for details.
* ChangeLog.zlib, adler32.c, compress.c, crc32.c,
deflate.c, deflate.h, gzguts.h, gzlib.c, gzread.c,
inffast.c, inffast.h, inftrees.c, inftrees.h,
trees.c, trees.h, uncompr.c, zlib.h, zutil.c, zutil.h:
Update to zlib-1.2.5.
* Makefile.am: Generate zconf.h from zconf.h.in.
* treebuild.xml, zconf.h.cmakein, zconf.h:
Remove (Import cleanup).
* win32/README-WIN32.txt, old/visualc6/README.txt,
old/visualc6/example.dsp, old/visualc6/minigzip.dsp,
old/visualc6/zlib.dsp, old/visualc6/zlib.dsw:
Remove (Import cleanup.).
* CMakeLists.txt, INDEX, zlib.3.pdf, zlib.3, zlib.map,
zlib.pc.in, zlib2ansi: Remove (Import cleanup.)
* nintendods/Makefile, nintendods/README,
old/as400/readme.txt, old/as400/zlib.inc, old/as400/bndsrc
old/as400/compile.clp,
watcom/watcom_l.mak, watcom/watcom_f.mak,
examples/enough.c, examples/zran.c, examples/gun.c:
* contrib/masmx86/match686.asm, contrib/gcc_gvmat64/gvmat64.S,
contrib/vstudio/vc10/zlibvc.def,
contrib/vstudio/vc10/miniunz.vcxproj.user,
contrib/vstudio/vc10/minizip.vcxproj.filters,
contrib/vstudio/vc10/testzlib.vcxproj.filters,
contrib/vstudio/vc10/zlibvc.sln,
contrib/vstudio/vc10/miniunz.vcxproj.filters,
contrib/vstudio/vc10/zlibvc.vcxproj,
contrib/vstudio/vc10/zlibvc.vcxproj.user,
contrib/vstudio/vc10/testzlib.vcxproj.user,
contrib/vstudio/vc10/zlib.rc,
contrib/vstudio/vc10/minizip.vcxproj,
contrib/vstudio/vc10/testzlibdll.vcxproj,
contrib/vstudio/vc10/testzlibdll.vcxproj.filters,
contrib/vstudio/vc10/zlibstat.vcxproj.filters,
contrib/vstudio/vc10/zlibvc.vcxproj.filters,
contrib/vstudio/vc10/testzlib.vcxproj,
contrib/vstudio/vc10/testzlibdll.vcxproj.user,
contrib/vstudio/vc10/zlibstat.vcxproj.user,
contrib/vstudio/vc10/miniunz.vcxproj,
contrib/vstudio/vc10/minizip.vcxproj.user,
contrib/vstudio/vc10/zlibstat.vcxproj,
contrib/vstudio/vc9/zlibvc.def,
contrib/vstudio/vc9/miniunz.vcproj,
contrib/vstudio/vc9/testzlib.vcproj,
contrib/vstudio/vc9/zlibvc.sln,
contrib/vstudio/vc9/zlibstat.vcproj,
contrib/vstudio/vc9/zlibvc.vcproj,
contrib/vstudio/vc9/zlib.rc,
contrib/vstudio/vc9/minizip.vcproj,
contrib/vstudio/vc9/testzlibdll.vcproj,
contrib/amd64/amd64-match.S,
contrib/minizip/make_vms.com,
contrib/minizip/MiniZip64_info.txt,
contrib/minizip/MiniZip64_Changes.txt:
* zconf.h: Regenerate by zlib's configure.
Eliminate HAVE_UNISTD_H. Use Z_PREFIX.
* zconf.h: Add include of config.h
eliminate unneeded comilation of 64 bit functions
Cherrypick from master 2011-03-18 10:11:29 UTC Joel Sherrill <joel.sherrill@OARcorp.com> '2010-03-22 Joel Sherrill <joel.sherrill@oarcorp.com>':
cpukit/zlib/doc/algorithm.txt
cpukit/zlib/gzclose.c
cpukit/zlib/gzguts.h
cpukit/zlib/gzlib.c
cpukit/zlib/gzread.c
cpukit/zlib/gzwrite.c
* ChangeLog.zlib, FAQ, Makefile.am, README, adler32.c, compress.c,
crc32.c, deflate.c, deflate.h, infback.c, inffast.c, inflate.c,
inflate.h, inftrees.c, inftrees.h, trees.c, uncompr.c, zconf.h,
zlib.3, zlib.h, zutil.c, zutil.h: Update to zlib 1.2.4.
* gzclose.c, gzguts.h, gzlib.c, gzread.c, gzwrite.c, doc/algorithm.txt:
New files.
* algorithm.txt, gzio.c: Removed.
