* wrapup/Makefile.am: Add libmisc.
* wrapup/Makefile.am: Remove *_OBJS, use LIBS+= instead.
* configure.ac: Require autoconf >= 2.54, automake-1.7.2.
* wrapup/Makefile.am: Reflect changes to score/.
* configure.ac: Reflect changes to score/.
* wrapup/Makefile.am: Reflect changes to sapi/.
* configure.ac: Reflect changes to sapi/.
* wrapup/Makefile.am: Reflect changes to rtems/.
* configure.ac: Reflect changes to rtems/.
* wrapup/Makefile.am: Reflect changes to posix/.
Reflect changes to itron/.
* wrapup/Makefile.am: Use librtems.a.
* wrapup/Makefile.am: Use libsapi.a.
* wrapup/Makefile.am: Use libscore.a.
* wrapup/Makefile.am: LIBBLOCK_OBJS = ../libblock/$(ARCH)/libblock.a.
* configure.ac: Disable LIBRPC for the c4x.
Check for presence of score/cpu/${RTEMS_CPU}/cpu.c.
Let librtemscpu.a depend upon libscorecpu.a.
* wrapup/Makefile.am: Use project_libdir instead of
$(PROJECT_RELEASE)/lib. Eliminate LIBNAME. Pickup *.o's instead of
*.rels for CPU_OBJS. Manually create $(project_libdir)$(MULTISUBDIR).
* wrapup/Makefile.am: Install by using cpulibdir, cpulib_DATA.
* wrapup/Makefile.am: Fix stupid typo in previous patch.
* configure.ac: Add librpc. AC_PROG_RANLIB.
* wrapup/Makefile.am: Add librpc.
Use relative path to lib*.a for
POSIX_OBJS, ITRON_OBJS, NETWORKING_OBJS.
* wrapup/Makefile.am: Use relative path to lib*.a for
LIBCSUPPORT_OBJS, LIBBLOCK_OBJS, LIBDOSFS_OBJS, LIBIMFS_OBJS.
* Include $(top_srcdir)/automake/*.am.
* configure.ac: Add libnetworking.
* wrapup/Makefile.am: Ditto.
* configure.ac: Add libblock. Add libfs. Add AM_CONDITIONAL(UNIX).
* wrapup/Makefile.am: Add libblock, libfs/dosfs, libfs/imfs.
* configure.ac: Add libcsupport.
* wrapup/Makefile.am: Add install-hook.
Remove SIZE_RTEMS.
* include/rtems/fs.h: New, extracted from libio_.h.
* include/rtems/userenv.h: New. extracted from libio_.h.
* wrapup/.cvsignore: Readded.
* include/.cvsignore: New file.
* configure.ac: Use AS_IF instead of if/then/else.
Add AC_DEFINE_UNQUOTED(RTEMS_UNIX) for RTEMS_CPU==unix.
Add AC_DEFINE_UNQUOTED(RTEMS_UNIXLIB) for RTEMS_CPU==unix.
Add include/Makefile to CONFIG_FILES.
Add AC_ENABLE_MULITLIB.
Remove wrapup/rtems, wrapup/itron, wrapup/posix.
Remove */optman/Makefile from CONFIG_FILES.
* Makefile.am: Add include to SUBDIRS.
* rtems/Makefile.am: Remove optman from SUBDIRS.
* sapi/Makefile.am: Remove optman from SUBDIRS.
* include/Makefile.am: New file.
* include/rtems/bspIo.h: Relocated from lib/include.
* include/rtems/libio_.h: Relocated from lib/include.
for RTEMS.
