path: root/cpukit/zlib (follow)
* This commit was manufactured by cvs2svn to create branch 'rtems-4-9-branch'.cvs2git2008-09-0915-4547/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Sprout from master 2008-09-09 18:14:52 UTC Joel Sherrill <joel.sherrill@OARcorp.com> '2008-09-09 Joel Sherrill <joel.sherrill@oarcorp.com>' Cherrypick from shttpd 2007-06-11 13:24:29 UTC Ralf Corsepius <ralf.corsepius@rtems.org> 'Import from shttpd-1.37.': cpukit/shttpd/auth.c cpukit/shttpd/cgi.c cpukit/shttpd/compat_unix.c cpukit/shttpd/compat_unix.h cpukit/shttpd/compat_win32.c cpukit/shttpd/compat_win32.h cpukit/shttpd/compat_wince.c cpukit/shttpd/compat_wince.h cpukit/shttpd/config.c cpukit/shttpd/io.h cpukit/shttpd/io_cgi.c cpukit/shttpd/io_dir.c cpukit/shttpd/io_emb.c cpukit/shttpd/io_file.c cpukit/shttpd/io_socket.c cpukit/shttpd/io_ssl.c cpukit/shttpd/llist.h cpukit/shttpd/md5.c cpukit/shttpd/md5.h cpukit/shttpd/mime_type.c cpukit/shttpd/shttpd.1 cpukit/shttpd/shttpd.c cpukit/shttpd/shttpd.h cpukit/shttpd/ssl.h cpukit/shttpd/standalone.c cpukit/shttpd/std_includes.h Cherrypick from B_rtems_mvme3100_bsp_slac 2007-12-14 06:30:15 UTC Till Straumann <strauman@slac.stanford.edu> ' - imported MVME3100 BSP (from SLAC repository)': c/src/lib/libbsp/powerpc/mvme3100/.cvsignore c/src/lib/libbsp/powerpc/mvme3100/KNOWN_PROBLEMS c/src/lib/libbsp/powerpc/mvme3100/LICENSE c/src/lib/libbsp/powerpc/mvme3100/README c/src/lib/libbsp/powerpc/mvme3100/bsp_specs c/src/lib/libbsp/powerpc/mvme3100/configure.ac c/src/lib/libbsp/powerpc/mvme3100/flash/flashcfg.c c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c_busdrv.h c/src/lib/libbsp/powerpc/mvme3100/include/bspopts.h.in c/src/lib/libbsp/powerpc/mvme3100/irq/irq.h c/src/lib/libbsp/powerpc/mvme3100/network/if_tsec_pub.h c/src/lib/libbsp/powerpc/mvme3100/startup/misc.c c/src/lib/libbsp/powerpc/mvme3100/tod/todcfg.c c/src/lib/libbsp/powerpc/mvme3100/vme/VMEConfig.h Cherrypick from zlib 2005-10-28 07:22:42 UTC Ralf Corsepius <ralf.corsepius@rtems.org> 'Import of zlib-1.2.2.2.tar.gz': cpukit/zlib/FAQ cpukit/zlib/INDEX cpukit/zlib/algorithm.txt cpukit/zlib/crc32.h cpukit/zlib/inffast.h cpukit/zlib/inffixed.h cpukit/zlib/inflate.h cpukit/zlib/trees.h Cherrypick from rtemsdoc-4-5-branch 1997-05-27 12:40:10 UTC Joel Sherrill <joel.sherrill@OARcorp.com> 'base RTEMS documentation': doc/common/treedef.tex Delete: contrib/crossrpms/cygwin/.cvsignore contrib/crossrpms/cygwin/Makefile.am contrib/crossrpms/cygwin/binutils.am contrib/crossrpms/cygwin/cygwin.am contrib/crossrpms/cygwin/expat.am contrib/crossrpms/cygwin/gcc-prep.add contrib/crossrpms/cygwin/gcc.am contrib/crossrpms/cygwin/gmp.am contrib/crossrpms/cygwin/i686/.cvsignore contrib/crossrpms/cygwin/i686/Makefile.am contrib/crossrpms/cygwin/i686/binutils-sources.add