The SPARC ABI is a bit special with respect to the floating point context.
The complete floating point context is volatile. Thus from an ABI point
of view nothing needs to be saved and restored during a context switch.
Instead the floating point context must be saved and restored during
interrupt processing. Historically the deferred floating point switch is
used for SPARC and the complete floating point context is saved and
restored during a context switch to the new floating point unit owner.
This is a bit dangerous since post-switch actions (e.g. signal handlers)
and context switch extensions may silently corrupt the floating point
context. The floating point unit is disabled for interrupt handlers.
Thus in case an interrupt handler uses the floating point unit then this
will result in a trap.
On SMP configurations the deferred floating point switch is not
supported in principle. So use here a safe floating point support. Safe
means that the volatile floating point context is saved and restored
around a thread dispatch issued during interrupt processing. Thus
post-switch actions and context switch extensions may safely use the
floating point unit.
Update #2270.
Store the floating-point unit property in the thread control block
regardless of the CPU_HARDWARE_FP and CPU_SOFTWARE_FP settings. Make
sure the floating-point unit is only enabled for the corresponding
multilibs. This helps targets which have a volatile only floating point
context like SPARC for example.
Define CONTEXT_FP_SIZE to zero in case hardware and software floating
point support is disabled. The problem is that empty structures have a
different size in C and C++. In C++ they have a non-zero size leading
to an overestimate of the workspace size.
With the introduction of fine grained locking there is no longer a
one-to-one connection between the Giant lock nest level and the thread
dispatch disable level.
Update #2270.
The FP context save/restore makes only sense in the context of FP
threads.
Update #2270.
Update #2270.
Write the pattern only once to the entry register window and the
floating point registers.
Update #2270.
Replace _API_Mutex_Is_locked() with _API_Mutex_Is_owner().
Implement _CPU_Context_validate() and _CPU_Context_volatile_clobber().
Update #2270.
Replace timestamp implementation with FreeBSD bintime and timecounters.
New test sptests/sptimecounter02.
Update #2271.
New test sptests/timecounter01.
Update #2271.
Update #2271.
FreeBSD assumes that u_int is a 32-bit integer type. This is wrong for
some 16-bit targets supported by RTEMS.
Update #2271.
Update #2271.
Thread dispatching is disabled in case interrupts are disabled. To get
an accurate thread dispatch disabled time it is important to use the
interrupt disabled instant in case a transition from an interrupt
disabled section to a thread dispatch level section happens.
Use _Thread_Timeout() instead. Use pseudo thread queue for nanosleep()
to deal with signals.
Close #2130.
This reduces the code size drastically.
This function is superfluous due to the introduction of fine grained
locking.
Update #2273.
Move the writes to Thread_Control::current_priority and
Thread_Control::real_priority into _Thread_Change_priority() under the
protection of the thread lock. Add a filter function to
_Thread_Change_priority() to enable specialized variants.
Avoid race conditions during a thread priority restore with the new
Thread_Control::priority_restore_hint for an important average case
optimizations used by priority inheritance mutexes.
Update #2273.
Update #2273.
Rename _CORE_semaphore_Seize_isr_disable() to _CORE_semaphore_Seize().
Update #2273.
Aggregate several critical sections into a bigger one. Sending and
receiving messages is now protected by an ISR lock. Thread dispatching
is only disabled in case a blocking operation is necessary. The message
copy procedure is done inside the critical section (interrupts
disabled). Thus this change may have a negative impact on the interrupt
latency in case very large messages are transferred.
Update #2273.
Check the number of pending messages in _CORE_message_queue_Flush() to
avoid race conditions.
Use a parameter for _Thread_queue_Enqueue() instead to reduce memory
usage.
Use thread wait flags for synchronization. The enqueue operation is now
part of the initial critical section. This is the key change and
enables fine grained locking on SMP for objects using a thread queue
like semaphores and message queues.
Update #2273.
Move thread queue discipline specific operations into
Thread_queue_Operations. Use a separate node in the thread control
block for the thread queue to make it independent of the scheduler data
structures.
Update #2273.
Replace the Thread_Priority_control with more general
Thread_queue_Operations which will be used for generic priority change,
timeout, signal and wait queue operations in the future.
Update #2273.
Move the complete thread queue enqueue procedure into
_Thread_queue_Enqueue_critical(). It is possible to use the thread
queue lock to protect state of the object embedding the thread queue.
This enables per object fine grained locking in the future.
Delete _Thread_queue_Enter_critical_section().
Update #2273.
Add a thread wait timeout code. Replace _Event_Timeout() with a general
purpose _Thread_Timeout() watchdog handler.
Update #2273.
Merge THREAD_WAIT_STATE_SATISFIED, THREAD_WAIT_STATE_TIMEOUT,
THREAD_WAIT_STATE_INTERRUPT_SATISFIED, and
THREAD_WAIT_STATE_INTERRUPT_TIMEOUT into one state
THREAD_WAIT_STATE_READY_AGAIN. This helps to write generic routines to
block a thread.
Update #2273.
Use mostly the standard watchdog operations. Use a system event for
synchronization. This implementation is simpler and offers better SMP
performance.
Close #2131.
Make internal function _Watchdog_Remove_it() static to avoid accidental
usage.
Update #2307.
Rewrite the _Watchdog_Insert(), _Watchdog_Remove() and
_Watchdog_Tickle() functions to use iterator items to synchronize
concurrent operations. This makes it possible to get rid of the global
variables _Watchdog_Sync_level and _Watchdog_Sync_count which are a
blocking point for scalable SMP solutions.
Update #2307.
Update #2307.
Add watchdog header parameter to _Watchdog_Remove() to be in line with
the other operations. Add _Watchdog_Remove_ticks() and
_Watchdog_Remove_seconds() for convenience.
Update #2307.
Avoid the usage of the current thread state in
_Thread_queue_Extract_with_return_code() since thread queues should not
know anything about thread states.
Remove thread queue parameter from _Thread_queue_Extract() since the
current thread queue is stored in the thread control block.
