Add support to untar XZ compressed files.
This allows BSPs to use this library.
Disable an optimization which would lead to a recursive calloc() call in
calloc().
In case the zlib compression was used, then the librtemscpu.a depended
on libz.a. To avoid a GCC patch or complicated link flags move the
JFFS2 support into a separate library to use a simple "-ljffs2 -lz" to
link the executable.
Add crypt_add_format(), crypt_r(), crypt_md5_r(), crypt_sha256_r() and
crypt_sha512_r().
This I2C driver framework has some major differences compared to libi2c.
* It is compatible to the Linux I2C user-space API.
* It uses generic IMFS nodes and thus reduces the levels of indirection.
* The drivers don't have to mess around with minor numbers to get their
state information.
* No arbitrary bus controller model is assumed. The main task of an I2C
bus controller driver is to process I2C messages. How this is done is
private to the driver.
* Scatter/gather operations are supported (I2C_M_NOSTART).
This is a merge of the RTL project.
utf8proc is a small library for processing UTF-8 encoded Unicode strings.
Some features are Unicode normalization, stripping of default ignorable characters, case folding and detection of grapheme cluster boundaries.
For the time beeing utf8proc is intended to be used for normalizing and folding UTF-8 strings
for comparison purposes when adding UTF-8 support to the FAT file system.
for details.
PR 1762/cpukit
* Makefile.am, preinstall.am, libmisc/Makefile.am, wrapup/Makefile.am:
Add generic serial mouse driver and mouse parser. The parser code was
in the pc386 BSP but was generic so cleaned up and placed here.
Serial mouse driver itself is new.
* libmisc/mouse/README, libmisc/mouse/mouse_parser.c,
libmisc/mouse/mouse_parser.h, libmisc/mouse/serial_mouse.c,
libmisc/mouse/serial_mouse.h: New files.
* libfs/Makefile.am: Remove reference to imfs_free.c,
wrapup/Makefile.am: Split devfs into its own library.
* libfs/src/imfs/fifoimfs_init.c, libfs/src/imfs/imfs.h,
libfs/src/imfs/imfs_init.c, libfs/src/rfs/rtems-rfs-rtems.c:
Use default freenode implementation.
* libfs/src/imfs/imfs_free.c: Removed.
* libcsupport/include/rtems/libio.h, libfs/Makefile.am,
libfs/src/defaults/default_chown.c,
libfs/src/defaults/default_evalpath.c,
libfs/src/defaults/default_freenode.c,
libfs/src/defaults/default_fsmount.c,
libfs/src/defaults/default_link.c,
libfs/src/defaults/default_mount.c,
libfs/src/defaults/default_rename.c,
libfs/src/defaults/default_statvfs.c,
libfs/src/defaults/default_symlink.c,
libfs/src/defaults/default_unlink.c,
libfs/src/defaults/default_utime.c, libfs/src/devfs/devfs_init.c,
libfs/src/dosfs/msdos_init.c, libfs/src/imfs/imfs_init.c,
libfs/src/nfsclient/src/nfs.c, libfs/src/rfs/rtems-rfs-rtems.c,
wrapup/Makefile.am: Fixed typo in default names. Added default
methods into filesystem tables.
* libfs/src/defaults/default_close.c,
libfs/src/defaults/default_evaluate_link.c,
libfs/src/defaults/default_fpathconf.c,
libfs/src/defaults/default_fsunmount.c,
libfs/src/defaults/default_open.c,
libfs/src/defaults/default_unmount.c: New files.
* libfs/src/rfs/rtems-rfs-bitmaps.c,
libfs/src/rfs/rtems-rfs-bitmaps.h,
libfs/src/rfs/rtems-rfs-bitmaps-ut.c,
libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-block.h,
libfs/src/rfs/rtems-rfs-block-pos.h,
libfs/src/rfs/rtems-rfs-buffer-bdbuf.c,
libfs/src/rfs/rtems-rfs-buffer.c,
libfs/src/rfs/rtems-rfs-buffer-devio.c,
libfs/src/rfs/rtems-rfs-buffer.h, libfs/src/rfs/rtems-rfs-data.h,
libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-dir.h,
libfs/src/rfs/rtems-rfs-dir-hash.c,
libfs/src/rfs/rtems-rfs-dir-hash.h,
libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-file.h,
libfs/src/rfs/rtems-rfs-file-system.c,
libfs/src/rfs/rtems-rfs-file-system-fwd.h,
libfs/src/rfs/rtems-rfs-file-system.h,
libfs/src/rfs/rtems-rfs-format.c,
libfs/src/rfs/rtems-rfs-format.h, libfs/src/rfs/rtems-rfs-group.c,
libfs/src/rfs/rtems-rfs-group.h, libfs/src/rfs/rtems-rfs.h,
libfs/src/rfs/rtems-rfs-inode.c, libfs/src/rfs/rtems-rfs-inode.h,
libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-link.h,
libfs/src/rfs/rtems-rfs-mutex.c, libfs/src/rfs/rtems-rfs-mutex.h,
libfs/src/rfs/rtems-rfs-rtems-dev.c,
libfs/src/rfs/rtems-rfs-rtems-dir.c,
libfs/src/rfs/rtems-rfs-rtems-file.c,
libfs/src/rfs/rtems-rfs-rtems.h,
libfs/src/rfs/rtems-rfs-rtems-utils.c,
libfs/src/rfs/rtems-rfs-shell.c, libfs/src/rfs/rtems-rfs-shell.h,
libfs/src/rfs/rtems-rfs-trace.c, libfs/src/rfs/rtems-rfs-trace.h:
New.
