* libi2c/Makefile.am, libi2c/Makefile.in, libi2c/libi2c.c,
libi2c/libi2c.h: New files.
* Makefile.am, configure.ac, preinstall.am, wrapup/Makefile.am: added a
simple API/library for i2c devices and drivers for i2c 2-byte eeproms
and a ds1621 temperature sensor; API is documented in libi2c.h
* wrapup/Makefile.am: Use librtemscpu_a_LIBRARIES.
* configure.ac: Remove LIBSCORECPU.
* automake/compile.am, httpd/Makefile.am, itron/Makefile.am,
libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am,
libmisc/Makefile.am, libnetworking/Makefile.am, librpc/Makefile.am,
posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am,
score/Makefile.am, wrapup/Makefile.am:
Remove build-variant support.
* wrapup/Makefile.am: Add libblock for !UNIX only.
* wrapup/Makefile.am: Remove $(ARCH)/$(dirstamp).
Add TMPINSTALL_FILES to CLEANFILES.
* wrapup/Makefile.am: Include compile.am.
Use TMP_LIBS instead of LIBS to avoid potential conflicts with
auto*tools' LIBS.
Reflect new locations of libscorecpu*.a
* aclocal/enable-networking.m4: Don't AC_SUBST(RTEMS_HAS_NETWORKING).
* aclocal/check-networking.m4: Don't AC_SUBST(HAS_NETWORKING).
* automake/amcompile.am: Remove $(ARCH).
* wrapup/Makefile.am: Add $(ARCH).
Remove compile.am, lib.am.
Include amcompile.am.
* wrapup/Makefile.am: Use ../*/*$(LIB_VARIANT).a instead of
$(ARCH)/lib*.a.
Reflect changes to libblock/Makefile.am.
Reflect changes to libcsupport/Makefile.am.
* wrapup/Makefile.am: Reflect changes to library Makefile.ams.
* aclocal/env-rtemscpu.m4: Remove stray '/' in PROJECT_LIB.
* wrapup/Makefile.am: Remove duplicate $(PROJECT_LIB) rule.
* aclocal/env-rtemscpu.m4: Add PROJECT_LIB.
* wrapup/Makefile.am: Use $(PROJECT_LIB) instead of ${PROJECT_RELEASE}/lib.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* wrapup/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* wrapup/Makefile.am: Reworked.
* automake/compile.am: Add $(ARCH)/$(dirstamp) rules.
* wrapup/Makefile.am: Reflect $(dirstamp) changes.
* wrapup/Makefile.am: Merge-in former libmisc/wrapup/Makefile.am
* wrapup/Makefile.am: Reflect having removed libnetworking/wrapup.
* configure.ac: Ditto.
* wrapup/Makefile.am: Remove bogus $(MULTISUBDIR).
* wrapup/Makefile.am: Fix path to libxdr and librpc (Another typo in
from the 2002-12-12 patch).
* wrapup/Makefile.am: Fix typo in yesterday's patch.
* wrapup/Makefile.am: Don't create $ARCH.
Use install-data-local to install librtemscpu.a
* wrapup/Makefile.am: Add libmisc.
* wrapup/Makefile.am: Remove *_OBJS, use LIBS+= instead.
* configure.ac: Require autoconf >= 2.54, automake-1.7.2.
* wrapup/Makefile.am: Reflect changes to score/.
* configure.ac: Reflect changes to score/.
* wrapup/Makefile.am: Reflect changes to sapi/.
* configure.ac: Reflect changes to sapi/.
* wrapup/Makefile.am: Reflect changes to rtems/.
* configure.ac: Reflect changes to rtems/.
* wrapup/Makefile.am: Reflect changes to posix/.
Reflect changes to itron/.
* wrapup/Makefile.am: Use librtems.a.
* wrapup/Makefile.am: Use libsapi.a.
* wrapup/Makefile.am: Use libscore.a.
* wrapup/Makefile.am: LIBBLOCK_OBJS = ../libblock/$(ARCH)/libblock.a.
* configure.ac: Disable LIBRPC for the c4x.
Check for presence of score/cpu/${RTEMS_CPU}/cpu.c.
Let librtemscpu.a depend upon libscorecpu.a.
* wrapup/Makefile.am: Use project_libdir instead of
$(PROJECT_RELEASE)/lib. Eliminate LIBNAME. Pickup *.o's instead of
*.rels for CPU_OBJS. Manually create $(project_libdir)$(MULTISUBDIR).
* wrapup/Makefile.am: Install by using cpulibdir, cpulib_DATA.
* wrapup/Makefile.am: Fix stupid typo in previous patch.
* configure.ac: Add librpc. AC_PROG_RANLIB.
* wrapup/Makefile.am: Add librpc.
Use relative path to lib*.a for
POSIX_OBJS, ITRON_OBJS, NETWORKING_OBJS.
* wrapup/Makefile.am: Use relative path to lib*.a for
LIBCSUPPORT_OBJS, LIBBLOCK_OBJS, LIBDOSFS_OBJS, LIBIMFS_OBJS.
* Include $(top_srcdir)/automake/*.am.
* configure.ac: Add libnetworking.
* wrapup/Makefile.am: Ditto.
* configure.ac: Add libblock. Add libfs. Add AM_CONDITIONAL(UNIX).
* wrapup/Makefile.am: Add libblock, libfs/dosfs, libfs/imfs.
* configure.ac: Add libcsupport.
