* Makefile.am:Restore further parts having been lost.
* Makefile.am: Restore file having been broken in last commit.
* Makefile.am: Remove TMPINSTALL_FILES.
* Makefile.am: Add $(dirstamp) to preinstallation rules.
Remove MACROS.
Remove MACROS.
PR 526/rtems
* src/threadcreateidle.c: Idle task name should be a string and
PR484 broke this.
PR 525/rtems
* include/rtems/system.h: Use RTEMS_INLINES instead of USE_INLINES.
* include/rtems/score/chain.h: Ditto.
* include/rtems/score/thread.h: Ditto.
* src/chain.c: Ditto.
* src/coremutexseize.c: Ditto.
* src/threadget.c: Ditto.
* Makefile.am: Remove all LIB-related rules.
* Makefile.am: Don't use gmake to preinstall.
* Makefile.am: Don't use gmake rules for preinstallation.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac: Remove RTEMS_CHECK_CPU.
* src/coremsgseize.c, src/coremsgsubmit.c:
Remove unnecessary typecasts in assignments to
thread->Wait.return_argument.
PR 504/rtems
* include/rtems/score/coremutex.h: Add fatal error check for a task
blocking on a mutex when thread dispatching is disabled.
* rtems/new-exceptions/cpu.h, rtems/old-exceptions/cpu.h: Obsoleting HP
PA-RISC port and removing all references.
* rtems/score/cpu.h: Obsoleting HP PA-RISC port and removing all
references.
* cpu/hppa1.1/.cvsignore, cpu/hppa1.1/ChangeLog,
cpu/hppa1.1/Makefile.am, cpu/hppa1.1/configure.ac, cpu/hppa1.1/cpu.c,
cpu/hppa1.1/cpu_asm.S, cpu/hppa1.1/rtems/.cvsignore,
cpu/hppa1.1/rtems/score/.cvsignore, cpu/hppa1.1/rtems/score/cpu.h,
cpu/hppa1.1/rtems/score/cpu_asm.h, cpu/hppa1.1/rtems/score/hppa.h,
cpu/hppa1.1/rtems/score/types.h: Removed.
PR 489/rtems
* include/rtems/score/thread.h: Change struct
Thread_Control_struct.libc_reent to using struct _reent*.
* inline/rtems/score/thread.inl: Reflect change above.
PR 484/rtems
* src/threadcreateidle.c: Idle task name was initialized incorrectly.
* inline/rtems/score/userext.inl, macros/rtems/score/userext.inl:
Add missing cast.
* cpu.c, rtems/score/cpu.h, rtems/score/types.h, rtems/score/unix.h:
* cpu.c, cpu_asm.S, rtems/score/cpu.h, rtems/score/sparc.h,
rtems/score/types.h: URL for license changed.
* asm.h, cpu.c, rtems/score/cpu.h, rtems/score/sh.h,
rtems/score/sh_io.h, rtems/score/types.h: URL for license changed.
* rtems/new-exceptions/cpu.h, rtems/old-exceptions/cpu.h,
rtems/powerpc/registers.h, rtems/score/ppc.h, rtems/score/types.h:
* cpu.c, cpu_asm.c, rtems/score/cpu.h, rtems/score/cpu_asm.h,
rtems/score/or32.h, rtems/score/types.h: URL for license changed.
rtems/score/no_cpu.h, rtems/score/types.h: URL for license changed.
* cpu.c, cpu_asm.S, cpu_asm.h, rtems/score/cpu.h,
rtems/score/mips64orion.h, rtems/score/types.h: URL for license
changed.
* cpu.c, cpu_asm.S, rtems/score/cpu.h, rtems/score/mips.h,
* cpu.c, cpu_asm.S, rtems/score/cpu.h, rtems/score/m68k.h,
* cpu.c, cpu_asm.S, rtems/score/cpu.h, rtems/score/i960.h,
* cpu.c, cpu_asm.S, rtems/score/cpu.h, rtems/score/i386.h,
rtems/score/idtr.h, rtems/score/interrupts.h,
rtems/score/registers.h, rtems/score/types.h: URL for license
changed.
* cpu.c, cpu_asm.S, rtems/score/cpu.h, rtems/score/hppa.h: URL for
license changed.
* asm.h, cpu.c, cpu_asm.S, rtems/score/cpu.h, rtems/score/h8300.h,
* cpu.c, cpu_asm.S, irq.c, rtems/score/c4x.h, rtems/score/cpu.h,
rtems/score/cpu_asm.h, rtems/score/types.h: URL for license changed.
* asm.h, cpu.c, cpu_asm.S, rtems/score/arm.h, rtems/score/cpu.h,
PR 457/bsps
* rtems/powerpc/registers.h: Add a few definitions for the PowerPC
thermal assistance unit.
* Makefile.am, include/rtems/score/object.h,
include/rtems/score/objectmp.h, src/objectmp.c, src/objectnametoid.c:
Added ID to name lookup service and changed name of id/name
translation status code. This propagated to multiple functions. The
user API service added was rtems_object_id_to_name()
* src/objectidtoname.c: New file.
PR 408/filesystem
* score/Makefile.am, score/include/rtems/score/thread.h: Added
sync() service. As part of adding this service, the
new RTEMS service rtems_iterate_over_all_threads() was also added.
This new service makes it easier to iterate over all the
tasks/threads in a system and perform an action on them.
* score/src/iterateoverthreads.c: New file.
* ChangeLog: Fixed screwup.
* ChangeLog: Add fileio to list of interactive tests.
* Makefile.am, include/rtems/score/thread.h: Add fileio to list of
interactive tests.
PR 455/bsps
* rtems/score/cpu.h: Added missing CPU_swap_u16().
PR 288/rtems
* rtems/new-exceptions/cpu.h: _ISR_Nest_level is now properly
maintained and does not reside in SPRG0.
PR 430/rtems
* include/rtems/score/watchdog.h: _Watchdog_Ticks_since_boot should
be a VOLATILE variable.
* src/watchdoginsert.c: 'restart' algorithm needs to enforce
reloading the list head in case a TICK interrupt during ISR_Flash()
modified the list. This is achieved by a proper VOLATILE cast.
Also _Watchdog_Sync_count++ should be protected by _ISR_Disable
(prevent corruption in case ISR calls watchdoginsert)
* src/watchdogadjust.c: ISR protection added.
* src/watchdogtickle.c: ISR protection added.
NOTE: PowerPC BSPs using the new exception processing MUST BE UPDATED
to maintain _ISR_Nest_level. See also PR288 which provides fixes
for the affected BSPs distributed with RTEMS.
* cpu/Makefile.am: Add DIST_SUBDIRS = $(RTEMS_CPU).
PR 417/rtems
* src/coresemsurrender.c: Correct incorrect check for maximum_count
reported by Sergei Organov <osv@topconrd.ru>.
* src/threadloadenv.c: Removed warnings.