contrib/crossrpms/cygwin/i686/expat.add contrib/crossrpms/cygwin/i686/gcc-sources.add contrib/crossrpms/cygwin/i686/gmp.add contrib/crossrpms/cygwin/i686/libs.add contrib/crossrpms/cygwin/i686/mpfr.add contrib/crossrpms/cygwin/i686/ncurses.add contrib/crossrpms/cygwin/i686/readline.add contrib/crossrpms/cygwin/i686/target-expat.add contrib/crossrpms/cygwin/i686/target-gmp.add contrib/crossrpms/cygwin/i686/target-libs.add contrib/crossrpms/cygwin/i686/target-mpfr.add contrib/crossrpms/cygwin/i686/target-ncurses.add contrib/crossrpms/cygwin/i686/target-readline.add contrib/crossrpms/cygwin/i686/target-termcap.add contrib/crossrpms/cygwin/i686/target-terminfo.add contrib/crossrpms/cygwin/i686/target-w32api.add contrib/crossrpms/cygwin/i686/target-zlib.add contrib/crossrpms/cygwin/i686/termcap.add contrib/crossrpms/cygwin/i686/terminfo.add contrib/crossrpms/cygwin/i686/w32api.add contrib/crossrpms/cygwin/i686/zlib.add contrib/crossrpms/cygwin/mpfr.am contrib/crossrpms/cygwin/ncurses.am contrib/crossrpms/cygwin/readline.am contrib/crossrpms/cygwin/termcap.am contrib/crossrpms/cygwin/terminfo.am contrib/crossrpms/cygwin/w32api.am contrib/crossrpms/cygwin/zlib.am contrib/crossrpms/freebsd6.2/.cvsignore contrib/crossrpms/freebsd6.2/Makefile.am contrib/crossrpms/freebsd6.2/binutils.am contrib/crossrpms/freebsd6.2/gcc-prep.add contrib/crossrpms/freebsd6.2/gcc.am contrib/crossrpms/freebsd6.2/i586/.cvsignore contrib/crossrpms/freebsd6.2/i586/Makefile.am contrib/crossrpms/freebsd6.2/i586/binutils-sources.add contrib/crossrpms/freebsd6.2/i586/gcc-sources.add contrib/crossrpms/freebsd6.2/i586/libs.add contrib/crossrpms/freebsd6.2/i586/target-libs.add contrib/crossrpms/freebsd6.3/.cvsignore contrib/crossrpms/freebsd6.3/Makefile.am contrib/crossrpms/freebsd6.3/binutils.am contrib/crossrpms/freebsd6.3/gcc-prep.add contrib/crossrpms/freebsd6.3/gcc.am contrib/crossrpms/freebsd6.3/i586/.cvsignore contrib/crossrpms/freebsd6.3/i586/Makefile.am contrib/crossrpms/freebsd6.3/i586/binutils-sources.add contrib/crossrpms/freebsd6.3/i586/gcc-sources.add contrib/crossrpms/freebsd6.3/i586/libs.add contrib/crossrpms/freebsd6.3/i586/target-libs.add contrib/crossrpms/freebsd7.0/.cvsignore contrib/crossrpms/freebsd7.0/Makefile.am contrib/crossrpms/freebsd7.0/binutils.am contrib/crossrpms/freebsd7.0/gcc-prep.add contrib/crossrpms/freebsd7.0/gcc.am contrib/crossrpms/freebsd7.0/i586/.cvsignore contrib/crossrpms/freebsd7.0/i586/Makefile.am contrib/crossrpms/freebsd7.0/i586/binutils-sources.add contrib/crossrpms/freebsd7.0/i586/gcc-sources.add contrib/crossrpms/freebsd7.0/i586/libs.add contrib/crossrpms/freebsd7.0/i586/target-libs.add contrib/crossrpms/mingw32/.cvsignore contrib/crossrpms/mingw32/Makefile.am contrib/crossrpms/mingw32/binutils.am contrib/crossrpms/mingw32/gcc-prep.add