PR 1599/cpukit
* posix/src/psignalunblockthread.c, posix/src/pthreadkill.c,
rtems/src/signalsend.c, score/include/rtems/score/percpu.h,
score/inline/rtems/score/thread.inl, score/src/thread.c,
score/src/threadchangepriority.c, score/src/threadclearstate.c,
score/src/threaddispatch.c, score/src/threadready.c,
score/src/threadresume.c, score/src/threadsetstate.c,
score/src/threadstartmultitasking.c, score/src/threadsuspend.c,
score/src/threadyieldprocessor.c: Rename _Context_Switch_necessary to
_Thread_Dispatch_necessary to more properly reflect the intent.
PR 1599/cpukit
* cpu_asm.c: Rename _Context_Switch_necessary to
PR 1599/cpukit
* irq.c: Rename _Context_Switch_necessary to _Thread_Dispatch_necessary
PR 1599/cpukit
* cpu_asm.S: Rename _Context_Switch_necessary to
PR 1635/cpukit
* sapi/src/exinit.c, score/Makefile.am, score/preinstall.am,
score/include/rtems/score/bitfield.h,
score/inline/rtems/score/priority.inl,
score/src/threadready.c, score/src/threadresume.c,
score/src/threadsetpriority.c, score/src/threadsetstate.c,
score/src/threadsettransient.c, score/src/threadsuspend.c:
Refactoring of priority handling, to isolate the bitmap
implementation of priorities in the supercore so that priority
management is a little more modular. This change is in anticipation
of scheduler implementations that can select how they manage tracking
priority levels / finding the highest priority ready task. Note that
most of the changes here are simple renaming, to clarify the use of
the bitmap-based priority management.
* score/include/rtems/score/prioritybitmap.h,
score/inline/rtems/score/prioritybitmap.inl: New files.
PR 1635/cpukit
* rtems/score/types.h: Refactoring of priority handling, to isolate the
bitmap implementation of priorities in the supercore so that priority
PR 1635/cpukit
* rtems/score/cpu.h, rtems/score/types.h: Refactoring of priority
handling, to isolate the bitmap implementation of priorities in the
supercore so that priority management is a little more modular. This
change is in anticipation of scheduler implementations that can
select how they manage tracking priority levels / finding the highest
priority ready task. Note that most of the changes here are simple
renaming, to clarify the use of the bitmap-based priority management.
* rtems/score/cpu.h: Assembler compatibility fixes.
* rtems/asm.h: Fixed header guard.
* score/src/threadget.c: Conditionalize a check that can only occur
when POSIX is disabled.
* rtems/src/taskmode.c, score/inline/rtems/score/thread.inl: Rework a
bit to eliminate unreachable path for task blocked while calling
rtems_task_mode() on itself.
* libcsupport/src/privateenv.c, libmisc/cpuuse/cpuusagereport.c,
posix/Makefile.am, posix/include/rtems/posix/key.h,
posix/src/keycreate.c, posix/src/keydelete.c,
score/src/iterateoverthreads.c: Since removing ITRON, the loop over
all APIs for tasks has a path that cannot be reached. Either modify
the code or mark tests for NULL as RTEMS_DEBUG.
* posix/src/keyfreememory.c: New file.
* rtems/score/cpu.h: Include <rtems/score/types.h> first.
* rtems/score/types.h: Use <rtems/score/basedefs.h> header file.
* rtems/new-exceptions/cpu.h: Removed file.
* Makefile.am, preinstall.am: Reflect change above.
* rtems/score/cpu.h: Include <rtems/score/types.h> first. Added
contents of <rtems/new-exceptions/cpu.h>.
* score/include/rtems/score/basedefs.h: New file.
* score/Makefile.am, score/preinstall.am: Reflect change above.
* score/include/rtems/score/percpu.h: Include <rtems/score/cpu.h>.
* score/include/rtems/system.h: Moved definition of SCORE_EXTERN,
SAPI_EXTERN, RTEMS_EXTERN, POSIX_EXTERN, RTEMS_INLINE_ROUTINE,
RTEMS_COMPILER_MEMORY_BARRIER, RTEMS_COMPILER_NO_RETURN_ATTRIBUTE,
RTEMS_COMPILER_DEPRECATED_ATTRIBUTE, TRUE, and FALSE to
<rtems/score/basedefs.h>.
Removed include of <rtems/score/cpu.h>, <stdint.h> and <stddef.h>.
PR 1607/cpukit
* score/src/coremutexsurrender.c: Clean up and split out helper
routines.
* score/include/rtems/seterr.h: Include <errno.h>.
PR 1606/cpukit
* score/include/rtems/score/interr.h: Remove
INTERNAL_ERROR_INVALID_WORKSPACE_ADDRESS since it is not generated.
