* | cpukit/score: avoid NULL and races in priority mutex4.10 | Gedare Bloom | 2020-01-03 | 2 | -1/+9 |
| | | | | | | | | | | The PIP modifications from #3359 introduced new data structures to track priority inheritance. Prioritized mutexes without PIP share some of the code paths, and may result in NULL pointer accesses. This patch checks for NULL, and also adds ISR critical sections to an uncovered corner case during thread restarts. Closes #3829. | ||||
* | score: add Inherited_priorities priority queue and functions | Gedare Bloom | 2018-03-23 | 11 | -16/+271 |
| | | | | | | | | | Adds enqueue, dequeue, requeue, evaluate, and release functions for the thread priority node priority queue of inherited priorities. Add calls to these functions as needed to maintain the priority queue due to blocking, unblocking, and priority changes. Closes #3359. | ||||
* | score: replace current and real priority with priority node | Gedare Bloom | 2018-03-23 | 14 | -37/+46 |
| | | | | | | | | | Encapsulate the current_priority and real_priority fields of the thread control block with a Thread_Priority_node struct. Propagate modifications throughout the tree where the two fields are directly accessed. Updates #3359. | ||||
* | score: Use _Workspace_Allocate_or_fatal_error() | Sebastian Huber | 2018-01-11 | 1 | -5/+8 |
| | | | | | | Use _Workspace_Allocate_or_fatal_error() consistently in case auto extend is turned off. This helps to avoid undefined behaviour in _API_Mutex_Allocate() in case _API_Mutex_Information() fails. | ||||
* | score/chain: Fix _Chain_Is_first and _Chain_Is_last | Gedare Bloom | 2018-01-10 | 1 | -2/+2 |
| | | | | Updates #1964. | ||||
* | score: PR2179: Fix initially locked PI mutex | Sebastian Huber | 2014-08-20 | 1 | -4/+10 |
* | score: PR2179: Fix initially locked PCP mutexes | Sebastian Huber | 2014-05-23 | 1 | -2/+3 |
| | | | | | Elevate the priority of the creating task to the ceiling priority in case a semaphore is created as initially locked. | ||||
* | score: PR2140: Fix _Thread_queue_Process_timeout() | Sebastian Huber | 2013-08-26 | 1 | -8/+37 |
| | | | | | | The _Thread_queue_Process_timeout() operation had several race conditions in the event of nested interrupts. Protect the critical sections via disabled interrupts. | ||||
* | score: PR2140: _Thread_queue_Extract() | Sebastian Huber | 2013-08-26 | 4 | -11/+14 |
| | | | | | Return if the executing context performed the extract operation since interrupts may interfere. | ||||
* | score: Fix _Objects_Shrink_information() | Sebastian Huber | 2013-01-07 | 1 | -20/+16 |
| | | | | The chain iteration was wrong. The chain tail is not an object. | ||||
* | score: Critical fix for timer server | Sebastian Huber | 2012-12-06 | 1 | -7/+0 |
| | | | | | | | | Under certain conditions it is possible that a call to _Watchdog_Adjust_to_chain() happens with a unit parameter value of zero (for example sptests/spintrcritical17). Remove superfluous checks that prevent an adjust to a chain of a watchdog chain which first element has a delta zero value. | ||||
* | Add .git ignore. Remove .cvsignore | Joel Sherrill | 2012-02-02 | 17 | -33/+0 |
* | 2011-11-28 Werner Almesberger <werner@almesberger.net> | Joel Sherrill | 2011-11-28 | 1 | -15/+3 |
