Fix the documentation.
Update #4181.
This directive has no implementation. It is documented in the RTEMS
Classic API Guide.
It was added by
commit 6c06288f6452da96fa630f1482aeaaba5d217531
Author: Joel Sherrill <joel.sherrill@OARcorp.com>
Date: Tue Jan 29 21:52:21 2008 +0000
without an implementation. The later change
commit fdc57ca4b6794dc17c7b7d94ae557da21e314d6a
Date: Mon Nov 23 14:53:04 2009 +0000
renamed the similar rtems_object_id_api_minimum_class() in
rtems_object_api_minimum_class().
The rtems_object_api_maximum_class() is documented and implemented. It
can be assumed that the rtems_object_id_api_maximum_class() is a
fragement left over from development.
In order to better support applications which use the new
rtems_task_construct() directive add the
CONFIGURE_INIT_TASK_CONSTURCT_STORAGE_SIZE configuration option. If
this option is specified, then the Classic API initialization task is
constructed with rtems_task_construct().
Update #4181.
Replace a runtime check with a compile time assertion. This makes the
INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL obsolete.
Update #4181.
Change the _Per_CPU_Information declaration so that Doxygen can parse
it. This attribute placement is also in line with the _Alignas()
specifier of C11.
This resolves a warning in the exception frame dump for AArch64 relating
to a missized printf format specifier.
It is only used by rtems_partition_create().
It is only used by rtems_partition_create(). Fix integer types.
It is only used by rtems_partition_create(). Move code directly into
directive which called the inline function. Add a comment.
the directive which called the inline function. Add a comment.
It is used only by rtems_partition_return_buffer(). Make the PTCB the
first parameter. Rename to _Partition_Is_address_on_buffer_boundary().
It is used only in one place. Make the PTCB the first parameter.
Rename it to _Partition_Is_address_a_buffer_begin().
Bug was introduced by 78baeb757957fa0807c30e6c4d21ae99c9639e6a.
Update #3199.
It was a trivial function call wrapper used only in one place.
It is only used by rtems_partition_return_buffer().
It is only used by rtems_partition_get_buffer().
This define was only used in one place.
Use a top-level implementation group to gather implementation related
files. The use of "Impl" is shorter and matches with the *impl.h file
names.
Modify the MPU functions of the stm32h7 BSP to be table based and
available for all ARMV7M BSPs.
Update #4180
Commit 21af87199297460470578479293ec6bc8c4e04b2 accidentally removed the
RTEMS_COMPILER_UNUSED_ATTRIBUTE and added RTEMS_COMPILER_USED_ATTRIBUTE.
Register a custom task stack allocator initialization handler only if
necessary.
Replace runtime checks with compile time assertions. This makes the
INTERNAL_ERROR_BAD_STACK_HOOK obsolete.
Report all runtime measurement environments with a name only and encode
the worker count of the "Load" environment in the name.
Update #3199.
Allow assert checks in test begin actions and setup fixture methods.
This name better reflects the execution envirnoment in which the cache
is fully loaded with valid data unrelated to the body request handler.
This primitive test case memory allocator uses memory from the low-level
memory information provided by the BSP. At the beginning of each test
case, the memory available to the test case is reinitialized. This
allows the use of a simple allocate only allocator.
Use the test case allocator functions T_zalloc() and T_malloc().
Restore the task affinity of the runner task.
This ensures that the saved SP register is sized appropriately depending
on the chosen ABI and prevents a warning in the libmisc stack checker.
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
