path: root/cpukit/wrapup (follow)
* 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-141-2/+0
| | | | * wrapup/Makefile.am: Remove UNIX.
* 2009-08-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-08-051-2/+3
| | | | | | | * Makefile.am, preinstall.am, libmisc/Makefile.am, wrapup/Makefile.am: Add new BSP Boot Command Line helper routines. Recently boot_card() has grown the ability to have a command line string pointer. These routines provide an interface to that string.
* 2009-07-22 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-07-221-0/+1
| | | | | | | | | | | | | | | | | * Makefile.am, preinstall.am, libmisc/Makefile.am, wrapup/Makefile.am: Add the stringto family of string to number converters. These are error checking wrappers for the strtoXXX methods and do their best to return false if the conversion failed. The error checking required for this is tedious and error prone. Hence better to have in a family of helper routines. * libmisc/stringto/stringto.h, libmisc/stringto/stringto_template.h, libmisc/stringto/stringtodouble.c, libmisc/stringto/stringtofloat.c, libmisc/stringto/stringtoint.c, libmisc/stringto/stringtolong.c, libmisc/stringto/stringtolonglong.c, libmisc/stringto/stringtounsignedchar.c, libmisc/stringto/stringtounsignedint.c, libmisc/stringto/stringtounsignedlong.c, libmisc/stringto/stringtounsignedlonglong.c: New files.
* UpdateThomas Doerfler2009-05-051-0/+1
* Use LIBGNAT.Ralf Corsepius2008-06-301-1/+1
* 2007-12-12 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-12-121-0/+3
| | | | | * libgnat/Makefile.am, wrapup/Makefile.am: Another attempt at the automake variables.
* 2007-12-11 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-12-121-0/+1
| | | | | | | | | | | | * Makefile.am, configure.ac, posix/Makefile.am, wrapup/Makefile.am: Move Ada support code that is untestable from the Standard RTEMS Test Suite into its own directory. All code in score, posix, rtems, and sapi should be testable by the Standard RTEMS Test Suites. It was buried under POSIX before so this should be a clearer location anyway. * libgnat/.cvsignore, libgnat/Makefile.am, libgnat/ada_intrsupp.c, libgnat/adasupp.c: New files. * posix/src/ada_intrsupp.c, posix/src/adasupp.c: Removed.
* 2007-07-27i Chris Johns <chrisj@rtems.org>Chris Johns2007-07-271-2/+3
| | | | | * wrapup/Makefile.am: Create archive from a file for hosts with a limited command line size.
* Pickup ../libmd/libmd.a.Ralf Corsepius2007-06-121-1/+1
* 2007-06-12 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-06-121-0/+4
| | | | * wrapup/Makefile.am: Add libmd.a.
* 2007-05-15 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-05-151-1/+0
| | | | | | | | | | | | | | | | | | | | | | * Makefile.am, preinstall.am, libmisc/Makefile.am, rtems/Makefile.am, rtems/include/rtems.h, rtems/include/rtems/rtems/ratemon.h, rtems/inline/rtems/rtems/ratemon.inl, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemontimeout.c, score/Makefile.am, score/include/rtems/score/object.h, score/src/threadhandler.c, wrapup/Makefile.am: Integrate Rate Monotonic Statistics and Period Usage into Rate Monotonic Manager. Added the following directives: rtems_rate_monotonic_get_statistics, rtems_rate_monotonic_reset_statistics, rtems_rate_montonic_reset_all_statistics, rtems_rate_montonic_report_statistics, and rtems_object_get_name. Obsoleted the rtems/rtmonuse.h file as a public interface. * rtems/src/ratemongetstatistics.c, rtems/src/ratemonreportstatistics.c, rtems/src/ratemonresetall.c, rtems/src/ratemonresetstatistics.c, rtems/src/rtemsobjectgetname.c, score/src/objectgetnameasstring.c: New files. * libmisc/rtmonuse/rtmonuse.c, libmisc/rtmonuse/rtmonuse.h: Removed.
* Rename AM_CONDITIONAL(HAS_POSIX) into LIBPOSIX.Ralf Corsepius2007-04-131-1/+1
* 2007-02-21 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2007-02-211-1/+1
| | | | * wrapup/Makefile.am: Use MKDIR_P instead of mkdir_p.
* Regenerate.Ralf Corsepius2007-01-081-1/+1
* Replace AM_CONDITIONAL(HAS_NETWORKING) with AM_CONDITIONAL(LIBNETWORKING).Ralf Corsepius2006-11-181-1/+1
* Introduce AM_CONDITIONAL(LIBITRON).Ralf Corsepius2006-11-171-1/+1
| | | | Remove AM_CONDITIONAL(HAS_ITRON).
* 2006-11-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-11-171-0/+2
| | | | * wrapup/Makefile.am: Introduce AM_CONDITIONAL(LIBDOSFS).
