1997-03-10 | added include of rtems.h so the proper macro definitions would be present. | Joel Sherrill | 1 | -0/+2 | |
1997-03-10 | initialized a stack variable to avoid a warning. | Joel Sherrill | 1 | -1/+1 | |
1997-03-10 | created. Split getpid() from types.c to allow it to be overridden by | Joel Sherrill | 1 | -0/+22 | |
cxe1001 of the ACVC 2.0.1. This allows gnat/rtems to pass the partition tests. | |||||
1997-03-10 | Fixed bug where the initial detachstate was not being set properly | Joel Sherrill | 1 | -1/+1 | |
1997-03-08 | Modified calls to _Thread_Change_priority to take a third argument. The new | Joel Sherrill | 4 | -14/+48 | |
argument indicates whether the task is to be placed at the head or tail of its priority fifo when it is lowering its own priority. POSIX normally follows the RTEMS API conventions but GNAT expects that all lowering of a task's priority by the task itself will result in being placed at the head of the priority FIFO. Normally, this would only occur as the result of lose of inherited priority. | |||||
1997-03-08 | Modified calls to _Thread_Change_priority to take a third argument. The new | Joel Sherrill | 1 | -1/+1 | |
argument indicates whether the task is to be placed at the head or tail of its priority fifo when it is lowering its own priority. POSIX normally follows the RTEMS API conventions but GNAT expects that all lowering of a task's priority by the task itself will result in being placed at the head of the priority FIFO. Normally, this would only occur as the result of lose of inherited priority. The RTEMS API always puts tasks at the end of their priority group except upon loss of inherited priority. | |||||
1997-03-08 | Removed getpid from this file and made it its own file. This lets it | Joel Sherrill | 1 | -10/+0 | |
get replaced as required. | |||||
1997-03-08 | Added commit to indicate exepcted _Thread_Dispatch_disable_level. Hopefully | Joel Sherrill | 1 | -0/+4 | |
no one will ever get confused here again and try to enable dispatching. :( | |||||
1997-01-29 | Modifications to make go32 build using new i386-go32-rtems toolset | Joel Sherrill | 2 | -4/+7 | |
and gcc 2.8.x -specs options. | |||||
1997-01-29 | Merged newlib's libgloss support for rtems into this directory. This | Joel Sherrill | 4 | -32/+41 | |
should simplify the build process. | |||||
1997-01-29 | Removed definitions which are now in targopts.h. This eliminates the | Joel Sherrill | 1 | -8/+4 | |
need for the "sed'ing" of this file. This should be a significant win when addressing non-unix host and non-gnu toolsets. | |||||
1997-01-29 | added type to macro to eliminate warning for untyped use of a register. | Joel Sherrill | 1 | -1/+1 | |
1997-01-29 | Added include of targopts.h. | Joel Sherrill | 13 | -7/+20 | |
1997-01-28 | With the transition from command line macro definitions to targopts.h, | Joel Sherrill | 1 | -3/+2 | |
it was necessary to include system.h before checking if anything was defined. | |||||
1997-01-28 | Switch to using newlib's implementation of time(). | Joel Sherrill | 1 | -0/+3 | |
1997-01-15 | fixed comments on vanilla 68000 SW interrupt stack (or the lack thereof) | Joel Sherrill | 1 | -1/+2 | |
1997-01-08 | added some casts to reduce warnings reported by users with Microtec C++ | Joel Sherrill | 4 | -28/+35 | |
compiler. | |||||
1997-01-08 | added type definitions for all supported task entry formats | Joel Sherrill | 1 | -1/+6 | |
1996-12-02 | Suggested changes from Mark Jordan which eliminate warnings and errors | Joel Sherrill | 7 | -14/+19 | |
he received using the Microtec C++ compiler. Most of these are either missing casts from/to (void *), heavy handed use of enumerated types, or simply assumed conversions. There is at least one actual bug in an error path in thread.c in which the wrong argument was passed to _Thread_Stack_Free and was not being caught by gcc. | |||||
1996-12-02 | Changes to reflect new revision of erc32 per Jiri Gaisler's suggestions. | Joel Sherrill | 3 | -0/+25 | |
This is current as of sis 2.6. | |||||
1996-12-02 | Updates from Derrick Ostertag <ostertag@transition.com> to fix bug in | Joel Sherrill | 1 | -8/+15 | |