| | | | | | | PR 1961/cpukit * score/src/coremsgsubmit.c: Close window caused by using message pending count rather than directly obtaining unused buffer. | ||||
* | Move entries to correct file. | Joel Sherrill | 2011-11-09 | 1 | -0/+7 |
* | 2011-11-09 Werner Almesberger <werner@almesberger.net> | Joel Sherrill | 2011-11-09 | 2 | -2/+7 |
| | | | | | PR 1954/cpukit * rtems/score/lm32.h: Protect against macro expansion. | ||||
* | 2011-11-09 Werner Almesberger <werner@almesberger.net> | Joel Sherrill | 2011-11-09 | 2 | -3/+3 |
| | | | | | | | PR 1957/cpukit * score/include/rtems/score/coremutex.h, score/inline/rtems/score/threadmp.inl: Add parentheses to protect macro arguments. | ||||
* | 2011-11-09 Werner Almesberger <werner@almesberger.net> | Joel Sherrill | 2011-11-09 | 2 | -2/+9 |
| | | | | | PR 1955/cpukit * rtems/score/cpu.h: Convert CPU_swap_u16 into a static inline. | ||||
* | 2011-09-01 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-09-01 | 3 | -10/+42 |
| | | | | | | | | PR 1895/cpukit * posix/src/mqueuerecvsupp.c, posix/src/pthreadjoin.c, score/src/coretodmsecstoticks.c, score/src/coretodusectoticks.c, score/src/timespectoticks.c: Ensure time conversions to ticks do not ignore partial tick and return 1 less than desired. | ||||
* | 2009-11-09 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2011-07-13 | 1 | -0/+5 |
| | | | | * ChangeLog: had forgotten to commit ChangeLog | ||||
* | Cosmetics from CVS-HEAD. | Ralf Corsepius | 2011-05-25 | 26 | -62/+49 |
* | Fix formatting. | Joel Sherrill | 2011-04-20 | 1 | -7/+0 |
* | 2011-04-20 Rohan Kangralkar <rkangral@ece.neu.edu> | Joel Sherrill | 2011-04-20 | 5 | -3/+454 |
| | | | | | | | | PR 1781/bsps * bfin/rtems/bf52x.h: This file defines basic MMR for the Blackfin 52x CPU. The MMR have been taken from the ADSP-BF52x Blackfin Processor Hardware Reference from Analog Devices. Mentioned Chapters refer to this Documentation. | ||||
* | 2010-11-23 Gedare Bloom <giddyup44@yahoo.com> | Sebastian Huber | 2010-11-23 | 2 | -1/+14 |
| | | | | | PR 1719/cpukit * arm_exc_abort.S: Avoid "bx" instruction to support ARMv4 and below. | ||||
* | 2010-06-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-14 | 4 | -14/+14 |
| | | | | | | | | | * libnetworking/rtems/mkrootfs.h, posix/include/rtems/posix/pthread.h, score/include/rtems/score/coresem.h, score/include/rtems/score/priority.h, score/include/rtems/score/threadq.h, score/include/rtems/score/timestamp.h: Move 'extern "C"'. | ||||
* | 2010-06-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-12 | 3 | -7/+7 |
| | | | | | | | * score/include/rtems/score/timestamp.h, score/include/rtems/score/timestamp64.h, score/include/rtems/score/watchdog.h: Misc. doxygen fixes. | ||||
* | 2010-06-09 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-09 | 1 | -1/+0 |
| | | | | | * configure.ac: Remove nios2 (unsupported, no toolchain). * score/cpu/Makefile.am: Remove nios2 (unsupported, no toolchain). | ||||
* | Remove (unsupported, no toolchain). | Ralf Corsepius | 2010-06-09 | 12 | -2446/+0 |
* | Remove (dead port). | Ralf Corsepius | 2010-06-09 | 13 | -3475/+0 |
| | | | | * score/cpu/Makefile.am: Remove c4x (dead port). | ||||
* | 2010-05-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-29 | 2 | -1/+5 |
