* rtems/score/cpu.h: Add doxygen preamble.
* rtems/score/cpu_asm.h: Add doxygen preamble.
* rtems/score/or32.h: Add doxygen preamble.
* rtems/score/types.h: Add doxygen preamble.
* rtems/score/mips.h: Add doxygen preamble.
* rtems/score/m68k.h: Add doxygen preamble.
* rtems/score/i386.h: Add doxygen preamble.
* rtems/score/idtr.h: Add doxygen preamble.
* rtems/score/interrupts.h: Add doxygen preamble.
* rtems/score/registers.h: Add doxygen preamble.
* rtems/score/h8300.h: Add doxygen preamble.
* rtems/score/c4x.h: Add doxygen preamble.
* rtems/score/avr.h: Add doxygen preamble.
* rtems/score/arm.h: Add doxygen preamble.
* libmisc/monitor/mon-manager.c, libmisc/monitor/mon-object.c: Remove
references to _Object_Is_local in single processor configurations.
* score/src/coresemsurrender.c, score/src/objectnametoid.c: All
_Objects_Is_Local... should only be called if multiprocessing is
enabled.
* score/include/rtems/score/object.h, score/src/object.c,
score/src/objectallocatebyindex.c, score/src/objectcomparenameraw.c,
score/src/objectinitializeinformation.c: Fix bugs in previous commit.
Now compiles.
* rtems/include/rtems/rtems/tasks.h, rtems/src/taskstart.c:
rtems_task_start(..., rtems_task_argument argument );
* score/cpu/no_cpu/rtems/score/cpu.h, score/include/rtems/debug.h,
score/include/rtems/seterr.h, score/include/rtems/system.h,
score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/apimutex.h,
score/include/rtems/score/bitfield.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/context.h,
score/include/rtems/score/copyrt.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/heap.h, score/include/rtems/score/interr.h,
score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/sysstate.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h,
score/include/rtems/score/tqdata.h,
score/include/rtems/score/userext.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h,
score/inline/rtems/score/address.inl,
score/inline/rtems/score/chain.inl,
score/inline/rtems/score/coremsg.inl,
score/inline/rtems/score/coremutex.inl,
score/inline/rtems/score/coresem.inl,
score/inline/rtems/score/heap.inl, score/inline/rtems/score/isr.inl,
score/inline/rtems/score/mppkt.inl,
score/inline/rtems/score/objectmp.inl,
score/inline/rtems/score/priority.inl,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/states.inl,
score/inline/rtems/score/sysstate.inl,
score/inline/rtems/score/thread.inl,
score/inline/rtems/score/threadmp.inl,
score/inline/rtems/score/tod.inl,
score/inline/rtems/score/tqdata.inl,
score/inline/rtems/score/userext.inl,
score/inline/rtems/score/watchdog.inl,
score/inline/rtems/score/wkspace.inl: Add Doxygen comments -- working
modifications which are not complete and may have broken code.
Committing so work and testing can proceed.
* score/Doxyfile, score/mainpage.h: New files.
* libmisc/monitor/monitor.h: Let rtems_monitor_config_dump return int.
* libmisc/monitor/mon-config.c: Ditto. Use PRI*N macros.
* libmisc/monitor/mon-itask.c, libmisc/monitor/mon-prmisc.c: Use
PRI*N macros.
score/inline/rtems/score/object.inl,
score/macros/rtems/score/object.inl: Add first cut of optional
16 bit object Id as space reduction for small systems (TinyRTEMS).
* monitor/monitor.h: Let rtems_monitor_config_dump return int.
* monitor/mon-config.c: Ditto. Use PRI*N macros.
* monitor/mon-itask.c, monitor/mon-prmisc.c: Use PRI*N macros.
* configure.ac: Remove -ansi (Cygwin breaks with it).
* libcsupport/include/stdint.h: Use sys/_stdint.h to setup fixed
size types.
* libcsupport/include/sys/_inttypes.h: Add SCN*N macros.