* score/src/isrthreaddispatch.c: Removed file.
* score/Makefile.am: Reflect change above.
* score/include/rtems/score/isr.h: Removed _ISR_Thread_dispatch()
declaration.
* rtems/score/cpu.h: Removed CPU_ENABLE_C_ISR_DISPATCH_IMPLEMENTATION
define.
* rtems/asm.h, rtems/score/cpu.h: cpu.h defines were not available to
assembly programs. This resulted in percpu.h (when included from
assembly) not being able to detect that the MIPS does not have a
dedicated software managed interrupt stack.
* libcsupport/src/rtems_memalign.c, score/include/rtems/score/heap.h:
Remove stray references to malloc boundary.
PR 1588/cpukit
* rtems/powerpc/registers.h: Renamed defines SR0 .. SR15 in
PPC_SR0 .. PPC_SR15.
* configure.ac, score/include/rtems/score/percpu.h: Add
__RTEMS_SIZEOF_VOID_P__ to cpuopts.h so percpu.h has this information
available during build and after installation.
PR 1573/cpukit
* configure.ac, posix/src/killinfo.c,
posix/src/psignalunblockthread.c, posix/src/pthreadcreate.c,
posix/src/pthreadkill.c, posix/src/pthreadsigmask.c,
rtems/src/signalsend.c, rtems/src/taskmode.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/system.h,
score/include/rtems/score/context.h, score/include/rtems/score/isr.h,
score/include/rtems/score/thread.h, score/src/isr.c,
score/src/isrthreaddispatch.c, score/src/thread.c,
score/src/threaddispatch.c, score/src/threadloadenv.c: Add a per cpu
data structure which contains the information required by RTEMS for
each CPU core. This encapsulates information such as thread
executing, heir, idle and dispatch needed.
* score/include/rtems/score/percpu.h, score/src/percpu.c: New files.
PR 1573/cpukit
* cpu_asm.S, rtems/score/cpu.h: Add a per cpu data structure which
contains the information required by RTEMS for each CPU core. This
encapsulates information such as thread executing, heir, idle and
dispatch needed.
PR 1573/cpukit
* rtems/score/cpu.h: Add a per cpu data structure which contains the
information required by RTEMS for each CPU core. This encapsulates
information such as thread executing, heir, idle and dispatch needed.
PR 1573/cpukit
* rtems/new-exceptions/cpu.h: Add a per cpu data structure which
dispatch needed.
PR 1573/cpukit
* cpu_asm.c, rtems/score/cpu.h: Add a per cpu data structure which
dispatch needed.
PR 1573/cpukit
* irq.c, rtems/score/cpu.h: Add a per cpu data structure which contains
dispatch needed.
PR 1573/cpukit
* cpu_asm.S, rtems/asm.h, rtems/score/cpu.h: Add a per cpu data
structure which contains the information required by RTEMS for each
CPU core. This encapsulates information such as thread executing,
PR 1573/cpukit
* arm_exc_interrupt.S: Add a per cpu data structure which contains the
PR 1589/cpukit
* score/Makefile.am, score/include/rtems/score/thread.h,
score/inline/rtems/score/thread.inl: Make _Thread_Evaluate_mode() an
inline method. It is only used in one place and relatively simple.
* score/src/threadevaluatemode.c: Removed.
PR 1590/cpukit
score/src/threadtickletimeslice.c: Remove _Thread_Reset_timeslice and
replaces its single use with a call to the functionally equivalent
_Thread_Yield_processor().
* score/src/threadresettimeslice.c: Removed.
PR 1554/cpukit
Coverity Id 17
* libi2c/libi2c.c, score/src/objectextendinformation.c: Fix memory leak
on error.
* score/include/rtems/score/object.h: Remove OBJECTS_ITRON_API.
* score/include/rtems/score/thread.h: Remove ITRON.
* score/include/rtems/score/interr.h: Remove ITRON.
* score/src/objectapimaximumclass.c: Remove OBJECTS_ITRON_API.
* score/include/rtems/system.h: Remove ITRON_EXTERN.
* score/src/apiext.c: Remove comment referring to ITRON.
* core/include/rtems/score/object.h: Remove Objects_ITRON_API.
* score/include/rtems/score/object.h,
score/include/rtems/score/thread.h: Remove prototypes for ITRON
only methods removed by Ralf.
* score/src/objectallocate.c: Add conditionally compiled debug code to
printk a message when an object allocation error occurs. This should
be helpful in identifying when a ported package required more
resources.
* cpu_asm.S: Remove trailing tabs.
* cpu_asm.S: Use SYM macro to be consistent with other ports.