* Regenerate.Ralf Corsepius2006-01-131-0/+2
* Regenerate.Ralf Corsepius2006-01-121-2/+2
* CleanupsRalf Corsepius2006-01-121-3/+0
* 2005-11-02 straumanatslacdotstanford.eduTill Straumann2005-11-031-0/+2
| | | | | | | | * libi2c/Makefile.am, libi2c/Makefile.in, libi2c/libi2c.c, libi2c/libi2c.h: New files. * Makefile.am, configure.ac, preinstall.am, wrapup/Makefile.am: added a simple API/library for i2c devices and drivers for i2c 2-byte eeproms and a ds1621 temperature sensor; API is documented in libi2c.h
* Regenerate.Ralf Corsepius2005-08-151-0/+8
* 2005-08-15 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-08-151-2/+3
| | | | * wrapup/Makefile.am: Use librtemscpu_a_LIBRARIES.
* Regenerate.Ralf Corsepius2005-05-241-8/+0
* Auto-generated update.Ralf Corsepius2005-02-191-1/+1
* 2005-02-12 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-121-2/+0
| | | | | * configure.ac: Remove LIBSCORECPU. * wrapup/Makefile.am: Reflect changes above.
* Cosmetics.Ralf Corsepius2005-02-081-0/+8
* Split preinstallation rules in to separate files (preinstall.am).Ralf Corsepius2005-02-081-12/+2
* New.Ralf Corsepius2005-02-081-0/+14
* 2005-01-01 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-011-40/+35
| | | | | | | | | * automake/compile.am, httpd/Makefile.am, itron/Makefile.am, libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am, libmisc/Makefile.am, libnetworking/Makefile.am, librpc/Makefile.am, posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am, wrapup/Makefile.am: Remove build-variant support.
* 2004-04-09 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-091-2/+1
| | | | * wrapup/Makefile.am: Add libblock for !UNIX only.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-141-5/+5
| | | | | * wrapup/Makefile.am: Remove $(ARCH)/$(dirstamp). Add TMPINSTALL_FILES to CLEANFILES.
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-111-34/+34
| | | | | | | * wrapup/Makefile.am: Include compile.am. Use TMP_LIBS instead of LIBS to avoid potential conflicts with auto*tools' LIBS. Reflect new locations of libscorecpu*.a
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-091-2/+2
| | | | * wrapup/Makefile.am: Cosmetics.
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-091-2/+14
| | | | | | | | | * aclocal/enable-networking.m4: Don't AC_SUBST(RTEMS_HAS_NETWORKING). * aclocal/check-networking.m4: Don't AC_SUBST(HAS_NETWORKING). * automake/amcompile.am: Remove $(ARCH). * wrapup/Makefile.am: Add $(ARCH). Remove compile.am, lib.am. Include amcompile.am.
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-091-25/+25
| | | | | * wrapup/Makefile.am: Use ../*/*$(LIB_VARIANT).a instead of $(ARCH)/lib*.a.
| | | | | | * wrapup/Makefile.am: Reflect changes to libblock/Makefile.am. Reflect changes to libcsupport/Makefile.am.
* 2004-01-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-071-19/+19
| | | | * wrapup/Makefile.am: Reflect changes to library Makefile.ams.
* 2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-131-7/+0
| | | | | * aclocal/env-rtemscpu.m4: Remove stray '/' in PROJECT_LIB. * wrapup/Makefile.am: Remove duplicate $(PROJECT_LIB) rule.
* 2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-131-6/+13
| | | | | * aclocal/env-rtemscpu.m4: Add PROJECT_LIB. * wrapup/Makefile.am: Use $(PROJECT_LIB) instead of ${PROJECT_RELEASE}/lib.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-2/+1
| | | | | * Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * wrapup/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-9/+11
| | | | * wrapup/Makefile.am: Reworked.
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-011-3/+5
| | | | | * automake/compile.am: Add $(ARCH)/$(dirstamp) rules. * wrapup/Makefile.am: Reflect $(dirstamp) changes.
* 2003-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-281-1/+22
| | | | * wrapup/Makefile.am: Merge-in former libmisc/wrapup/Makefile.am
* 2003-11-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-221-1/+3
| | | | | * wrapup/Makefile.am: Reflect having removed libnetworking/wrapup. * configure.ac: Ditto.
* 2003-07-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-151-2/+2
| | | | * wrapup/Makefile.am: Remove bogus $(MULTISUBDIR).
* 2003-07-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-151-3/+3
* 2002-12-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-141-2/+2
| | | | | * wrapup/Makefile.am: Fix path to libxdr and librpc (Another typo in from the 2002-12-12 patch).
* 2002-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-131-3/+3
| | | | * wrapup/Makefile.am: Fix typo in yesterday's patch.
* 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-121-4/+4
| | | | | * wrapup/Makefile.am: Don't create $ARCH. Use install-data-local to install librtemscpu.a
