path: root/cpukit/zlib (follow)
* NewRalf Corsepius2005-11-101-0/+2
* 2005-10-30 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-10-302-1/+8
| | | | | * zconf.h: Hard-code using unistd.h. Hard-code Z_PREFIX.
* 2005-10-28 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-10-281-0/+1
| | | | * zconf.in.h: Remove (Unused).
* Remove (Unused)Ralf Corsepius2005-10-281-330/+0
* 2005-10-28 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-10-281-0/+5
| | | | | * zconf.h: Use uint_least*_t types. * crc32.c, zutil.c, zutil.h: Misc. type fixes.
* Misc. type fixesRalf Corsepius2005-10-283-9/+9
* Use uint_least*_t types.Ralf Corsepius2005-10-281-0/+9
| | | | | * Makefile.am: New. * preinstall.am: New.
* New.Ralf Corsepius2005-10-282-0/+72
* * adler32.c, compress.c, crc32.c, deflate.c, deflate.h, gzio.c,Ralf Corsepius2005-10-281-0/+6
| | | | | trees.c, uncompr.c, zconf.h, zconf.in.h, zutil.c, zutil.h: Reformat CVS Ids.
* Reformat CVS IdsRalf Corsepius2005-10-2812-12/+12
* 2005-10-28 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-10-281-0/+9
| | | | | | | | | * ChangeLog.zlib: Renamed version of zlib's ChangeLog. * FAQ, INDEX, README, adler32.c, algorithm.txt, compress.c, crc32.c, crc32.h, deflate.c, deflate.h, gzio.c, infback.c, inffast.c, inffast.h, inffixed.h, inflate.c, inflate.h, trees.c, trees.h, uncompr.c, zconf.h, zconf.in.h, zlib.3, zlib.h, zutil.c, zutil.h, inftrees.h, inftrees.c, ChangeLog: Import from zlib-1.2.2.2.tar.gz.
* Remove.Ralf Corsepius2005-10-285-1639/+0
* Rename the original ChangeLog to ChangeLog.zlibRalf Corsepius2005-10-281-0/+0
* Apply FC4's zlib-1.2.2.2-can-2005-2096.patchRalf Corsepius2005-10-281-1/+1
* Apply FC4's zlib-1.2.2.2-can-2005-1849.patchRalf Corsepius2005-10-281-4/+4
* Post-import cleanupRalf Corsepius2005-10-28147-32362/+0
* This commit was generated by cvs2svn to compensate for changes in r12486,Ralf Corsepius2005-10-281-9/+9
|\ | | | | which included commits to RCS files with non-trunk default branches.
| * Import from zlib-1.2.4Ralf Corsepius2005-10-281-9/+9
* | This commit was generated by cvs2svn to compensate for changes in r12484,Ralf Corsepius2005-10-283-7/+7
|\| | | | | which included commits to RCS files with non-trunk default branches.
| * Import from zlib-1.2.4Ralf Corsepius2005-10-283-7/+7
* | This commit was generated by cvs2svn to compensate for changes in r12482,Ralf Corsepius2005-10-281-5/+5
| * Import from zlib-1.2.4Ralf Corsepius2005-10-281-5/+5
* | This commit was generated by cvs2svn to compensate for changes in r12480,Ralf Corsepius2005-10-281-2/+2
| * Import from zlib-1.2.4Ralf Corsepius2005-10-281-2/+2
* | This commit was generated by cvs2svn to compensate for changes in r12478,Ralf Corsepius2005-10-281-10/+10
| * Import from zlib-1.2.4Ralf Corsepius2005-10-281-10/+10
* | This commit was generated by cvs2svn to compensate for changes in r12476,Ralf Corsepius2005-10-281-9/+9
* | This commit was generated by cvs2svn to compensate for changes in r12474,Ralf Corsepius2005-10-282-13/+13
| * Import from zlib-1.2.4Ralf Corsepius2005-10-282-13/+13
* | This commit was generated by cvs2svn to compensate for changes in r12472,Ralf Corsepius2005-10-281-2/+2
* | This commit was generated by cvs2svn to compensate for changes in r12470,Ralf Corsepius2005-10-28181-0/+46633
| * Import of zlib-1.2.2.2.tar.gzRalf Corsepius2005-10-28181-0/+46633
* | This commit was generated by cvs2svn to compensate for changes in r12147,Ralf Corsepius2005-07-182-0/+234
| * Import from zlib-1.2.4Ralf Corsepius2005-07-182-0/+234
| * Import from zlib-1.2.4Ralf Corsepius2005-02-061-0/+10
| * Import from zlib-1.2.4Ralf Corsepius2005-02-061-0/+2
* Import from zlib-1.2.5Ralf Corsepius2004-10-211-0/+73
* Import from zlib-1.2.5Ralf Corsepius2004-05-311-0/+59
* Import from zlib-1.2.4Ralf Corsepius2003-11-121-0/+132
* Import from zlib-1.2.4Ralf Corsepius1996-05-281-0/+675
* Import from zlib-1.2.4Ralf Corsepius1996-05-212-0/+1574