interrupt handling. | |||||
1996-12-02 | Update from Chris Johns <cjohns@awa.com.au> to add better support for | Joel Sherrill | 1 | -3/+19 | |
68000 class CPUs. | |||||
1996-11-08 | Added asserts for unhandled conditions which need to result in error | Joel Sherrill | 1 | -1/+8 | |
statuses being returned to gnat runtime in order for it to raise use_errors. This was needed to identify the places in gnat's runtime which needed to be addressed. | |||||
1996-10-15 | added ENOSYS support | Joel Sherrill | 1 | -0/+1 | |
1996-10-15 | added support for cpu time used field in tcb | Joel Sherrill | 1 | -0/+16 | |
1996-10-15 | added cpu time used field to tcb | Joel Sherrill | 1 | -0/+1 | |
1996-09-30 | fixed incorrect placement of CPU_STRUCTURE_ALIGNMENT macro. | Joel Sherrill | 1 | -2/+2 | |
1996-09-30 | changed stack size of posix initialization threads to double the minimum | Joel Sherrill | 1 | -0/+3 | |
stack size so more of acvc would pass. | |||||
1996-09-18 | pointer arithmetic reworked to be more portable | Joel Sherrill | 1 | -8/+8 | |
1996-09-18 | casts added to numerous arguments, prototypes corrected, and | Joel Sherrill | 10 | -22/+27 | |
proper include files added. | |||||
1996-09-18 | dummy function added to satisfy ANSI | Joel Sherrill | 2 | -0/+20 | |
1996-09-18 | modified to support non-GNU compilers and to use calloc rather than | Joel Sherrill | 1 | -3/+20 | |
malloc for per-thread reentrancy structure allocation. | |||||
1996-09-18 | added malloc_walk | Joel Sherrill | 1 | -4/+35 | |
miscellaneous corrections in casting. | |||||
1996-09-18 | added prototype for malloc_walk | Joel Sherrill | 1 | -0/+1 | |
1996-09-18 | loop to clear workspace memory changed to use sizeof rather than | Joel Sherrill | 1 | -1/+1 | |
hardcoded 4 to be compatible with CPUs with 64-bit ints | |||||
1996-09-18 | corrected prototype of _Objects_Get_next | Joel Sherrill | 1 | -1/+1 | |
1996-09-18 | uses address object rather than direct pointer arithmetic | Joel Sherrill | 1 | -2/+3 | |
1996-09-18 | OBJECTS_NAME_ALIGNMENT definition changed to use sizeof rather than | Joel Sherrill | 1 | -2/+2 | |
1996-09-18 | MP_PACKET_MINIMUN_HETERO_CONVERSION definition changed to use sizeof | Joel Sherrill | 1 | -1/+2 | |
rather than hardcoded 4 to be compatible with CPUs with 64-bit ints | |||||
1996-09-18 | modified declaration of CORE_message_queue_Buffer_control to avoid use | Joel Sherrill | 1 | -11/+4 | |
of GNU C extension | |||||
1996-09-18 | corrected white space problems | Joel Sherrill | 1 | -60/+62 | |
added CPU_STRUCTURE_ALIGNMENT to default context structures | |||||
1996-09-18 | new files submitted by Craig Lebakken (lebakken@minn.net) and Derrick Ostertag | Joel Sherrill | 4 | -0/+1327 | |
(ostertag@transition.com). | |||||
1996-09-17 | Reversed logic in conditional to correctly distinguish between | Joel Sherrill | 1 | -2/+2 | |
FIFO and priority disciplines. | |||||
1996-09-17 | added routine _POSIX_Timespec_subtract | Joel Sherrill | 1 | -0/+31 | |
1996-09-17 | Added code to insure that the post switch extension was executed and | Joel Sherrill | 1 | -0/+5 | |
to made signals sent to a particular thread from an ISR operated correctly. This behavior was required by the exception detection/reporting code in the gnat runtime. | |||||
1996-09-17 | Corrected implementation of timed wait on condition variables. First | Joel Sherrill | 1 | -29/+52 | |
the timeout is given as a wall-time not an interval as was previously implemented. Second, the interpretation of ETIMEDOUT behavior was incorrect as all possible error cases needed to be checked before this error was returned. This caused problems when the wall-time specified was in the past. | |||||
1996-09-17 | added prototype for _POSIX_Timespec_subtract | Joel Sherrill | 1 | -0/+11 | |
1996-09-11 | added $Id$ to file headers | Joel Sherrill | 15 | -8/+15 | |
cpu.h: added prototype for _CPU_ISR_Get_level() | |||||
1996-09-08 | moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to pthread.h so it would be | Joel Sherrill | 1 | -1/+0 | |
visible to other files. | |||||
1996-09-08 | Ada task stack size minimize is twice that for regular pthreads. | Joel Sherrill | 1 | -2/+2 | |
