PR 1762/cpukit
* Makefile.am, preinstall.am, libmisc/Makefile.am, wrapup/Makefile.am:
Add generic serial mouse driver and mouse parser. The parser code was
in the pc386 BSP but was generic so cleaned up and placed here.
Serial mouse driver itself is new.
* libmisc/mouse/README, libmisc/mouse/mouse_parser.c,
libmisc/mouse/mouse_parser.h, libmisc/mouse/serial_mouse.c,
libmisc/mouse/serial_mouse.h: New files.
* libfs/Makefile.am: Remove reference to imfs_free.c,
wrapup/Makefile.am: Split devfs into its own library.
* libfs/src/imfs/fifoimfs_init.c, libfs/src/imfs/imfs.h,
libfs/src/imfs/imfs_init.c, libfs/src/rfs/rtems-rfs-rtems.c:
Use default freenode implementation.
* libfs/src/imfs/imfs_free.c: Removed.
* libcsupport/include/rtems/libio.h, libfs/Makefile.am,
libfs/src/defaults/default_chown.c,
libfs/src/defaults/default_evalpath.c,
libfs/src/defaults/default_freenode.c,
libfs/src/defaults/default_fsmount.c,
libfs/src/defaults/default_link.c,
libfs/src/defaults/default_mount.c,
libfs/src/defaults/default_rename.c,
libfs/src/defaults/default_statvfs.c,
libfs/src/defaults/default_symlink.c,
libfs/src/defaults/default_unlink.c,
libfs/src/defaults/default_utime.c, libfs/src/devfs/devfs_init.c,
libfs/src/dosfs/msdos_init.c, libfs/src/imfs/imfs_init.c,
libfs/src/nfsclient/src/nfs.c, libfs/src/rfs/rtems-rfs-rtems.c,
wrapup/Makefile.am: Fixed typo in default names. Added default
methods into filesystem tables.
* libfs/src/defaults/default_close.c,
libfs/src/defaults/default_evaluate_link.c,
libfs/src/defaults/default_fpathconf.c,
libfs/src/defaults/default_fsunmount.c,
libfs/src/defaults/default_open.c,
libfs/src/defaults/default_unmount.c: New files.
* libfs/src/rfs/rtems-rfs-bitmaps.c,
libfs/src/rfs/rtems-rfs-bitmaps.h,
libfs/src/rfs/rtems-rfs-bitmaps-ut.c,
libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-block.h,
libfs/src/rfs/rtems-rfs-block-pos.h,
libfs/src/rfs/rtems-rfs-buffer-bdbuf.c,
libfs/src/rfs/rtems-rfs-buffer.c,
libfs/src/rfs/rtems-rfs-buffer-devio.c,
libfs/src/rfs/rtems-rfs-buffer.h, libfs/src/rfs/rtems-rfs-data.h,
libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-dir.h,
libfs/src/rfs/rtems-rfs-dir-hash.c,
libfs/src/rfs/rtems-rfs-dir-hash.h,
libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-file.h,
libfs/src/rfs/rtems-rfs-file-system.c,
libfs/src/rfs/rtems-rfs-file-system-fwd.h,
libfs/src/rfs/rtems-rfs-file-system.h,
libfs/src/rfs/rtems-rfs-format.c,
libfs/src/rfs/rtems-rfs-format.h, libfs/src/rfs/rtems-rfs-group.c,
libfs/src/rfs/rtems-rfs-group.h, libfs/src/rfs/rtems-rfs.h,
libfs/src/rfs/rtems-rfs-inode.c, libfs/src/rfs/rtems-rfs-inode.h,
libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-link.h,
libfs/src/rfs/rtems-rfs-mutex.c, libfs/src/rfs/rtems-rfs-mutex.h,
libfs/src/rfs/rtems-rfs-rtems-dev.c,
libfs/src/rfs/rtems-rfs-rtems-dir.c,
libfs/src/rfs/rtems-rfs-rtems-file.c,
libfs/src/rfs/rtems-rfs-rtems.h,
libfs/src/rfs/rtems-rfs-rtems-utils.c,
libfs/src/rfs/rtems-rfs-shell.c, libfs/src/rfs/rtems-rfs-shell.h,
libfs/src/rfs/rtems-rfs-trace.c, libfs/src/rfs/rtems-rfs-trace.h:
New.
* Makefile.am, preinstall.am, libfs/Makefile.am,
wrapup/Makefile.am: Updated with the RFS support.
* libfs/README: Updated after 10 years.
* libblock/src/flashdisk.c, libblock/src/nvdisk.c,
libblock/src/ramdisk-driver.c: Updated to the new error reporting
in libblock.
* libmisc/shell/main_ls.c, libmisc/shell/print-ls.c: Fix printing
the size in long mode.
* libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_bootp.c,
libnetworking/rtems/rtems_bsdnet_internal.h: Return the BOOTP/DHCP
to the forever behaviour of 4.9 with the ability to call BOOTP and
control the process if required.
* wrapup/Makefile.am: Remove UNIX.
Add new BSP Boot Command Line helper routines. Recently boot_card()
has grown the ability to have a command line string pointer. These
routines provide an interface to that string.
Add the stringto family of string to number converters. These are
error checking wrappers for the strtoXXX methods and do their best to
return false if the conversion failed. The error checking required
for this is tedious and error prone. Hence better to have in a family
of helper routines.