contrib/crossrpms/mingw32/gcc.am contrib/crossrpms/mingw32/i686/.cvsignore contrib/crossrpms/mingw32/i686/Makefile.am contrib/crossrpms/mingw32/i686/binutils-sources.add contrib/crossrpms/mingw32/i686/gcc-sources.add contrib/crossrpms/mingw32/i686/libs.add contrib/crossrpms/mingw32/i686/target-libs.add contrib/crossrpms/mingw32/i686/target-w32api.add contrib/crossrpms/mingw32/i686/w32api.add contrib/crossrpms/solaris2.7/.cvsignore contrib/crossrpms/solaris2.7/Makefile.am contrib/crossrpms/solaris2.7/binutils.am contrib/crossrpms/solaris2.7/gcc-prep.add contrib/crossrpms/solaris2.7/gcc.am contrib/crossrpms/solaris2.7/sparc/.cvsignore contrib/crossrpms/solaris2.7/sparc/Makefile.am contrib/crossrpms/solaris2.7/sparc/binutils-sources.add contrib/crossrpms/solaris2.7/sparc/gcc-sources.add contrib/crossrpms/solaris2.7/sparc/libs.add contrib/crossrpms/solaris2.7/sparc/target-libs.add cpukit/zlib/doc/rfc1950.txt cpukit/zlib/doc/rfc1951.txt cpukit/zlib/doc/rfc1952.txt cpukit/zlib/doc/txtvsbin.txt cpukit/zlib/examples/enough.c cpukit/zlib/examples/zran.c cpukit/zlib/old/as400/bndsrc cpukit/zlib/old/as400/compile.clp cpukit/zlib/old/as400/readme.txt cpukit/zlib/old/visualc6/README.txt cpukit/zlib/old/visualc6/example.dsp cpukit/zlib/old/visualc6/minigzip.dsp cpukit/zlib/old/visualc6/zlib.dsw cpukit/zlib/zlib.pc.in cpukit/zlib/zlib2ansi
* 2008-09-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-021-0/+6
| | | | | | * adler32.c, compress.c, crc32.c, deflate.c, gzio.c, infback.c, inflate.c, inffast.c, inftrees.c, trees.c, uncompr.c, zutil.c: Stop using old-style function definitions.
* Stop using old-style function definitions.Ralf Corsepius2008-09-021-18/+18
* Stop using old-style function definitions.Ralf Corsepius2008-09-0212-345/+344
* 2008-09-01 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-011-0/+7
| | | | | | | * ChangeLog.zlib, README, adler32.c, compress.c, crc32.c, deflate.c, deflate.h, gzio.c, infback.c, inflate.c, inftrees.c, inftrees.h, trees.c, uncompr.c, zconf.h, zlib.3, zlib.h, zutil.c, zutil.h: Upgrade to zlib-1.2.3.
* Upgrade to zlib-1.2.3.Ralf Corsepius2008-09-0119-115/+333
* Add prototypes.Ralf Corsepius2008-08-031-10/+10
* This commit was generated by cvs2svn to compensate for changes in r16912,Ralf Corsepius2008-02-181-0/+569
|\ | | | | which included commits to RCS files with non-trunk default branches.
| * Import from zlib-1.2.4Ralf Corsepius2008-02-181-0/+569
| * Import from zlib-1.2.4Ralf Corsepius2008-02-171-41/+50
| * Import from zlib-1.2.4Ralf Corsepius2008-01-111-2/+2
* | Regenerate.Ralf Corsepius2007-01-081-2/+2
* | This commit was generated by cvs2svn to compensate for changes in r13861,Ralf Corsepius2006-10-141-0/+152
|\| | | | | which included commits to RCS files with non-trunk default branches.
