path: root/cpukit/telnetd (follow)
* 2002-08-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-141-0/+1
| | | | | | | * rtems_servers/ftpd.c: Remove unused variable buf. * pppd/md5.c: #include <string.h> to make gcc31 happy. * rtems_telnetd/telnetd.c: #include <string.h> to make gcc31 happy. * rtems_webserver/webmain.c: Remove unused variable dir, cp.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-1/+1
| | | | | | | | * pppd/Makefile.am: Use .$(OBJEXT) instead of .o. * rtems_servers/Makefile.am: Use .$(OBJEXT) instead of .o. * rtems_telnetd/Makefile.am: Use .$(OBJEXT) instead of .o. * rtems_webserver/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-05-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-281-1/+1
| | | | * rtems_telnetd/pty.c: Remove bsp.h. Include <rtems/bspIo.h>.
| | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * arpa/Makefile.am: Remove AUTOMAKE_OPTIONS. * kern/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * lib/Makefile.am: Remove AUTOMAKE_OPTIONS. * libc/Makefile.am: Remove AUTOMAKE_OPTIONS. * machine/Makefile.am: Remove AUTOMAKE_OPTIONS. * net/Makefile.am: Remove AUTOMAKE_OPTIONS. * netinet/Makefile.am: Remove AUTOMAKE_OPTIONS. * nfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * pppd/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_servers/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_telnetd/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_webserver/Makefile.am: Remove AUTOMAKE_OPTIONS. * sys/Makefile.am: Remove AUTOMAKE_OPTIONS. * vm/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-221-6/+5
| | | | | | * rtems_telnetd/pty.c: Move config.h to were it belongs. Remove printf (Reported by Till Straumann <strauman@SLAC.Stanford.EDU>).
* 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-271-1/+1
| | | | | | | | | | | | | | | * machine/Makefile.am: Use 'PREINSTALL_FILES ='. * net/Makefile.am: Use 'PREINSTALL_FILES ='. * netinet/Makefile.am: Use 'PREINSTALL_FILES ='. * vm/Makefile.am: Use 'PREINSTALL_FILES ='. * pppd/Makefile.am: Use 'PREINSTALL_FILES ='. * sys/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems_servers/Makefile.am: Use 'PREINSTALL_FILES ='. * arpa/Makefile.am: Use 'PREINSTALL_FILES ='. * nfs/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems_webserver/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems_telnetd/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-08-09 Fernando-Ruiz Casas <correo@fernando-ruiz.com>Joel Sherrill2001-08-097-0/+758
* Makefile.am, configure.in, rtems_servers/Makefile.am, rtems_servers/telnetd.c, rtems_servers/telnetd.h, rtems_telnetd/Makefile.am, rtems_telnetd/README, rtems_telnetd/icmds.c, rtems_telnetd/pty.c, rtems_telnetd/pty.h, rtems_telnetd/telnetd.c, rtems_telnetd/telnetd.h, wrapup/Makefile.am: - pty and telnetd have a new subdir rtems_telnetd to avoid the side effect when ftpd change. - the tcp/ip stats have been implemented into icmds.c and started when telnetd daemon is started. * rtems_servers/telnetd.c, rtems_servers/telnetd.h: Removed. * rtems_telnetd: New directory. * rtems_telnetd/Makefile.am, rtems_telnetd/README, rtems_telnetd/icmds.c, rtems_telnetd/pty.c, rtems_telnetd/pty.h, rtems_telnetd/telnetd.c, rtems_telnetd/telnetd.h: New files.