* libmisc/stringto/stringto.h, libmisc/stringto/stringto_template.h,
libmisc/stringto/stringtodouble.c, libmisc/stringto/stringtofloat.c,
libmisc/stringto/stringtoint.c, libmisc/stringto/stringtolong.c,
libmisc/stringto/stringtolonglong.c,
libmisc/stringto/stringtounsignedchar.c,
libmisc/stringto/stringtounsignedint.c,
libmisc/stringto/stringtounsignedlong.c,
libmisc/stringto/stringtounsignedlonglong.c: New files.
* libgnat/Makefile.am, wrapup/Makefile.am: Another attempt at the
automake variables.
* Makefile.am, configure.ac, posix/Makefile.am, wrapup/Makefile.am:
Move Ada support code that is untestable from the Standard RTEMS Test
Suite into its own directory. All code in score, posix, rtems, and
sapi should be testable by the Standard RTEMS Test Suites. It was
buried under POSIX before so this should be a clearer location
anyway.
* libgnat/.cvsignore, libgnat/Makefile.am, libgnat/ada_intrsupp.c,
libgnat/adasupp.c: New files.
* posix/src/ada_intrsupp.c, posix/src/adasupp.c: Removed.
* wrapup/Makefile.am: Create archive from a file for hosts with
a limited command line size.
* wrapup/Makefile.am: Add libmd.a.
* Makefile.am, preinstall.am, libmisc/Makefile.am, rtems/Makefile.am,
rtems/include/rtems.h, rtems/include/rtems/rtems/ratemon.h,
rtems/inline/rtems/rtems/ratemon.inl, rtems/src/ratemoncancel.c,
rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c,
rtems/src/ratemonperiod.c, rtems/src/ratemontimeout.c,
score/Makefile.am, score/include/rtems/score/object.h,
score/src/threadhandler.c, wrapup/Makefile.am: Integrate Rate
Monotonic Statistics and Period Usage into Rate Monotonic Manager.
Added the following directives: rtems_rate_monotonic_get_statistics,
rtems_rate_monotonic_reset_statistics,
rtems_rate_montonic_reset_all_statistics,
rtems_rate_montonic_report_statistics, and rtems_object_get_name.
Obsoleted the rtems/rtmonuse.h file as a public interface.
* rtems/src/ratemongetstatistics.c,
rtems/src/ratemonreportstatistics.c, rtems/src/ratemonresetall.c,
rtems/src/ratemonresetstatistics.c, rtems/src/rtemsobjectgetname.c,
score/src/objectgetnameasstring.c: New files.
* libmisc/rtmonuse/rtmonuse.c, libmisc/rtmonuse/rtmonuse.h: Removed.
* wrapup/Makefile.am: Use MKDIR_P instead of mkdir_p.
Remove AM_CONDITIONAL(HAS_ITRON).
* wrapup/Makefile.am: Introduce AM_CONDITIONAL(LIBDOSFS).
* libi2c/Makefile.am, libi2c/Makefile.in, libi2c/libi2c.c,
libi2c/libi2c.h: New files.
* Makefile.am, configure.ac, preinstall.am, wrapup/Makefile.am: added a
simple API/library for i2c devices and drivers for i2c 2-byte eeproms
and a ds1621 temperature sensor; API is documented in libi2c.h
* wrapup/Makefile.am: Use librtemscpu_a_LIBRARIES.
* configure.ac: Remove LIBSCORECPU.
* automake/compile.am, httpd/Makefile.am, itron/Makefile.am,
libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am,
libmisc/Makefile.am, libnetworking/Makefile.am, librpc/Makefile.am,
posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am,
score/Makefile.am, wrapup/Makefile.am:
Remove build-variant support.
* wrapup/Makefile.am: Add libblock for !UNIX only.
* wrapup/Makefile.am: Remove $(ARCH)/$(dirstamp).
Add TMPINSTALL_FILES to CLEANFILES.
* wrapup/Makefile.am: Include compile.am.
Use TMP_LIBS instead of LIBS to avoid potential conflicts with
auto*tools' LIBS.
Reflect new locations of libscorecpu*.a
* aclocal/enable-networking.m4: Don't AC_SUBST(RTEMS_HAS_NETWORKING).
* aclocal/check-networking.m4: Don't AC_SUBST(HAS_NETWORKING).
* automake/amcompile.am: Remove $(ARCH).
* wrapup/Makefile.am: Add $(ARCH).
Remove compile.am, lib.am.
Include amcompile.am.
* wrapup/Makefile.am: Use ../*/*$(LIB_VARIANT).a instead of
$(ARCH)/lib*.a.
Reflect changes to libblock/Makefile.am.
Reflect changes to libcsupport/Makefile.am.
* wrapup/Makefile.am: Reflect changes to library Makefile.ams.
* aclocal/env-rtemscpu.m4: Remove stray '/' in PROJECT_LIB.
* wrapup/Makefile.am: Remove duplicate $(PROJECT_LIB) rule.
* aclocal/env-rtemscpu.m4: Add PROJECT_LIB.
* wrapup/Makefile.am: Use $(PROJECT_LIB) instead of ${PROJECT_RELEASE}/lib.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* wrapup/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* wrapup/Makefile.am: Reworked.
* automake/compile.am: Add $(ARCH)/$(dirstamp) rules.
* wrapup/Makefile.am: Reflect $(dirstamp) changes.
