver commit | Javier Jalle | 1 | -0/+4 | |
2018-10-09 | posix: Remove static assertion | Sebastian Huber | 1 | -2/+0 | |
Standard C does not allow pointer operands in an integer constant expressions. GCC issues only a -Wpedantic warning in the removed static assertion. However, clang is pedantic by default and issues an error. Rely on the test case instead. | |||||
2018-10-08 | ftpd: Remove superfluous temporary buffer | Sebastian Huber | 1 | -31/+15 | |
2018-10-08 | ftpd: Check return status of getsockname() | Sebastian Huber | 1 | -18/+22 | |
2018-10-05 | ftpd: Fix insecure chroot() handling | Sebastian Huber | 1 | -8/+9 | |
Ensure that the rtems_libio_set_private_env() was successful before the chroot(). Update #3530. | |||||
2018-10-05 | ftpd: Avoid resource leak | Sebastian Huber | 1 | -0/+2 | |
2018-10-05 | ftpd: Avoid use of uninitialized memory | Sebastian Huber | 1 | -8/+7 | |
2018-10-05 | ftpd: Avoid malloc() and sscanf() | Sebastian Huber | 1 | -4/+3 | |
Move the user name to the session information. Update #3530. | |||||
2018-10-05 | ftpd: Remove FTPD_SessionInfo_t::pass member | Sebastian Huber | 1 | -9/+1 | |
There is no need to keep the password throughout the session. Update #3530. | |||||
2018-10-05 | ftpd: Avoid NULL pointer checks before free() | Sebastian Huber | 1 | -10/+5 | |
They are superfluous and just bloat the code. Update #3530. | |||||
2018-10-05 | jffs2: Avoid use of constant register variable | Sebastian Huber | 1 | -0/+12 | |
Avoid the use of a constant register variable which is used in some conditions. This gets rid of a clang -Wsometimes-uninitialized warning. | |||||
2018-10-05 | Fix rbtree_postorder_for_each_entry_safe() | Sebastian Huber | 1 | -2/+2 | |
Use the non-standard typeof operator to avoid code generation errors with clang and use of uninitialized variable warnings with GCC and Coverity Scan. Update #3465. | |||||
2018-10-05 | score: Fix legacy RTEMS_STATIC_ASSERT() | Sebastian Huber | 7 | -11/+25 | |
In standard C pointer operands are not allowed in integer constant expressions. Avoid a static assertion based on an array typedef since this could lead to warnings ("variably modified 'x' at file scope" and "typedef 'x' locally defined but not used"); This implementation requires unique messages. | |||||
2018-10-05 | score: Remove CPU_PROVIDES_IDLE_THREAD_BODY | Sebastian Huber | 35 | -504/+53 | |
Remove the CPU_PROVIDES_IDLE_THREAD_BODY option to avoid unnecessary conditional compilation. Close #3539. | |||||
2018-10-05 | dev/sc16is752: Deal with a baud of zero | Sebastian Huber | 1 | -8/+13 | |
Avoid division by zero and instead disable rx/tx in case of a zero baud value. Problem identified by Coverity Scan. | |||||
2018-10-04 | Add rtems_interrupt_server_request_set_vector() | Sebastian Huber | 1 | -0/+27 | |
By default, the interrupt vector of an interrupt server request is set to a special value which is outside the range of vectors supported by the interrupt controller hardware. Add rtems_interrupt_server_request_set_vector() to set the interrupt vector in an interrupt server request. Calls to rtems_interrupt_server_request_submit() will disable the interrupt vector of the request. After processing of the request by the interrupt server the interrupt vector will be enabled again. | |||||
2018-10-04 | Optimize calloc() | Sebastian Huber | 1 | -4/+5 | |
Use return value of memset() to enable tail call optimizations. | |||||
2018-10-04 | Avoid need for -fno-builtin for calloc() | Sebastian Huber | 1 | -0/+2 | |
Use RTEMS_OBFUSCATE_VARIABLE() instead. | |||||
2018-10-04 | Remove superfluous pipe_create() | Sebastian Huber | 4 | -50/+5 | |
2018-10-04 | Rename files to make them unique within cpukit | Sebastian Huber | 8 | -4/+4 | |
This allows to build librtemscpu.a in one rush in the future. | |||||
2018-10-04 | libdl: Avoid command line defines | Sebastian Huber | 2 | -1/+3 | |
2018-10-04 | mghttpd: Add configuration to source file | Sebastian Huber | 2 | -2/+4 | |
2018-10-04 | pppd: Simplify Makefile.am | Sebastian Huber | 1 | -1/+1 | |
2018-10-04 | rpc: Use configuration header file | Sebastian Huber | 39 | -4/+115 | |
2018-10-02 | Use rtems_task_exit() | Sebastian Huber | 17 | -32/+31 | |
Update #3530. Update #3533. | |||||
2018-10-01 | rtems: Add rtems_task_exit() | Sebastian Huber | 3 | -0/+41 | |
2018-10-01 | telnetd: Remove CEXP convenience routines | Sebastian Huber | 1 | -25/+0 | |
Close #3535. | |||||
2018-10-01 | telnetd: Remove CONFIGURE_MAXIMUM_PTYS | Sebastian Huber | 3 | -66/+75 | |
Add a rtems_telnetd_config_table::client_maximum member to the Telnet configuration. Close #3526. Close #3528. | |||||
2018-10-01 | telnetd: Regroup includes | Sebastian Huber | 1 | -7/+5 | |
2018-10-01 | telnetd: Remove dead code | Sebastian Huber | 1 | -7/+0 | |
2018-10-01 | telnetd: Remove superfluous global variable | Sebastian Huber | 1 | -9/+7 | |
Update #3528. |
