Remove unused local declations.
* configure.ac: fixed bug that always enabled strict order
mutexes.
* score/inline/rtems/score/coremutex.inl: Fixed coding standard.
* score/src/coremutex.c: Add the holder's thread to the lock_mutex
list if the mutex is initialised locked.
* libnetworking/rtems/rtems_glue.c: Changed semaphore error
message to show the error is an rtems-net error.
* libmisc/monitor/mon-network.c: Removed warnings.
* telnetd/icmds.c: Changed shell_* to rtems_shell_*.
* score/Makefile.am: Fixed typo that stopped 'make tags' working.
* libmisc/shell/err.c, libmisc/shell/err.h, libmisc/shell/errx.c,
libmisc/shell/extern-cp.h, libmisc/shell/fts.c,
libmisc/shell/fts.h, libmisc/shell/main_cp.c,
libmisc/shell/utils-cp.c, libmisc/shell/verr.c,
libmisc/shell/verrx.c, libmisc/shell/vwarn.c,
libmisc/shell/vwarnx.c, libmisc/shell/warn.c,
libmisc/shell/warnx.c: New. Ported from BSD.
* libmisc/shell/shellconfig.h: Add the cp command.
* libmisc/Makefile.am: Add the new files to the shell.
* libmisc/shell/shell.c, libmisc/shell/shell.h: Add scripting
support.
* libblock/src/flashdisk.c: Fixed disk drive count size setting
bug.
* telnetd/pty.c, telnetd/telnetd.c, telnetd/telnetd.h: Style clean up.
Now works on gen5200/icecube.
* telnetd/icmds.c, telnetd/pty.c, telnetd/telnetd.c, telnetd/telnetd.h:
Fix headers and formatting.
* score/include/rtems/score/copyrt.h: Update year.
* telnetd/passwd.h: New file.
* telnetd/README, telnetd/pty.c, telnetd/pty.h, telnetd/telnetd.c,
telnetd/telnetd.h: telnetd rewrite.
* telnetd/check_passwd.c, telnetd/des.c, telnetd/genpw.c: New files.
PR 1262/filesystem
* libcsupport/Makefile.am, libnetworking/libc/herror.c,
libnetworking/libc/res_send.c, libnetworking/sys/uio.h,
telnetd/Makefile.am, telnetd/README, telnetd/preinstall.am,
telnetd/pty.c, telnetd/telnetd.c: Add support for readv() and
writev() including documentation and test case.
* libcsupport/src/readv.c, libcsupport/src/writev.c: New files.
* telnetd/icmds.c: Add HAVE_CONFIG_H magic.
* libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-command.c,
libmisc/monitor/mon-driver.c, libmisc/monitor/mon-symbols.c,
libmisc/rtmonuse/rtmonuse.c, libmisc/stackchk/check.c,
libnetworking/libc/res_debug.c, telnetd/telnetd.c: Remove printf
format warnings.
* telnetd/Makefile.am: Only build if LIBSHELL is available.
* telnetd/icmds.c: Rename register_icmds to
_rtems_telnet_register_icmds. Make main_* functions static.
* telnetd/pty.c: Make many functions static.
Rename rtems_telnetd_maximum_ptys to rtems_pty_maximum_ptys.
* telnetd/pty.h: Reflect changes above.
Rename get_pty to rtems_pty_get. New header guards.
* telnetd/telnetd.c: Reflect changes above.
* telnetd/telnetd.h: New header guards.
* telnet/telnet.h, telnet/telnet.c: Rename
rtems_initialize_telnetd to rtems_telnetd_initialize,
main_telnetd to rtems_telnetd_main,
register_telnetd to rtems_telnetd_register.
* sapi/include/confdefs.h, telnetd/pty.c, telnetd/pty.h: Attempt
to fix MAX_PTYS and provide a real configuration entry. This should
make telnetd some suitable for inclusion in cpukit.
* libchip/Makefile.am, libnetworking/pppd/Makefile.am,
libnetworking/rtems_servers/Makefile.am,
libnetworking/rtems_telnetd/Makefile.am,
librdbg/Makefile.am, optman/Makefile.am, support/Makefile.am:
Eliminate CFLAGS_OPTIMIZE_V.
* libnetworking/pppd/Makefile.am,
libnetworking/rtems_telnetd/Makefile.am:
Remove build-variant support.
* libnetworking/pppd/rtemspppd.c: rtems_task_priority priority.
* libnetworking/rtems_telnetd/telnetd.c: Eliminate rtems_unsigned32.
libnetworking/rtems_webserver/Makefile.am, optman/Makefile.am,
support/Makefile.am: Don't include lib.am.
* libnetworking/rtems_webserver/Makefile.am: Add PREINSTALL_DIRS.
* libnetworking/rtems_telnetd/Makefile.am: Add PREINSTALL_DIRS.
* libnetworking/rtems_servers/Makefile.am: Add PREINSTALL_DIRS.
* libnetworking/pppd/Makefile.am: Add PREINSTALL_DIRS.
* Makefile.am: Remove wrapup.
* pppd/Makefile.am: Build libpppd.
Use automake-compilation rules.
* rtems_servers/Makefile.am: Build libftpd.
* rtems_telnetd/Makefile.am: Build libtelnetd.
* rtems_webserver/Makefile.am: Build libhttpd.
* wrapup/Makefile.am: Remove (Unused).
* pppd/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* rtems_servers/Makefile.am: Ditto.
* rtems_telnetd/Makefile.am: Ditto.
* rtems_webserver/Makefile.am: Ditto.
* pppd/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* rtems_servers/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* rtems_telnetd/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* rtems_webserver/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* pppd/Makefile.am: Remove all-local: $(ARCH).
* rtems_servers/Makefile.am: Remove all-local: $(ARCH).
* rtems_telnetd/Makefile.am: Remove all-local: $(ARCH).
* rtems_webserver/Makefile.am: Remove all-local: $(ARCH).
* Makefile.am: Reformat. Apply dirstamps to preinstallation.
* pppd/Makefile.am: Ditto.
* wrapup/Makefile.am: Ditto.
pppd/Makefile.am: Reflect having moved automake.
rtems_servers/Makefile.am: Reflect having moved automake.
rtems_telnetd/Makefile.am: Reflect having moved automake.
rtems_webserver/Makefile.am: Reflect having moved automake.
* configure.ac: Remove (Merged into ../configure.ac).
* .cvsignore, Makefile.am, pppd/Makefile.am,
rtems_servers/Makefile.am, rtems_telnetd/Makefile.am,
rtems_webserver/Makefile.am, wrapup/Makefile.am:
Reflect having merged configure.ac into ../configure.ac