| | | | | * irq.c: Change _exception_stack_frame into void*. | ||||
* | 2010-05-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-23 | 2 | -0/+6 |
| | | | | * cpu.c: Warning removal. | ||||
* | 2010-05-21 Vinu Rajashekhar <vinutheraj@gmail.com> | Joel Sherrill | 2010-05-21 | 2 | -115/+6 |
| | | | | | * rtems/score/registers.h: Remove structs with bit-fields. Add a mask for cr3 page directory. | ||||
* | 2010-05-10 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-05-10 | 2 | -1/+6 |
| | | | | | * rtems/score/arm.h: Make it a warning not error that the FPU multilib is not supported yet. | ||||
* | 2010-05-10 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-05-10 | 4 | -4/+31 |
| | | | | | * context_init.c, context_switch.S, cpu.c: Now builds multilib. R8C paths produce warnings for now. | ||||
* | 2010-05-10 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-05-10 | 162 | -2171/+52157 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, cpu_asm.S, avr/boot.h, avr/common.h, avr/crc16.h, avr/delay.h, avr/eeprom.h, avr/fuse.h, avr/interrupt.h, avr/io.h, avr/io1200.h, avr/io2313.h, avr/io2323.h, avr/io2333.h, avr/io2343.h, avr/io43u32x.h, avr/io43u35x.h, avr/io4414.h, avr/io4433.h, avr/io4434.h, avr/io76c711.h, avr/io8515.h, avr/io8534.h, avr/io8535.h, avr/io86r401.h, avr/io90pwm1.h, avr/io90pwm216.h, avr/io90pwm2b.h, avr/io90pwm316.h, avr/io90pwm3b.h, avr/io90pwm81.h, avr/io90pwmx.h, avr/io90scr100.h, avr/ioa6289.h, avr/ioat94k.h, avr/iocan128.h, avr/iocan32.h, avr/iocan64.h, avr/iocanxx.h, avr/iom103.h, avr/iom128.h, avr/iom1280.h, avr/iom1281.h, avr/iom1284p.h, avr/iom128rfa1.h, avr/iom16.h, avr/iom161.h, avr/iom162.h, avr/iom163.h, avr/iom164.h, avr/iom165.h, avr/iom165p.h, avr/iom168.h, avr/iom168p.h, avr/iom169.h, avr/iom169p.h, avr/iom16hva.h, avr/iom16m1.h, avr/iom16u4.h, avr/iom2560.h, avr/iom2561.h, avr/iom32.h, avr/iom323.h, avr/iom324.h, avr/iom325.h, avr/iom3250.h, avr/iom328p.h, avr/iom329.h, avr/iom3290.h, avr/iom32c1.h, avr/iom32hvb.h, avr/iom32m1.h, avr/iom32u4.h, avr/iom32u6.h, avr/iom406.h, avr/iom48.h, avr/iom48p.h, avr/iom64.h, avr/iom640.h, avr/iom644.h, avr/iom645.h, avr/iom6450.h, avr/iom649.h, avr/iom6490.h, avr/iom64c1.h, avr/iom64m1.h, avr/iom8.h, avr/iom8515.h, avr/iom8535.h, avr/iom88.h, avr/iom88p.h, avr/iom8hva.h, avr/iomx8.h, avr/iomxx0_1.h, avr/iomxx4.h, avr/iomxxhva.h, avr/iotn11.h, avr/iotn12.h, avr/iotn13.h, avr/iotn13a.h, avr/iotn15.h, avr/iotn167.h, avr/iotn22.h, avr/iotn2313.h, avr/iotn24.h, avr/iotn25.h, avr/iotn26.h, avr/iotn261.h, avr/iotn28.h, avr/iotn43u.h, avr/iotn44.h, avr/iotn45.h, avr/iotn461.h, avr/iotn48.h, avr/iotn84.h, avr/iotn85.h, avr/iotn861.h, avr/iotn87.h, avr/iotn88.h, avr/iotnx4.h, avr/iotnx5.h, avr/iotnx61.h, avr/iousb1286.h, avr/iousb1287.h, avr/iousb162.h, avr/iousb646.h, avr/iousb647.h, avr/iousb82.h, avr/iousbxx2.h, avr/iousbxx6_7.h, avr/iox128a1.h, avr/iox128a3.h, avr/iox16a4.h, avr/iox16d4.h, avr/iox256a3.h, avr/iox256a3b.h, avr/iox32a4.h, avr/iox32d4.h, avr/iox64a1.h, avr/iox64a3.h, avr/lock.h, avr/parity.h, avr/pgmspace.h, avr/portpins.h, avr/power.h, avr/sfr_defs.h, avr/signal.h, avr/sleep.h, avr/version.h, avr/wdt.h, rtems/asm.h, rtems/score/cpu.h: Update to avr .h files from avr-libc 1.6.8. Tinker with code and includes to eliminate warnings. Now builds multilib. * avr/iom169pa.h, avr/iom16a.h, avr/iom16hva2.h, avr/iom16hvb.h, avr/iom16u2.h, avr/iom324pa.h, avr/iom32u2.h, avr/iom644p.h, avr/iom644pa.h, avr/iom649p.h, avr/iom64hve.h, avr/iom88pa.h, avr/iom8u2.h, avr/iotn2313a.h, avr/iotn24a.h, avr/iotn261a.h, avr/iotn4313.h, avr/iotn44a.h, avr/iotn461a.h, avr/iotn861a.h, avr/iox128d3.h, avr/iox192a3.h, avr/iox192d3.h, avr/iox256d3.h, avr/iox64d3.h, avr/signature.h: New files. | ||||
