PR 1262/filesystem
* libcsupport/Makefile.am, libnetworking/libc/herror.c,
libnetworking/libc/res_send.c, libnetworking/sys/uio.h,
telnetd/Makefile.am, telnetd/README, telnetd/preinstall.am,
telnetd/pty.c, telnetd/telnetd.c: Add support for readv() and
writev() including documentation and test case.
* libcsupport/src/readv.c, libcsupport/src/writev.c: New files.
* telnetd/icmds.c: Add HAVE_CONFIG_H magic.
* libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-command.c,
libmisc/monitor/mon-driver.c, libmisc/monitor/mon-symbols.c,
libmisc/rtmonuse/rtmonuse.c, libmisc/stackchk/check.c,
libnetworking/libc/res_debug.c, telnetd/telnetd.c: Remove printf
format warnings.
* telnetd/Makefile.am: Only build if LIBSHELL is available.
* telnetd/icmds.c: Rename register_icmds to
_rtems_telnet_register_icmds. Make main_* functions static.
* telnetd/pty.c: Make many functions static.
Rename rtems_telnetd_maximum_ptys to rtems_pty_maximum_ptys.
* telnetd/pty.h: Reflect changes above.
Rename get_pty to rtems_pty_get. New header guards.
* telnetd/telnetd.c: Reflect changes above.
* telnetd/telnetd.h: New header guards.
* telnet/telnet.h, telnet/telnet.c: Rename
rtems_initialize_telnetd to rtems_telnetd_initialize,
main_telnetd to rtems_telnetd_main,
register_telnetd to rtems_telnetd_register.
* sapi/include/confdefs.h, telnetd/pty.c, telnetd/pty.h: Attempt
to fix MAX_PTYS and provide a real configuration entry. This should
make telnetd some suitable for inclusion in cpukit.
* libchip/Makefile.am, libnetworking/pppd/Makefile.am,
libnetworking/rtems_servers/Makefile.am,
libnetworking/rtems_telnetd/Makefile.am,
librdbg/Makefile.am, optman/Makefile.am, support/Makefile.am:
Eliminate CFLAGS_OPTIMIZE_V.
* libnetworking/pppd/Makefile.am,
libnetworking/rtems_telnetd/Makefile.am:
Remove build-variant support.
* libnetworking/pppd/rtemspppd.c: rtems_task_priority priority.
* libnetworking/rtems_telnetd/telnetd.c: Eliminate rtems_unsigned32.
libnetworking/rtems_webserver/Makefile.am, optman/Makefile.am,
support/Makefile.am: Don't include lib.am.
* libnetworking/rtems_webserver/Makefile.am: Add PREINSTALL_DIRS.
* libnetworking/rtems_telnetd/Makefile.am: Add PREINSTALL_DIRS.
* libnetworking/rtems_servers/Makefile.am: Add PREINSTALL_DIRS.
* libnetworking/pppd/Makefile.am: Add PREINSTALL_DIRS.
* Makefile.am: Remove wrapup.
* pppd/Makefile.am: Build libpppd.
Use automake-compilation rules.
* rtems_servers/Makefile.am: Build libftpd.
* rtems_telnetd/Makefile.am: Build libtelnetd.
* rtems_webserver/Makefile.am: Build libhttpd.
* wrapup/Makefile.am: Remove (Unused).
* pppd/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* rtems_servers/Makefile.am: Ditto.
* rtems_telnetd/Makefile.am: Ditto.
* rtems_webserver/Makefile.am: Ditto.
* pppd/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* rtems_servers/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* rtems_telnetd/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* rtems_webserver/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* pppd/Makefile.am: Remove all-local: $(ARCH).
* rtems_servers/Makefile.am: Remove all-local: $(ARCH).
* rtems_telnetd/Makefile.am: Remove all-local: $(ARCH).
* rtems_webserver/Makefile.am: Remove all-local: $(ARCH).
* Makefile.am: Reformat. Apply dirstamps to preinstallation.
* pppd/Makefile.am: Ditto.
* wrapup/Makefile.am: Ditto.
pppd/Makefile.am: Reflect having moved automake.
rtems_servers/Makefile.am: Reflect having moved automake.
rtems_telnetd/Makefile.am: Reflect having moved automake.
rtems_webserver/Makefile.am: Reflect having moved automake.
* configure.ac: Remove (Merged into ../configure.ac).
* .cvsignore, Makefile.am, pppd/Makefile.am,
rtems_servers/Makefile.am, rtems_telnetd/Makefile.am,
rtems_webserver/Makefile.am, wrapup/Makefile.am:
Reflect having merged configure.ac into ../configure.ac
* pppd/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Eliminate *_O_FILES.
* rtems_servers/ftpd.c: Remove unused variable buf.
* pppd/md5.c: #include <string.h> to make gcc31 happy.
* rtems_telnetd/telnetd.c: #include <string.h> to make gcc31 happy.
* rtems_webserver/webmain.c: Remove unused variable dir, cp.
* pppd/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_servers/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_telnetd/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_webserver/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_telnetd/pty.c: Remove bsp.h. Include <rtems/bspIo.h>.
* arpa/Makefile.am: Remove AUTOMAKE_OPTIONS.
* kern/Makefile.am: Remove AUTOMAKE_OPTIONS.
* lib/Makefile.am: Remove AUTOMAKE_OPTIONS.
* libc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* machine/Makefile.am: Remove AUTOMAKE_OPTIONS.
* net/Makefile.am: Remove AUTOMAKE_OPTIONS.
* netinet/Makefile.am: Remove AUTOMAKE_OPTIONS.
* nfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* pppd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_servers/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_telnetd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_webserver/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sys/Makefile.am: Remove AUTOMAKE_OPTIONS.
* vm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_telnetd/pty.c: Move config.h to were it belongs.
Remove printf (Reported by Till Straumann
<strauman@SLAC.Stanford.EDU>).
* machine/Makefile.am: Use 'PREINSTALL_FILES ='.
* net/Makefile.am: Use 'PREINSTALL_FILES ='.
* netinet/Makefile.am: Use 'PREINSTALL_FILES ='.
* vm/Makefile.am: Use 'PREINSTALL_FILES ='.
* pppd/Makefile.am: Use 'PREINSTALL_FILES ='.
* sys/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems_servers/Makefile.am: Use 'PREINSTALL_FILES ='.
* arpa/Makefile.am: Use 'PREINSTALL_FILES ='.
* nfs/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems_webserver/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems_telnetd/Makefile.am: Use 'PREINSTALL_FILES ='.
* Makefile.am, configure.in, rtems_servers/Makefile.am,
rtems_servers/telnetd.c, rtems_servers/telnetd.h,
rtems_telnetd/Makefile.am, rtems_telnetd/README, rtems_telnetd/icmds.c,
rtems_telnetd/pty.c, rtems_telnetd/pty.h, rtems_telnetd/telnetd.c,
rtems_telnetd/telnetd.h, wrapup/Makefile.am:
- pty and telnetd have a new subdir rtems_telnetd to avoid
the side effect when ftpd change.
- the tcp/ip stats have been implemented into icmds.c and
started when telnetd daemon is started.
* rtems_servers/telnetd.c, rtems_servers/telnetd.h: Removed.
* rtems_telnetd: New directory.
* rtems_telnetd/Makefile.am, rtems_telnetd/README,
rtems_telnetd/icmds.c, rtems_telnetd/pty.c, rtems_telnetd/pty.h,
rtems_telnetd/telnetd.c, rtems_telnetd/telnetd.h: New files.