| * Import from zlib-1.2.4Ralf Corsepius2006-10-141-0/+152
* | This commit was generated by cvs2svn to compensate for changes in r13747,Ralf Corsepius2006-08-122-0/+556
| * Import from zlib-1.2.5Ralf Corsepius2006-08-122-0/+556
| * Import from zlib-1.2.4Ralf Corsepius2006-08-122-126/+126
* | This commit was generated by cvs2svn to compensate for changes in r13434,Ralf Corsepius2006-05-281-0/+107
| * Import from zlib-1.2.4Ralf Corsepius2006-05-281-0/+107
* | This commit was generated by cvs2svn to compensate for changes in r13387,Ralf Corsepius2006-03-231-0/+12
| * Import from zlib-1.2.4Ralf Corsepius2006-03-231-0/+12
| * Import from zlib-1.2.4Ralf Corsepius2006-03-031-4/+4
* | Regenerate.Ralf Corsepius2006-01-141-1/+1
* | Regenerate.Ralf Corsepius2006-01-121-0/+4
* | Remove all-local.Ralf Corsepius2006-01-121-2/+0
* | Regenerate.Ralf Corsepius2006-01-121-1/+1
* | Regenerate.Ralf Corsepius2006-01-121-3/+3
* | CleanupsRalf Corsepius2006-01-121-4/+0
* | Regenerate.Ralf Corsepius2006-01-101-4/+4
* | This commit was generated by cvs2svn to compensate for changes in r12921,Ralf Corsepius2005-12-111-0/+404
| * Import from zlib-1.2.4Ralf Corsepius2005-12-111-0/+404
* | NewRalf Corsepius2005-11-101-0/+2
* | 2005-10-30 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-10-302-1/+8
| | | | | | | | | | * zconf.h: Hard-code using unistd.h. Hard-code Z_PREFIX.
* | 2005-10-28 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-10-281-0/+1
| | | | | | | | * zconf.in.h: Remove (Unused).
* | Remove (Unused)Ralf Corsepius2005-10-281-330/+0
* | 2005-10-28 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-10-281-0/+5
| | | | | | | | | | * zconf.h: Use uint_least*_t types. * crc32.c, zutil.c, zutil.h: Misc. type fixes.
* | Misc. type fixesRalf Corsepius2005-10-283-9/+9
* | Use uint_least*_t types.Ralf Corsepius2005-10-281-0/+9
| | | | | | | | | | * Makefile.am: New. * preinstall.am: New.
* | New.Ralf Corsepius2005-10-282-0/+72
* | * adler32.c, compress.c, crc32.c, deflate.c, deflate.h, gzio.c,Ralf Corsepius2005-10-281-0/+6
| | | | | | | | | | trees.c, uncompr.c, zconf.h, zconf.in.h, zutil.c, zutil.h: Reformat CVS Ids.
* | Reformat CVS IdsRalf Corsepius2005-10-2812-12/+12
* | 2005-10-28 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-10-281-0/+9
| | | | | | | | | | | | | | | | | | * ChangeLog.zlib: Renamed version of zlib's ChangeLog. * FAQ, INDEX, README, adler32.c, algorithm.txt, compress.c, crc32.c, crc32.h, deflate.c, deflate.h, gzio.c, infback.c, inffast.c, inffast.h, inffixed.h, inflate.c, inflate.h, trees.c, trees.h, uncompr.c, zconf.h, zconf.in.h, zlib.3, zlib.h, zutil.c, zutil.h, inftrees.h, inftrees.c, ChangeLog: Import from zlib-1.2.2.2.tar.gz.
* | Remove.Ralf Corsepius2005-10-285-1639/+0
* | Rename the original ChangeLog to ChangeLog.zlibRalf Corsepius2005-10-281-0/+0
* | Apply FC4's zlib-1.2.2.2-can-2005-2096.patchRalf Corsepius2005-10-281-1/+1
* | Apply FC4's zlib-1.2.2.2-can-2005-1849.patchRalf Corsepius2005-10-281-4/+4
* | Post-import cleanupRalf Corsepius2005-10-28147-32362/+0
* | This commit was generated by cvs2svn to compensate for changes in r12486,Ralf Corsepius2005-10-281-9/+9
| * Import from zlib-1.2.4Ralf Corsepius2005-10-281-9/+9
