not updated.
It is not so easy to use Termios for that. We already map CRNUL to CR,
thus we cannot ignore CRs. We could change the shell code to map CRNL
to a single line end, but this is more intrusive than the change here.
The standard line editor rtems_shell_line_editor() produces an echo.
for details.
PR 1985/cpukit
* telnetd/Makefile.am: Remove icmds.c.
PR 1985/cpukit
* telnetd/icmds.c: Removed.
All functionality is in shell. Obsolete and unreferenced.
* libblock/include/rtems/ide_part_table.h, libblock/src/bdbuf.c,
libcsupport/src/__times.c, libcsupport/src/libio_init.c,
libcsupport/src/mallocfreespace.c, libcsupport/src/mount-mgr.c,
libcsupport/src/mount.c, libcsupport/src/rewinddir.c,
libcsupport/src/seekdir.c, libcsupport/src/telldir.c,
libcsupport/src/unmount.c, libfs/src/dosfs/fat.c,
libfs/src/dosfs/fat_fat_operations.c, libfs/src/dosfs/msdos_create.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_fsunmount.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_rename.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/shell/vis.c, libmisc/stackchk/check.c, sapi/src/posixapi.c,
telnetd/telnetd.c: Remove include of assert.h when it is not needed.
* libgnat/ada_intrsupp.c, telnetd/check_passwd.c, telnetd/des.c,
telnetd/genpw.c: Add include of config.h
* telnetd/telnetd.c: Honor configuration setting for telnet daemon
stack size.
* telnetd/pty.c:
Reflect changes to rtems_termios_callbacks->write.
* telnetd/telnetd.c (telnetd_dflt_spawn): Adjust prototype.
* telnetd/des.c: Split the des_f struct into smaller parts so
targets that cannot address large structs can be supported.
* libmisc/uuid/gen_uuid.c, libnetworking/lib/syslog.c,
telnetd/telnetd.c: Fixed warnings.
* telnetd/telnetd.h: Spacing.
* Makefile.am, preinstall.am, libmisc/Makefile.am,
libmisc/shell/shell.c, libmisc/shell/shell.h, telnetd/check_passwd.c,
telnetd/telnetd.c, telnetd/telnetd.h:
Generalized login check.
* libmisc/shell/login.h, libmisc/shell/login_check.c,
libmisc/shell/login_prompt.c: New files.
* libmisc/stackchk/check.c: Changed format for blown stack message.
* libcsupport/src/libio_sockets.c: Removed superfluous cast.
* libnetworking/rtems/ftpfs.h: Documentation.
PR 1331/networking
* libmisc/shell/shell.c, telnetd/check_passwd.c, telnetd/telnetd.c,
telnetd/telnetd.h: Improve comments and explanation of options to
rtems_telnetd_initialize. Add extra newline to login sequence from
shell.
Remove unused local declations.
* configure.ac: fixed bug that always enabled strict order
mutexes.
* score/inline/rtems/score/coremutex.inl: Fixed coding standard.
* score/src/coremutex.c: Add the holder's thread to the lock_mutex
list if the mutex is initialised locked.
* libnetworking/rtems/rtems_glue.c: Changed semaphore error
message to show the error is an rtems-net error.
* libmisc/monitor/mon-network.c: Removed warnings.
* telnetd/icmds.c: Changed shell_* to rtems_shell_*.
* score/Makefile.am: Fixed typo that stopped 'make tags' working.
* libmisc/shell/err.c, libmisc/shell/err.h, libmisc/shell/errx.c,
libmisc/shell/extern-cp.h, libmisc/shell/fts.c,
libmisc/shell/fts.h, libmisc/shell/main_cp.c,
libmisc/shell/utils-cp.c, libmisc/shell/verr.c,
libmisc/shell/verrx.c, libmisc/shell/vwarn.c,
libmisc/shell/vwarnx.c, libmisc/shell/warn.c,
libmisc/shell/warnx.c: New. Ported from BSD.
* libmisc/shell/shellconfig.h: Add the cp command.
* libmisc/Makefile.am: Add the new files to the shell.
* libmisc/shell/shell.c, libmisc/shell/shell.h: Add scripting
support.
* libblock/src/flashdisk.c: Fixed disk drive count size setting
bug.
* telnetd/pty.c, telnetd/telnetd.c, telnetd/telnetd.h: Style clean up.
Now works on gen5200/icecube.
* telnetd/icmds.c, telnetd/pty.c, telnetd/telnetd.c, telnetd/telnetd.h:
Fix headers and formatting.
* score/include/rtems/score/copyrt.h: Update year.
* telnetd/passwd.h: New file.
* telnetd/README, telnetd/pty.c, telnetd/pty.h, telnetd/telnetd.c,
telnetd/telnetd.h: telnetd rewrite.
* telnetd/check_passwd.c, telnetd/des.c, telnetd/genpw.c: New files.
PR 1262/filesystem
* libcsupport/Makefile.am, libnetworking/libc/herror.c,
libnetworking/libc/res_send.c, libnetworking/sys/uio.h,
telnetd/Makefile.am, telnetd/README, telnetd/preinstall.am,
telnetd/pty.c, telnetd/telnetd.c: Add support for readv() and
writev() including documentation and test case.
* libcsupport/src/readv.c, libcsupport/src/writev.c: New files.
* telnetd/icmds.c: Add HAVE_CONFIG_H magic.
* libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-command.c,
libmisc/monitor/mon-driver.c, libmisc/monitor/mon-symbols.c,
libmisc/rtmonuse/rtmonuse.c, libmisc/stackchk/check.c,
libnetworking/libc/res_debug.c, telnetd/telnetd.c: Remove printf
format warnings.