* Makefile.am, preinstall.am, libfs/Makefile.am,
wrapup/Makefile.am: Updated with the RFS support.
* libfs/README: Updated after 10 years.
* libblock/src/flashdisk.c, libblock/src/nvdisk.c,
libblock/src/ramdisk-driver.c: Updated to the new error reporting
in libblock.
* libmisc/shell/main_ls.c, libmisc/shell/print-ls.c: Fix printing
the size in long mode.
* libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_bootp.c,
libnetworking/rtems/rtems_bsdnet_internal.h: Return the BOOTP/DHCP
to the forever behaviour of 4.9 with the ability to call BOOTP and
control the process if required.
* wrapup/Makefile.am: Remove UNIX.
Add new BSP Boot Command Line helper routines. Recently boot_card()
has grown the ability to have a command line string pointer. These
routines provide an interface to that string.
Add the stringto family of string to number converters. These are
error checking wrappers for the strtoXXX methods and do their best to
return false if the conversion failed. The error checking required
for this is tedious and error prone. Hence better to have in a family
of helper routines.
* libmisc/stringto/stringto.h, libmisc/stringto/stringto_template.h,
libmisc/stringto/stringtodouble.c, libmisc/stringto/stringtofloat.c,
libmisc/stringto/stringtoint.c, libmisc/stringto/stringtolong.c,
libmisc/stringto/stringtolonglong.c,
libmisc/stringto/stringtounsignedchar.c,
libmisc/stringto/stringtounsignedint.c,
libmisc/stringto/stringtounsignedlong.c,
libmisc/stringto/stringtounsignedlonglong.c: New files.
* libgnat/Makefile.am, wrapup/Makefile.am: Another attempt at the
automake variables.
* Makefile.am, configure.ac, posix/Makefile.am, wrapup/Makefile.am:
Move Ada support code that is untestable from the Standard RTEMS Test
Suite into its own directory. All code in score, posix, rtems, and
sapi should be testable by the Standard RTEMS Test Suites. It was
buried under POSIX before so this should be a clearer location
anyway.
* libgnat/.cvsignore, libgnat/Makefile.am, libgnat/ada_intrsupp.c,
libgnat/adasupp.c: New files.
* posix/src/ada_intrsupp.c, posix/src/adasupp.c: Removed.
* wrapup/Makefile.am: Create archive from a file for hosts with
a limited command line size.
* wrapup/Makefile.am: Add libmd.a.
* Makefile.am, preinstall.am, libmisc/Makefile.am, rtems/Makefile.am,
rtems/include/rtems.h, rtems/include/rtems/rtems/ratemon.h,
rtems/inline/rtems/rtems/ratemon.inl, rtems/src/ratemoncancel.c,
rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c,
rtems/src/ratemonperiod.c, rtems/src/ratemontimeout.c,
score/Makefile.am, score/include/rtems/score/object.h,
score/src/threadhandler.c, wrapup/Makefile.am: Integrate Rate
Monotonic Statistics and Period Usage into Rate Monotonic Manager.
Added the following directives: rtems_rate_monotonic_get_statistics,
rtems_rate_monotonic_reset_statistics,
rtems_rate_montonic_reset_all_statistics,
rtems_rate_montonic_report_statistics, and rtems_object_get_name.
Obsoleted the rtems/rtmonuse.h file as a public interface.
* rtems/src/ratemongetstatistics.c,
rtems/src/ratemonreportstatistics.c, rtems/src/ratemonresetall.c,
rtems/src/ratemonresetstatistics.c, rtems/src/rtemsobjectgetname.c,
score/src/objectgetnameasstring.c: New files.
* libmisc/rtmonuse/rtmonuse.c, libmisc/rtmonuse/rtmonuse.h: Removed.
* wrapup/Makefile.am: Use MKDIR_P instead of mkdir_p.
Remove AM_CONDITIONAL(HAS_ITRON).
* wrapup/Makefile.am: Introduce AM_CONDITIONAL(LIBDOSFS).
* libi2c/Makefile.am, libi2c/Makefile.in, libi2c/libi2c.c,
libi2c/libi2c.h: New files.
* Makefile.am, configure.ac, preinstall.am, wrapup/Makefile.am: added a
simple API/library for i2c devices and drivers for i2c 2-byte eeproms
and a ds1621 temperature sensor; API is documented in libi2c.h
* wrapup/Makefile.am: Use librtemscpu_a_LIBRARIES.
