* cpu.c, rtems/score/cpu.h: Convert to using c99 fixed size types.
* cpu.c, cpu_asm.S, rtems/score/cpu.h, rtems/score/interrupts.h:
* cpu.c, rtems/score/cpu.h, rtems/score/sparc.h: Convert to using
* cpu.c, m68302.h, rtems/score/cpu.h, rtems/score/m68k.h: Convert to
* cpu.c, rtems/score/cpu.h, rtems/score/sh.h, rtems/score/sh_io.h:
* cpu.c, cpu_asm.c, rtems/score/cpu.h: Convert to using c99 fixed
size types.
* c4xio.h, cpu.c, irq.c, rtems/score/cpu.h: Convert to using c99
fixed size types.
* score/include/rtems/debug.h, score/include/rtems/score/bitfield.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/heap.h,
score/include/rtems/score/interr.h, score/include/rtems/score/isr.h,
score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/threadq.h,
score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h,
score/include/rtems/score/userext.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h,
score/inline/rtems/score/address.inl,
score/inline/rtems/score/coremsg.inl,
score/inline/rtems/score/coresem.inl,
score/inline/rtems/score/heap.inl, score/inline/rtems/score/isr.inl,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/priority.inl,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/thread.inl,
score/inline/rtems/score/tqdata.inl,
score/inline/rtems/score/userext.inl,
score/inline/rtems/score/wkspace.inl,
score/macros/rtems/score/address.inl,
score/macros/rtems/score/heap.inl,
score/macros/rtems/score/object.inl,
score/macros/rtems/score/priority.inl,
score/macros/rtems/score/userext.inl: Convert to using c99 fixed
size types.
* configure.ac: RTEMS_TOP([../../../..]).
* score/src/Unlimited.txt, score/src/chain.c, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsgclose.c,
score/src/coremsgflush.c, score/src/coremsgflushsupp.c,
score/src/coremsgseize.c, score/src/coremsgsubmit.c,
score/src/coremutex.c, score/src/coremutexflush.c,
score/src/coresem.c, score/src/coresemflush.c, score/src/coretod.c,
score/src/coretodtickle.c, score/src/coretodtoseconds.c,
score/src/coretodvalidate.c, score/src/heap.c,
score/src/heapallocate.c, score/src/heapextend.c,
score/src/heapfree.c, score/src/heapsizeofuserarea.c,
score/src/interr.c, score/src/iterateoverthreads.c,
score/src/mpci.c, score/src/object.c, score/src/objectallocate.c,
score/src/objectallocatebyindex.c, score/src/objectclearname.c,
score/src/objectcomparenameraw.c,
score/src/objectcopynamestring.c,
score/src/objectget.c, score/src/objectgetbyindex.c,
score/src/objectgetisr.c, score/src/objectgetnoprotection.c,
score/src/objectidtoname.c, score/src/objectinitializeinformation.c,
score/src/objectmp.c, score/src/objectnametoid.c,
score/src/objectshrinkinformation.c, score/src/thread.c,
score/src/threadcreateidle.c, score/src/threadget.c,
score/src/threadidlebody.c, score/src/threadinitialize.c,
score/src/threadqdequeuepriority.c,
score/src/threadqenqueuepriority.c,
score/src/threadqfirstpriority.c, score/src/threadqflush.c,
score/src/threadreset.c, score/src/threadrestart.c,
score/src/threadsettransient.c, score/src/threadstackallocate.c,
score/src/threadstart.c, score/src/userext.c,
score/src/watchdoginsert.c, score/src/wkspace.c: Convert to using
* score/include/rtems/system.h: include <stdint.h>.
* score/macros/rtems/score/chain.inl, score/src/objectidtoname.c:
Add cast to avoid type punning warning in gcc 3.3.
