1995-08-22 | fix broken RCS Ids -- $ accidentally lost merging changes earlier | Joel Sherrill | 3 | -3/+3 | |
1995-08-22 | Modified object name to id translation loop to make it easier to | Joel Sherrill | 1 | -16/+24 | |
incorporate variable length object names. Previously the algorithm scanned an array of 4-byte names for a match. Now it scans the object table, grabs a pointer to the name, and then compares it if the object is active and has a name. | |||||
1995-08-18 | + Added object type field to object id. | Joel Sherrill | 2 | -10/+20 | |
+ Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control. + Added parameter "object class" to calls to Initialize Information | |||||
1995-08-18 | + Added object type field to object id. | Joel Sherrill | 4 | -21/+102 | |
+ Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control. | |||||
1995-08-17 | Numerous miscellaneous features incorporated from Tony Bennett | Joel Sherrill | 4 | -2/+101 | |
(tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables | |||||
1995-08-16 | bug fixes to make macro implementations work | Joel Sherrill | 11 | -74/+23 | |
1995-08-11 | added constant for number of notepads | Joel Sherrill | 1 | -8/+10 | |
1995-08-04 | cleanup and optimization from Tony | Joel Sherrill | 1 | -12/+18 | |
1995-08-02 | *** empty log message *** | Joel Sherrill | 1 | -1/+0 | |
1995-07-31 | Switched to events for mp receive server and eliminated the special | Joel Sherrill | 4 | -92/+3 | |
blocking mechanism for it. | |||||
1995-07-21 | after testing go32 and cvme961 | Joel Sherrill | 1 | -1/+8 | |
1995-07-18 | fixed for Linux | Joel Sherrill | 1 | -13/+24 | |
1995-07-18 | merged Linux UNIX simulator support (C) | Joel Sherrill | 2 | -2/+23 | |
1995-07-12 | Ada95, gnat, go32 | Joel Sherrill | 8 | -359/+551 | |
1995-06-14 | added David Glessner's 68302 work. | Joel Sherrill | 1 | -5/+5 | |
1995-06-07 | corrected pseudo-code for _ISR_Handler | Joel Sherrill | 1 | -5/+17 | |
1995-06-07 | incorporated mc68302 support | Joel Sherrill | 3 | -0/+1239 | |
1995-06-04 | changed release number to 3.2.0 | Joel Sherrill | 2 | -11/+12 | |
1995-05-25 | TEST | Joel Sherrill | 1 | -0/+2 | |
1995-05-24 | Fully tested on all in-house targets | Joel Sherrill | 14 | -171/+104 | |
