Update #3706
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7976215
* score/include/rtems/score/wkspace.h, score/src/wkstringduplicate.c:
Changed parameter of _Workspace_String_duplicate() to avoid strnlen().
* score/src/wkstringduplicate.c: New file.
* score/Makefile.am: Reflect change above.
* score/include/rtems/score/wkspace.h: Declare
_Workspace_String_duplicate().