* libcsupport/src/utsname.c: Revert yesterdays patch.
* rtems/score/types.h: s/no_cpu/avr/g.
Use POSIX types from rtems/stdint.h.
* libcsupport/src/utsname.c: Fix typo.
* score/src/coremsg.c: Eliminate unsigned32.
* score/include/rtems/system.h: Set __RTEMS_REVISION__ to 99.
* librpc/include/rpc/xdr.h: Use elipsis in xdrproc_t prototype.
* libcsupport/include/inttypes.h: #include <sys/_inttypes.h>
* libcsupport/src/utsname.c: Don't include sptables.h.
Include <inttypes.h>. Use PRId32 instead of "%d".
* libcsupport/include/rtems/_inttypes.h: Remove.
* libcsupport/include/rtems/_stdint.h: Remove.
* libcsupport/include/sys/_inttypes.h: New.
* libcsupport/include/sys/_stdint.h: New.
* libcsupport/Makefile.am: Reflect changes above.
* configure.ac: Remove RTEMS_CPUOPT([RTEMS_MULTILIBS],..).
(Unused).
* monitor/mon-prmisc.c, monitor/monitor.h: Let rtems_monitor_dump
return int's not uint32_t (They are printf return values).
* configure.ac: Add score/cpu/no_cpu/Makefile.
* Makefile.am, configure.ac: Add httpd.
* httpd/asp.c, httpd/balloc.c, httpd/cgi.c, httpd/default.c,
httpd/ej.h, httpd/ejIntrn.h, httpd/ejlex.c, httpd/ejparse.c,
httpd/emfdb.c, httpd/emfdb.h, httpd/form.c, httpd/handler.c,
httpd/h.c, httpd/license.txt, httpd/Makefile.am, httpd/md5c.c,
httpd/md5.h, httpd/mime.c, httpd/misc.c, httpd/NOTES, httpd/ringq.c,
httpd/rom.c, httpd/rtems_webserver.h, httpd/security.c,
httpd/sock.c, httpd/socket.c, httpd/sockGen.c, httpd/sym.c,
httpd/uemf.c, httpd/uemf.h, httpd/um.c, httpd/um.h, httpd/umui.c,
httpd/url.c, httpd/value.c, httpd/wbase64.c, httpd/webcomp.c,
httpd/webmain.c, httpd/webpage.c, httpd/webrom.c, httpd/webs.c,
httpd/websda.c, httpd/websda.h, httpd/webs.h, httpd/websSSL.c,
httpd/websSSL.h, httpd/websuemf.c, httpd/wsIntrn.h: New (Moved from
c/src/libnetworking/rtems_webserver).
* httpd/Makefile.am: Install libhttpd.a.
* libcsupport/include/rtems/_inttypes.h: Undefine __PRIN defines.
* libcsupport/include/rtems/_stdint.h: Apply GNUC-limits to GCC >= 3.3, only.
Add _rtems_*_t_defined defines. Add extern "C".
* libcsupport/rtems/_stdint.h: New.
* libcsupport/rtems/_inttypes.h: New.
* libcsupport/include/sys/ioctl.h: Cosmetical update from FreeBSD.
Remove sys/compat_ioctl.h section (Meaningless with RTEMS).
* libfs/src/dosfs/msdos_conv.c:
Replace BSD fixed-size types with POSIX fixed-size types.
Replace SECONDSTO1980 with DAYSTO1980.
Make macros 16bit clean.
* libcsupport/include/sys/ioccom.h: Cosmetical update from FreeBSD.
* libnetworking/Makefile.am: Reflect changes below.
* libnetworking/net/slcompress.h: New (from FreeBSD).
* libnetworking/net/slcompress.c: New (from FreeBSD).
* libnetworking/kern/kern_sysctl.c: Remove uintptr_t.
Cosmetics.
* libnetworking/opt_compat.h: New.
* libcsupport/include/stdint.h: Add intptr_t uintptr_t.
