* | 2008-12-18 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-12-18 | 3 | -7/+8 |
| | | | | * zutil.c, zutil.h: Make code match prototype to eliminate warnings. | ||||
* | #include <stdint.h> instead of <rtems/stdint.h>. | Ralf Corsepius | 2008-12-11 | 1 | -1/+1 |
* | 2008-09-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-02 | 1 | -0/+6 |
| | | | | | | * adler32.c, compress.c, crc32.c, deflate.c, gzio.c, infback.c, inflate.c, inffast.c, inftrees.c, trees.c, uncompr.c, zutil.c: Stop using old-style function definitions. | ||||
* | Stop using old-style function definitions. | Ralf Corsepius | 2008-09-02 | 1 | -18/+18 |
* | Stop using old-style function definitions. | Ralf Corsepius | 2008-09-02 | 12 | -345/+344 |
* | 2008-09-01 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-01 | 1 | -0/+7 |
| | | | | | | | * ChangeLog.zlib, README, adler32.c, compress.c, crc32.c, deflate.c, deflate.h, gzio.c, infback.c, inflate.c, inftrees.c, inftrees.h, trees.c, uncompr.c, zconf.h, zlib.3, zlib.h, zutil.c, zutil.h: Upgrade to zlib-1.2.3. | ||||
* | Upgrade to zlib-1.2.3. | Ralf Corsepius | 2008-09-01 | 19 | -115/+333 |
* | Add prototypes. | Ralf Corsepius | 2008-08-03 | 1 | -10/+10 |
* | This commit was generated by cvs2svn to compensate for changes in r16912, | Ralf Corsepius | 2008-02-18 | 1 | -0/+569 |
|\ | | | | | which included commits to RCS files with non-trunk default branches. | ||||
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2008-02-18 | 1 | -0/+569 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2008-02-17 | 1 | -41/+50 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2008-01-11 | 1 | -2/+2 |
* | | Regenerate. | Ralf Corsepius | 2007-01-08 | 1 | -2/+2 |
* | | This commit was generated by cvs2svn to compensate for changes in r13861, | Ralf Corsepius | 2006-10-14 | 1 | -0/+152 |
|\| | | | | | which included commits to RCS files with non-trunk default branches. | ||||
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2006-10-14 | 1 | -0/+152 |
* | | This commit was generated by cvs2svn to compensate for changes in r13747, | Ralf Corsepius | 2006-08-12 | 2 | -0/+556 |
| * | Import from zlib-1.2.5 | Ralf Corsepius | 2006-08-12 | 2 | -0/+556 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2006-08-12 | 2 | -126/+126 |
* | | This commit was generated by cvs2svn to compensate for changes in r13434, | Ralf Corsepius | 2006-05-28 | 1 | -0/+107 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2006-05-28 | 1 | -0/+107 |
* | | This commit was generated by cvs2svn to compensate for changes in r13387, | Ralf Corsepius | 2006-03-23 | 1 | -0/+12 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2006-03-23 | 1 | -0/+12 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2006-03-03 | 1 | -4/+4 |
* | | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 |
* | | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -0/+4 |
* | | Remove all-local. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -1/+1 |
* | | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -3/+3 |
* | | Cleanups | Ralf Corsepius | 2006-01-12 | 1 | -4/+0 |
* | | Regenerate. | Ralf Corsepius | 2006-01-10 | 1 | -4/+4 |
* | | This commit was generated by cvs2svn to compensate for changes in r12921, | Ralf Corsepius | 2005-12-11 | 1 | -0/+404 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2005-12-11 | 1 | -0/+404 |
* | | New | Ralf Corsepius | 2005-11-10 | 1 | -0/+2 |
* | | 2005-10-30 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-30 | 2 | -1/+8 |
| | | | | | | | | | | * zconf.h: Hard-code using unistd.h. Hard-code Z_PREFIX. | ||||
* | | 2005-10-28 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-28 | 1 | -0/+1 |
| | | | | | | | | * zconf.in.h: Remove (Unused). | ||||
* | | Remove (Unused) | Ralf Corsepius | 2005-10-28 | 1 | -330/+0 |
* | | 2005-10-28 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-28 | 1 | -0/+5 |
| | | | | | | | | | | * zconf.h: Use uint_least*_t types. * crc32.c, zutil.c, zutil.h: Misc. type fixes. | ||||
* | | Misc. type fixes | Ralf Corsepius | 2005-10-28 | 3 | -9/+9 |
* | | Use uint_least*_t types. | Ralf Corsepius | 2005-10-28 | 1 | -0/+9 |
| | | | | | | | | | | * Makefile.am: New. * preinstall.am: New. | ||||
* | | New. | Ralf Corsepius | 2005-10-28 | 2 | -0/+72 |
* | | * adler32.c, compress.c, crc32.c, deflate.c, deflate.h, gzio.c, | Ralf Corsepius | 2005-10-28 | 1 | -0/+6 |
| | | | | | | | | | | trees.c, uncompr.c, zconf.h, zconf.in.h, zutil.c, zutil.h: Reformat CVS Ids. | ||||
* | | Reformat CVS Ids | Ralf Corsepius | 2005-10-28 | 12 | -12/+12 |
* | | 2005-10-28 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-28 | 1 | -0/+9 |
| | | | | | | | | | | | | | | | | | | * ChangeLog.zlib: Renamed version of zlib's ChangeLog. * FAQ, INDEX, README, adler32.c, algorithm.txt, compress.c, crc32.c, crc32.h, deflate.c, deflate.h, gzio.c, infback.c, inffast.c, inffast.h, inffixed.h, inflate.c, inflate.h, trees.c, trees.h, uncompr.c, zconf.h, zconf.in.h, zlib.3, zlib.h, zutil.c, zutil.h, inftrees.h, inftrees.c, ChangeLog: Import from zlib-1.2.2.2.tar.gz. | ||||
* | | Remove. | Ralf Corsepius | 2005-10-28 | 5 | -1639/+0 |
* | | Rename the original ChangeLog to ChangeLog.zlib | Ralf Corsepius | 2005-10-28 | 1 | -0/+0 |
* | | Apply FC4's zlib-1.2.2.2-can-2005-2096.patch | Ralf Corsepius | 2005-10-28 | 1 | -1/+1 |
* | | Apply FC4's zlib-1.2.2.2-can-2005-1849.patch | Ralf Corsepius | 2005-10-28 | 1 | -4/+4 |
* | | Post-import cleanup | Ralf Corsepius | 2005-10-28 | 147 | -32362/+0 |
* | | This commit was generated by cvs2svn to compensate for changes in r12486, | Ralf Corsepius | 2005-10-28 | 1 | -9/+9 |