* libblock/src/bdbuf.c, libblock/src/ramdisk.c,
libcsupport/src/newlibc.c, libcsupport/src/sync.c,
libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-symbols.c,
libmisc/shell/cmds.c, libmisc/shell/shell.c,
libnetworking/kern/kern_sysctl.c, libnetworking/lib/ftpfs.c,
libnetworking/lib/tftpDriver.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetnamadr.c,
libnetworking/libc/inet_addr.c, libnetworking/libc/linkaddr.c,
libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_print.c,
libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c,
libnetworking/libc/rcmd.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c,
libnetworking/libc/res_send.c, libnetworking/libc/res_update.c,
libnetworking/net/radix.c, libnetworking/rtems/mkrootfs.c,
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/svc.c,
score/macros/rtems/score/chain.inl, score/src/objectidtoname.c: Too
much was accidentally committed -- revert.
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/rtems_rpc.c,
librpc/src/rpc/svc.c, sapi/include/confdefs.h,
* cpu_asm.S: Close window while restoring interrupted task state which
resulted in CWP corruption.
PR 565/rtems
* asm.h: Various hacks.
PR 561/rtems
* asm.h: Add CONCAT0, EVAL. Let SYM and REG use CONCAT0 and EVAL.
* ChangeLog: Merge-in itron/ChangeLog, posix/ChangeLog, score/ChangeLog,
sapi/ChangeLog, rtems/ChangeLog.
* itron/ChangeLog, posix/ChangeLog, score/ChangeLog, sapi/ChangeLog,
rtems/ChangeLog: Remove.
* configure.ac: Move RTEMS_TOP one subdir down.
* Makefile.am: Re-add dirstamps to PREINSTALL_FILES.
Add PREINSTALL_FILES to CLEANFILES.
Add cpuopts.h to DISTCLEANFILES.
* configure.ac: Requires automake >= 1.8.1.
* cpu/Makefile.am: Use @RTEMS_CPU@ instead of $(RTEMS_CPU).
* Makefile.am: Include compile.am, again.
* macros/rtems/score/README: Remove (Redundant with macros/README).
* Makefile.am: Convert to using automake compilation rules.
* Makefile.am: Add libs to CLEANFILES
Set lib*_g_a_SOURCES = lib*_a_SOURCES.
* Makefile.am: Build libscore$(LIB_VARIANT).a instead of
$(ARCH)/libscore.a.
* qsm.h, sim.h: Remove efi68k and efi332 references as they are no
longer in the tree.
* rtems/score/mips.h: Removed junk revision line.
* cpu/Makefile.am: mips64orion port removed as mips port more
completely covers the MIPS family.
* cpu/mips64orion/.cvsignore, cpu/mips64orion/ChangeLog,
cpu/mips64orion/Makefile.am, cpu/mips64orion/asm.h,
cpu/mips64orion/configure.ac, cpu/mips64orion/cpu.c,
cpu/mips64orion/cpu_asm.S, cpu/mips64orion/cpu_asm.h,
cpu/mips64orion/idtcpu.h, cpu/mips64orion/idtmon.h,
cpu/mips64orion/iregdef.h, cpu/mips64orion/rtems/.cvsignore,
cpu/mips64orion/rtems/score/.cvsignore,
cpu/mips64orion/rtems/score/cpu.h,
cpu/mips64orion/rtems/score/mips64orion.h,
cpu/mips64orion/rtems/score/types.h: Removed.
* Makefile.am: Build library using EXTRA_LIBRARIES and automake rules.
PR 533/bsps
* startup/linkcmds: Update linkcmds for gcc 3.3.2.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Use mkdir_p. Remove dirs from PREINSTALL_FILES.
* Makefile.am:Restore further parts having been lost.
* Makefile.am: Restore file having been broken in last commit.
* Makefile.am: Remove TMPINSTALL_FILES.
* Makefile.am: Add $(dirstamp) to preinstallation rules.
Remove MACROS.
Remove MACROS.
PR 526/rtems
* src/threadcreateidle.c: Idle task name should be a string and
PR484 broke this.
