path: root/cpukit/zlib/adler32.c (follow)
* Update to zlib-1.2.5.Ralf Corsepius2011-03-191-2/+0
* Make code match prototype to eliminate warnings.Thomas Doerfler2011-03-181-0/+2
| | | | eliminate unneeded comilation of 64 bit functions
* 2010-03-22 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-03-181-15/+35
| | | | | | | | | | * ChangeLog.zlib, FAQ, Makefile.am, README, adler32.c, compress.c, crc32.c, deflate.c, deflate.h, infback.c, inffast.c, inflate.c, inflate.h, inftrees.c, inftrees.h, trees.c, uncompr.c, zconf.h, zlib.3, zlib.h, zutil.c, zutil.h: Update to zlib 1.2.4. * gzclose.c, gzguts.h, gzlib.c, gzread.c, gzwrite.c, doc/algorithm.txt: New files. * algorithm.txt, gzio.c: Removed.
* Stop using old-style function definitions.Ralf Corsepius2008-09-021-8/+8
* Upgrade to zlib-1.2.3.Ralf Corsepius2008-09-011-1/+1
* Reformat CVS IdsRalf Corsepius2005-10-281-1/+1
* Import of zlib-1.2.2.2.tar.gzRalf Corsepius2005-10-281-0/+149