* | 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-25 | 2 | -6/+10 |
| | | | | * context_init.c: Eliminate warnings. | ||||
* | 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-25 | 3 | -14/+57 |
| | | | | | * cpu.c, rtems/score/cpu.h: Move _CPU_Context_Initialize() to cpu.c so it is easier to make warning free. | ||||
* | 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-25 | 2 | -2/+6 |
| | | | | * rtems/score/cpu.h: Remove warning in _CPU_Context_Initialize. | ||||
* | 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-25 | 4 | -6/+14 |
* | 2010-04-20 Allan Hessenflow <allanh@kallisti.com> | Joel Sherrill | 2010-04-20 | 2 | -9/+26 |
| | | | | | | | * cpu_asm.S: L0-L3 were part of the interrupt context, but as Mike Frysinger noted they were not being zeroed before calling the C handlers. A patch that corrects this, as well as improving some of the push/pop order to avoid stalls. | ||||
* | 2010-04-17 Allan Hessenflow <allanh@kallisti.com> | Joel Sherrill | 2010-04-17 | 4 | -32/+8 |
| | | | | | | * cpu.c, cpu_asm.S, rtems/score/cpu.h: Fine tune registers saved in the context. The sp and imask registers need to be saved. Also allocated 12 bytes on the stack at thread entry as the abi requires that. | ||||
* | 2010-04-17 Mike Frysinger <vapier.adi@gmail.com> | Joel Sherrill | 2010-04-17 | 2 | -0/+10 |
| | | | | * cpu.c: Blackfin ABI requires L registers to be 0 upon function entry. | ||||
* | 2010-04-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-04-15 | 2 | -1/+6 |
| | | | | * rtems/score/cpu.h: Make _gp global. | ||||
* | 2010-04-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-04-12 | 1 | -1/+1 |
| | | | | | * score/include/rtems/system.h: Let RTEMS_offsetof return uintptr_t instead of uint32_t (16bit target compatibility). | ||||
* | 2010-04-08 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 2010-04-08 | 3 | -8/+23 |
| | | | | | | * cpu_asm.S, rtems/score/cpu.h: On uC5282, the thread restart needed to reload the frame pointer. As part of doing this, the code was moved from inline asm to the .S file. | ||||
* | add/adapt documentation | Thomas Doerfler | 2010-04-08 | 13 | -69/+190 |
* | 2010-04-07 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-04-07 | 1 | -1/+0 |
| | | | | * score/src/wkspace.c: Remove duplicate include. | ||||
* | 2010-04-07 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-04-07 | 1 | -0/+6 |
| | | | | | * score/include/rtems/system.h: Fix warnings about TRUE/FALSE not defined on ARM target. This file need to be clean from .S files. | ||||
* | 2010-04-07 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-04-07 | 2 | -1/+5 |
| | | | | * arm_exc_abort.S: Fix warnings about TRUE/FALSE not defined. | ||||
* | Fix. | Joel Sherrill | 2010-03-28 | 1 | -3/+4 |
